Question about Kenmore 73952 Gas Dryer
Kenmore 400 series electric dryer
Can I change a 4 prong to a 3 prong plug and if so how
    President:
  • 1,902 Answers
Are you wanting to do this because of your plugs at your house? If so, just go to Radio Shack or Home Depot and buy a adapter, a lot safer then doing the switch
Posted on Feb 08, 2009
    President:
  • 2,559 Answers
  1. Remove safety plate (usually attached only by 1 or 2 screws)
  2. Remove old cord and restraint with a hand or cordless drill.
  3. The restraint is the collar that fits tightly around the cord to hold it firm to the dryer.
  4. Connect the center wire of the 10/3 cord to the center silver terminal. Turn screw in firmly but not too tight.
  5. Now you have two wires remaining which are attached on either of the two terminals beside the silver terminal. It does not matter which wire goes on which terminal, as both wires are hot. Screw in firmly.
  6. From the outside of the dryer, you need to slide the tab end of one of the collar halves into the 10/3 cord wire hole. Do the same with the other half of the collar,easily draw the two halves together to tighten against the cord .
This is the 4 wire view Kenmore 400 series electric dryer - 43fa7d5.jpg This is the 3 wire view
Please rate this a fixya
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Posted on Feb 27, 2009
rylee_smith
  • 8619 Answers
SOURCE: kenmore 400 electric dryer, installing a 4 wire
Hi
Thanks for using FixYa. Please check this picture which will sort out everything for you:
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 02, 2010
Changing 4 prong plug to 3 prong plug on a Kenmore ultra fabric care electric dryer, where is the metal strap?
The metal strap connects the neutral to the housing ground connection when using a 3-prong cord. It may have been removed when the 4-prong cord was installed.
Feb 17, 2017 | Kenmore Dryers
Or all blower motors on electric kenmore 80 series 220 or 110 current
Speaking of these United States, here's how that goes.
In this country, dryers are called 220, but they are really 110 twice!
So, on the back of the dryer is a plug with 3 or 4 prongs.
( hope you can get this from my description. )
On a 3 prong plug, the two "slanted" prongs are each hooked to 110 volt p service.
The "L" shaped prong is a ground.
If you have a 4 pronged plug, the two flat straight prongs are 110 volt each, and the "L" shaped and the round prong are both grounded.
FYI: Each of the 110 volt wires has a different function. One powers the motor, the other the heating element.
Be Blessed.
Jan 23, 2013 | Kenmore 659 Electric Dryer
Have a kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what? Can we wire our 3 prong plug from the other dryer to the four wire dryer? And how would we wire this way...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Aug 26, 2010 | Kenmore 400 6942 Dryer
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Jul 06, 2010 | Kenmore Dryers
How do I wire a 3 prong plug on a kenmore 400 series dryer
Jun 22, 2010 | Dryers
Kenmore 400 electric dryer, installing a 4 wire dryer to a 3 prong electric plug, now what?
Hi
Thanks
Rylee
Jun 02, 2010 | Kenmore 400 6942 Dryer
We have a Kenmore 70 series Electric dryer and it heats just fine and stays hot, air flow is good,(checked), however the clothes are not getting dry. My husband replaced the cord to the outlet from a 3...
Did the dryer get clothes dry in your old home with the 3 prong plug?
If so, id put the 3 prong plug back on it, and switch to outlet to a 3 prong...
Jul 10, 2009 | Kenmore 63942 Dryer
Feb 15, 2009 | Kenmore 62802 Electric Dryer
Kenmore dryer cord change
if you have the new plug the wiring is the same just without the green wire....just leave it off
Jun 24, 2008 | Kenmore 84832 Electric Dryer
Kenmore 73952 Gas Dryer Logo
1,300 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
