Question about Microsoft Xbox 360 Console
Turning the xbox 360 into xbox 360 live?
We have the xbox working but we seem unable, as we simply don't know, what we need and are required to do to make our xbox live via a wireless connection.
My pc is too far away for the cable and we are using a vodafone netgear wireless connection to my pc which has 4 spare wired connector points.
The router is a Netgear 54Mbps Wireless ADSL Modem router DG834GSP v3
  • 5 Answers
Ok, so if you want to do it wirelessly you need to get the wireless network adapter for the 360. i got mine at target for about 100 bucks. You also will need a Xbox live Gold card if you are wanting to play with your friends. you can also get your subcription over the xbox by using a credit card. The setup is pretty simple, just follow the on screan instructions. I am assuming your dashboard uses the "blades". if so, go over to the marketplace section, and go to join xbox live. then it will guide you through the process.
Hope this helps you.
Posted on Feb 08, 2009
It asking me to dowload something what do I do?
It is an update for the game. It fixes glitches and bugs usually. However they are not required to be downloaded.
Feb 09, 2013 | Ubisoft Just Dance 4 Xbox 360
Dont know how to set up xbox live
First you need to have a Windows Live ID email address, you can link any email address to Windows Live so you don't need to create a new one.
Second, you need to get on your Xbox console and select connect to Xbox Live, follow the instructions and you should be good to go.
Aug 17, 2011 | Microsoft Xbox 360 Console
Got a game the other day the xbox 360 will not let us play it keeps coming up the game requires an update please can you tell me what that means
Means you system needs an update. Connect you xbox to xbox live. If you don't have an account thats alright silver access will work for this. I was going to type it out but found this and thought be easier for you to use just go to this site:http://support.xbox.com/en-us/pages/xbox-360/how-to/update-xbox-360/system-updates.aspx. Let me know if it works. Also if you cant do this there is a way to update through burned cd or flash drive both of which you can find instructions form the same site but xbox live is much faster and easier.
Apr 13, 2011 | Microsoft Xbox 360 Console
Heey i just bought a new xbox 360 slim 250gb and my network connection is fine but when it prompts me the update the update keeps failing and ive tried everything on xbl support but nothings working please...
Hey there,
This is likely a problem with your network connection in which it is unable to connect to XBOX Live. I would need to know the make and model of your router to go into further detail on this, so all I can provide you with is some general information to help resolve the issue.
Go to this website and select the router you are connected to: http://portforward.com/
Skip the Advertisement if it pops up, then select Xbox Live 360. Follow the instructions to set up the proper ports for your router.
If that doesn't work, try plugging in your 360 with an Ethernet Cable, directly to the modem, then download the update.
Let me know if that works :)
Jan 29, 2011 | Microsoft Xbox 360 Console
I need to know how i can get xbox live with the ethernet cable
1.Simply connect your xbox 360 to the internet with the Ethernet cable. Go from the xbox 360 to a router or directly to your internet source; internet modem or internet cable if you have fiber optic internet connection.
2. Turn on your xbox 360 and go to the xbox live tab.
3. Go wher it says Join and follow instructions.
You can put your credit card info. or buy a prepaid xbox live card
May 28, 2010 | Microsoft Xbox 360 Console
Xbox nat setting
If you have a firewall or network hardware, such as a router, you might need to make a configuration change in order for your Xbox 360 console to communicate with Xbox LIVE. This configuration change is sometimes called “opening ports” or "port forwarding."
Xbox LIVE requires the following ports to be open: • TCP 80 • UDP 88 • UDP 3074 • TCP 3074 • UDP 53 • TCP 53
Mar 07, 2010 | Microsoft Xbox 360 Controller
We have just found out we need a download to run x box 360 pro?
Hi micklivesay
you should be able to play yor console normally
without updating
but if you really need to update you NEED to be Connected to Xbox live
to download simply connect to Xbox Live and You can download it just by starting up your console
xbox will soon be releasing a download so all ofline members can update by using a CD-R.
Dec 18, 2008 | Microsoft Xbox 360 Console
Xbox 360 update
i,m assuming that you have a hard-drive, and this is a premium x-box 360 ?
it,ll only work with the hard-drive attached.
If you go to xbox.com theres all the information you need there.
you have 3 options. 1 is to update via x-box live.
2. you can download the file, and burn the image.
3. order a disk via mail.
If you have any problems, obtaining the CD. please leave me your e-mail address here.
And i,ll send you 1 FREE Of charge.
If you don,t have a hard-drive. thats definately the problem.
****Don,t forget to rate this solution accordingly****
Our status as experts on Fixya. are dependent on good ratings.
Any further problems, please feel free to contact me.
Mike @ Compurepair.
May 01, 2008 | Microsoft Xbox 360 Console
Xbox not reading game
I don't know if this will help anyone, but I have tried a variety of things that occasionally have worked. Eject disk and pop it back in and then restart 360. Sometimes may require doing this a couple of times. If that doesn't work, try unplugging that thing in back with the orange light and replug it. Or simply, as it worked for my brother, just turn the 360 off and unplug the orange light thingy and don't play again until maybe a week or month, etc. He unplugged it for about 3 weeks and then it worked perfectly again. Sometimes the 360 just needs a little break. Even though this may be impossible for most to leave it alone for even a day, but its either you or your 360. make it live again!
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
116 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
