Question about Belkin Computers & Internet
I'm trying to connect my Belkin N1 wireless router to my SKY broadband to replace my netgear router to improve the wireless range. I've tried the usual websites and extracted the username and password for the netgear router, but it still doesn't recognise the ISP setting at the end of the set-up process. I have used the following settings: username: 12 digits alphanumeric@skyds1 password: 10 digits alphanumeric VPI: 0 VCI: 38 Network type: PPPoA It appears possible to do from the various help websites, but after days of frustation I'm not so sure! Any suggestions would be much be appreciated
  • 257 Answers
Hi, I think you are trying too hard. If your netgear worked so will your belkin. Remove the belkin and put your netgear back on, make sure it works OK. Remove any of the belkin software you install under add/remove settings and in the network connections. Enter the netgear address into your browser and you can view any of the settings. You don't say what your computer OS is but the belkin wizard is really good. So now put the belkin back on let your OS find the hardware and when it does it may ask if you have the disk that came with it, install the program. The only information you will really need is the login information from your isp. Good Luck!
Posted on Feb 08, 2009
  • 744 Answers
Hi do u have the installation disk wid u??
  • 679 Answers
You have to contact to your isp for that issue.
Thanks
    Brigadier General:
  • 3,614 Answers
have you try resetting the device first of use.?
try to reset the device on factory settings.
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Setting up a w.less repeater using an old w.less b.band router
Temporarily plug in wire network cable into Dell and log into Dell.
1. Set wireless up the same as the Belkin. Save these settings.
2. Set WAN to "Static IP Address and give it an address about 25 higher than Belkin. (Belkin 192.169.0.1 - Del 192.168.0.26). Save these settings.
3. Disable DHCP and Save these settings.
Exit web browser and disconnect network cable. Restart your complete system, first the Belkin, then the Dell, then your computers.
This way, the Belkin is running and able to assign IP addresses to all that start after it.
Jun 11, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Wireless connection
i can't connect wireless int
Feb 01, 2009 | NetGear DG834G Router
Connection problems
Sound like the least road of Pain is to Return it and write down the new code you need to know.
There may be other solutions, but is support is not helping, get another brand. It should not be that hard.
I might suggest Linksys / Cisco
E
Jan 21, 2009 | Belkin N1 Vision Router
Belkin w/range extenter question
you can use as many as you want, since they just find a signal and amplify it. using more than one shouldnt cause any problems
Nov 07, 2008 | Belkin (F5D8231-4) Wireless Router...
Adsl wireless n modem router
regard to G it can transfer signal up to 54mbps  and nano tech have even come to point now as its 130mbps more that ethernet cable but it depends on the factors such as heavy wall , and other interference such as sky , heavy speakers  microwave , bulgrar alarm so on with network booster like netgear it works 2 boost the wireless signal, regards 2 comparision 1 has advantage over the other
Oct 20, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Low signal from my wireless adaptor / router
Have you tried connecting the laptop in a different wireless network? Try changing the channel in your router and you may also upgrade the firmware of your router.
Oct 04, 2008 | NetGear WGR614 Wireless Router
Major issues
I had the same problem. My Belkin N1 Router was constantly dropping the WiFi connection (every few minutes). I tried several solutions I found on different forums:
Change the channel selection from Auto to a specific channel -- I tried all 13 channels, but no improvement.
Update the firmware to the latest (Beta) version -- still no improvement.
Finally I enabled "Protected Mode" and the connection seems fine now.
Hope this helps, and good luck!
Apr 16, 2008 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
44 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
