Question about Sony Playstation 3 (PS3) Console
Ps3 no display
When powering up the ps3 can only see a wavy thick stripe across the screen. There is also a luminated trash can light on the back of the console???? What is the repair for this issue?i have this problem also i start it up and it doesnt load anything just that wavy line
  • 217 Answers
Hold your finger on the power button as you turn on the ps3, it will beep once when you turn it on and again about 5 seconds later. It basically resets the display settings to default which fixes the no display issue.
Posted on Feb 08, 2009
  • 679 Answers
First of all check all cables and connections.
and let me know for further assistance.
Thanks
  • 744 Answers
Hi.. i think this solution will suit u.All you have to do is hold the turn on button hold it for a few secs remember it will take a few times but it works Again it will come up with a few options do restore system, now you will lose all your saves and you will have to sign up for ps3 network again...
pls rate me!!
    Brigadier General:
  • 3,614 Answers
HI THERE,
  • micromaster
    micromaster Feb 08, 2009
    better check all connections, reset the unit as well
  • Sony Master
  • 19,396 Answers
Unplug the playstation power cable to reset.
Check PS display definition.
  • Ginko
    Ginko Feb 08, 2009
    Try first unplugging the PS from power for five minutes or so. This is called hard reset , and reset the PS to factory by draining power.
    When connect PS back, ensure that there is no disk inside PS.
    If you still get the problem, try connecting the PS to a different HDMI input (always plug/unplug HDMI cable with PS and TV off, or you can damage TV).
    Try going to TV HDMI configuration menu , and re-configure HDMI devices.
    Try also setting both TV and PS display settings to 720 dpi, if that work, eventually set back to 1080 afterward.
Will not play games or dvds- menu screen will not come up the screen just shows the red wavy lines not the blue like it is suppose to
1- Disconnect the PS3 from the internet.
2- Turn the standby switch off so the red light turns off too, then you turn the system back on
3- Then place your finger on the power button for a total of 4 beeps to access the recovery menu. It might not work on the first attempt but it will on the second.
4- The display will instruct you to connect your controller to the PS3 and press the enter button. A list of menus will appear on your display. The choices are as follows: Restart System, Restore Default Settings, Restore File System, Rebuild data base, Restore PS3
5- Select Restore Default Settings.
Nov 23, 2009 | Sony Playstation 3 (PS3) Console
When powering up the ps3 i can only see a wavy thick stripe across the screen?? what can i do?
Hi, this sounds like a problem with the TV cable (from the ps3 to the TV), this is a common problem that causes bad picture on the TV, try to replace it.
Hope This Helps
Muzzi_123
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
When I switch my ps3 on, there are just wavy lines across the middle of the screen, the icons do not appear and games will not play
If you have componite connetion and have played in hdmi than you need to switch the connection back and you will see the screen. Set it to auto detect, go to video settings
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not start up. no display
sounds like the resolution is not set correctly on your tv or your ps3 settings. make sure they both are set to 720i to start, if you have a HDMI cable, that should be the min resolution your tv will do.
Find out the max resolution your tv can do, and set the ps3 to output that.
720i is a good place to start.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
PS3 working but no display. Originally wavy
im having this problem right now, when its on press and hold the power button until it turns off( the light is red) then hold the power button for 1 beep then u'll hear 2 beeps then u'll go to a menu where it asks you to plug in a controller but this is where im stuck so you can try experimenting if u want but hopefully someone will find a proper solution
Apr 07, 2009 | Sony Playstation 3 (PS3) Console
Ps3 from wavy screen to blank screen at start up.
Quick call and its fixed.... Whilst the PS3 is in stand by (red light on) press and hold the on button. Wait until it peeps slowly three times then take the finger off the button. This opens up a factory reset. Work from the top down and see which one fixes your PS3. For me it was a full reset, but at least it keeps your updgrades. :o(
Mar 14, 2009 | Sony Playstation 3 (PS3) Console
Black stripes
It could need a video head adjustment. You can take it to a camera store and they should be able to fix it for you.
Dec 23, 2008 | JVC GR-DV900AG Mini DV Digital Camcorder
Playstation 3 wont load up
this problem happens when the hd is already faulty.got this same problem before,i replace the hd and my problem is dissolved.try it.
Dec 22, 2008 | Sony Playstation 3 (PS3) Console
Ps3 no display
Ok i have good news and bad news. The good news is you don't have to send it to sony for 150 bucks, you can fixs it and i will tell you. Ok it could take a few times but all you have to do is hold the turn on button hold it for a few secs remember it will take a few times but it works.Now the bad news it will come up with a few options do restore system, now you will lose all your saves and you will have to sign up for ps3 network again (if you had it) bu i does save you a 150 bucks right. Well i hope this helps it did for me.
Nov 16, 2008 | Sony Playstation 3 (PS3) Console
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
