Question about Toshiba Satellite A100-S8111TD Notebook
Slow Start Up and run Speed on a Satalite Laptop
This machine was working fine on Monday, two days later it is running like molasses. When I try to load any programs or web pages it can take up to 10 minutes. As of now my cup usage is at 12% and available memory is 211300k.
  • Chris May 11, 2010
    Do you have anti-virus / anti-spyware software installed? Has it been kept up to date? Which one(s) are you using?
    President:
  • 1,902 Answers
Virus, try to download malware anti virus, and it will check for any viruses, that will make your computer run slower then molasses on a cold day
Posted on Feb 08, 2009
Blower mtor on 1997 Chevy 1/2 ton 4wd runs real slow or not at all,some times it speeds up to near normal speed.
Yes, the blower motor is bad, replace it. This is exactly what you say, brushes are worn.
Dec 04, 2013 | Cars & Trucks
Last year I changed the machine engine (PfaFF 1222 E). I noticed immediately that the machine sewed too slow and I thought it was a problem of the kind of engine the repairer had put into the machine. But...
If the machine did sew fast the the replacement motor, then the problem might be that the machine is getting gummed up somewhere. Pull off the top cover, remove the 5 screws from the bottom of the base plate, (4 large screws, 1 small screw), remove the base plate remove the 1 screw from the bottom of the free arm cover. Now you can see most of the moving parts. Spray a little WD 40 on all the areas that you see metal to metal rubbing together, both on the bottom side of the machine and the top side. Don't flood the machine and stay away from the motor area. Plug the machine in, lay it on it's back and run it full speed, or at least till it runs full speed. After you free it up, blow out the machine with compressed air, and reoil with tri flow all the areas again. Run the machine again, and you've started your own tail gate repair shop.
May 05, 2011 | PfaFF Sewing Machines
My laptop running slow and net browsing very slow my configeration windows7 original ,320 gb HD,3GB memorry
There are several reason for the computer to be running slow for the start please try restarting the computer to safe mode with networking (Steps given below) and check if your browsing speed is better. If your internet browsing speed not better in safe mode with networking then you need to contact your ISP to complain about slow speed.
If it is working fine in safe mode, then some of the software (example: Antivirus / Internet Security / Firewall) is slowing down your computer. Please try removing it. Also try reducing the color scheme, use a non aero theme and see if your comptuer is working fine. If so your processor is not able to take the load of windows 7 visual effects aswell as other programs running in the background at the same time
Mar 02, 2011 | Computers & Internet
My sewing seem to run to slow how to make it go faster
Do you have a lever below the digital stitch window? That's where you change the speed. There are 3 speeds on this machine ranging from "slower than frozen molasses" to "autobahn" ... When you try the different speeds, you'll see what I mean!
Jul 19, 2010 | Brother CS6000i Computerized Sewing...
I have a trendnet kvm switch and the one computer runs slow as molasses and the other works just fine .
On the one that isn't working properly, try and see if the video card driver for your model of card has been installed. you might find it is only using Default Video Adapter driver, you can find out by going to (in XP) - Display in Control Panel, goto Settings, Advanced, Adapter.
Jul 12, 2010 | Trendware (tk206i) 2-port KVM Switch
My laptop freezes after start up. I start the computer and it runs normal until right after log in. I have roughly 30 seconds to 1 minute after logging in before the fan turns on and the laptop starts...
when was the last time your computer worked fine? run system restore and choose a restore point prior to when the issue started. if no restore point is available, open run and enter 'msconfig', go to startup and disable unecessary startup programs. also open the prefetch folder and delete its contents. then restart your system. if it's still slow, i suggest you backup your files and reinstall windows. make sure that you operate the laptop on a flat surface to avoid any ventilation blockage. hope it'll help. good day. =)'
Dec 07, 2009 | Computers & Internet
My satalite laptop found no audio device
start "windows audio" from running "services.msc" from run dialog box, if it doesn't work try uninstalling and installing sound drivers.
Sep 19, 2009 | Computers & Internet
Slow Slow Notebook (Acer Travelmate 290 CL51)
Well, upgrading the ram COULD help, firstly before spending any money run a disk defrag by right clicking the drive and going to tools, also note that their may be viruses on the computer so downloading AVAST and running the preboot scan would help ALOT. the easiest way is to run a recovery but you would need either the recovery discs or a fresh windows install disk (preferably xp) that should do the trick my friend, if you have any issues please let us all know
Jan 24, 2009 | Computers & Internet
Speed of laptop is very slow
Try and remove unnecessary software, and scan for spyware.
You can check under
Start->run->
msconfig
Stratup
What you have running
Nov 01, 2008 | IBM ThinkPad T30 2366 Notebook
Toshiba Satellite A100-S8111TD Notebook Logo
140 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
