Question about Whirlpool Calypso GVW9959K Top Load Washer
Leaves white clothes gray
I wash a load of white clothes some look not so white and some are gray
    Scholar:
  • 105 Answers
Many of the machines are having a similar issue I am trying to find a resolution to fixing this, there are two issues. First Whirlpool has just recently identified a problem with premature bleach dispensing. Another dispensing problem I had is that fabric softener had to be diluted otherwise it would not wash out of the dispenser. And finally, the fabric softener dispenser would still hold a small amount of water after the wash cycle completed.Removing the top of some washers I have found that there is often a lot of stainless steel polish residue around the rim of the machine - which should have been cleaned away before the machine was shipped from Whirlpool. The gray, oily residue was not visible without removing the top of the washer. Knowing now what has caused the dark gray streaks on many peoples laundry.
Posted on Feb 11, 2009
I purchased the Kenmore Elite washer approximately five years ago. I have had no problems with it operating. However, since purchasing this washer I have ruined almost everything white I owned and avoid...
There has been many reports of complaints regarding this problem and it was found out that the gray spots on white clothing are caused by the fabric softener. The Kenmore Elite is a "highly efficient" machine that it uses very minimal amount water when washing and rinsing. The minimal use of water results in the fabric softener not being diluted completely and eventually makes gray spots on white clothing. The ridiculous solution to this problem, as Sears "advised" is not using fabric softener for white clothing. But you may also try putting the fabric softener in a small plastic bowl just enough to hold it and place it inside the machine prior to the final rinse. Using only the suggested amount of detergent and avoiding the use of detergent powder with speckles reduces the possibility spot occurrences in your while clothing.
Aug 27, 2010 | Kenmore Elite 45986 Front Load Washer
My machine is leaving white marks on my coloured clothes this has happened now and again but lately its happening in all my washes I'm having to throw loads of clothes can't afford to go on like this!
It sounds like you have some type of scum left over from the loads you are doing. Spray around the tub with a good tub/tile cleaner, then fill it with water and pour in several cups of white vinegar. let it sit for a few minutes then let it run through a wash cycle with no clothes. It should clean it out.
You might rethink whatever products you use because if too much soap or alkaline it could be leaving behind residue.
Jun 18, 2010 | Neff W4380X1 Front Load Washer
Dryer is leaving marks on my clothes. At least I think it's the dryer. It could be the washer. It's just leaving little gray lines, about an inch to an inch and a half long, in various places on my...
The dryer is prone upon leaving marks on clothes. The felt band surrounding the drum has worn out. Replacing this felt band will keep your clothes streak free again
Apr 28, 2010 | Washing Machines
All our whites are now greys washing with our GE WCVH6260
graying of clothes is usualy caused by / serveral things . too much soap / washer not rinsing properly / and gas dryers. change your dergt. use one with a bleach in it . and use 2nd rinse ( cold water ) make sure washer drains wash water completly . do this by cking the drain pump clean out .. if cloged it will slow the drain cycle and you will be rinsing with the wash water . also use H E dergt. . if dergt is still in clothes when drying this turns nylon yellow and whites gray .. .also seperate colors . and whites .. **** ..
Feb 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
White Clothes Turning Gray FAST - Maytag Performa Top Loader
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 24, 2009 | Washing Machines
Washer is turning my white clothes gray
Oil from transmission is a good possibility. The machine is still young but sounds like you do a lot with the washer. Better have a friend that don't mind looking it over, make sure that's oil and go from there!
Feb 02, 2009 | GE Energy Star WCVH6260F Front Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Oct 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
TROMM ultra capacity washer water levels
these machines are mean on water and you can open the door after wash starts
use good quality soap powder that suits front loaders and always wash at 40 deg or above
the black stuff is body fat that is still in machine called scud to me
also if you use conditioner in rinse cycle stop using that
it can cause same problem
Jan 28, 2008 | LG WM-1832C Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
182 people viewed this question
Dan Webster
Dan Webster
Sal De
