Question about Toshiba Tecra 8000 Notebook
Connection to printer not working
Have toshiba tecra connected to printer through d-link router. Although printing functions, it is very slow, and the printer flashes an error (unknown) prior to printer
Dell inspiron 6000..no sound audio..i think the sigmatel c-major audio has problem.how to solution this?
Posted on Feb 08, 2009
I cannot work out how to connect my printer with my d-link DIR-655 router. When I take the printer USB out of my computer and plug it in to the USB port on the router, I cannot print from mycomputer. I...
You cannot set the printer up directly on the router as the router needs to have a driver to understand how to use the printer. If you have a wireless printer, you need to enter a wireless key on the printer, you'll have to do that from the printer interface (you didn't list your printer model so i'm not sure how exactly you do that). On my wireless printer there is a nice network setup menu on the touch screen display.
Then you have to install the full drivers for the printer and tell it the printer is connected wirelessly and it looks for it and finds its IP address and allows you to connect to it.
If you do not have a wireless printer, and need to print wirelessly, you will need to buy a print server.
Apr 17, 2011 | D-Link Xtreme N DIR-655 Wireless Router
Can the epson R220 print wireless
It can't print wirelessly with the native hardware. It has a USB 1.1 connection. You may be able to find a print server that can connect to a wireless router. However, you will need to check the specifications. Some print servers will only work with select printers or OS combinations.
The specifications for the R220 are here: http://www.epson.com/cgi-bin/Store/consumer/consDetail.jsp?BV_UseBVCookie=yes&infoType=Specs&oid=58654761&category=Products .
I hope this helps.
(note since this is an older printer with a USB 1.1 connection, you can expect the printer to be slow with a wireless connection. If your signal strength drops, you may need to reboot everything (computer, print server, router and printer).)
Mar 21, 2011 | Epson Stylus Photo R220 InkJet Printer
I have print server d-link dpr-1020 connected to laser printer hp P1006. My PC is running under windows 7 Pro. Print server is connected to linksys wrt120n router by cable. My PC is connected to the...
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
Nov 05, 2010 | D-Link RangeBooster G DPR-1260 (DPR1260)...
I have the MFC-490CW, I am trying to install it to be wireless. But I can't figure out some of the items. How do I find the WEP key?
My brother MFC490-CW is connected wirelessly to the router. It printed OK wirelessly yesterday when I set it up but today it will not print. The printer has a strong wireless connection to the router. My PC also has a strong connection to the router. But the printer seems to have lost the connection to my PC. How to I re-establish the wireless connection from the printer to my PC?
Nov 03, 2009 | Brother MFC 490cw Color Inkjet...
Using D-link dp-300 Printer Canon ImargeClass MF4350d (Multifunction printer) Problem. I can not use scanner fanction. (no problem for printer) Without printer server, I able to use the scanner.
The problem you are having is pretty standard, the IP based printing works for most printers but the scanner require direct(or well faked, direct) connectivity with a USB port which most routers do not provide.
Several companies including Startech and Io Gear make Virtual USB devices which would resolve the issue.
How they work differs as instead of creating an IP printer, the usb device installs on an ip and then a driver you install on your PC(s) connect to the unit over the router and sets up a virtual USB port on your machine so you can re-install the printer as a local printer attached to what it thinks is a local USB port.
Doing this will allow you all functionality the printer offers but will slow down printing and scanning a bit
Hope this Helps,
Chris
Armor-IT
Apr 24, 2009 | D-Link DP 300U (DP-300U) Print Server
Document will not print when sent to the printer; and it is being sent to the correct printer.
Are you sure you printer is 'online" and the connection is good? Can you ping it?
I did a service call just today that the router port had died, so although properly connected, it was not communicating. Is the "green light" lit on your network port on the printer or just the "yellow"? If not, then maybe bad cable or connection from router.
Mar 06, 2009 | Ricoh Aficio MP1600SPF Copier
Toshiba Tecra 8000.how do i activate wireless?
it should work even without using the cd based on my experience. just be sure your wifi in your laptop is on. it should let you know if the wifi light is turned on on your laptop.
Feb 05, 2009 | Toshiba Tecra 8000 Notebook
Toshiba Tecra 510CDT Laptop
hi,
this is mainly dependant, on what input/outputs the laptop has at the rear. If it has a printer port, or USBs. you need to be able to physically connect, laptop to printer, as i,d imagine it has no bluetooth or infra-red et,c.
Thankyou for using fixya.
Mike at compurepair.
Jan 20, 2009 | Toshiba Tecra 510CDT (P000224080)...
Toshiba Tecra 8000 Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
