Question about Whirlpool AWM8143 Front Load Washer
FAULT CODE F11
AWM 8163 WASHING MECHINE FAULT CODE F11
NOT RINSE AND DRY
  • 107 Answers
F-11 like a Kenmore means communication error between the motor control and the main control. Check connections, unplug and replug computer connections and see if problem persists. I've seen cases where either board or even both can be bad.
Posted on Mar 14, 2009
I have a top lg fuzzy logic washing mechine, it stops at rinse position , display lights , gear are all working. whats the fault please ?
this usually happens when the water pump or the hoses are clogged and it cannot drain, it stops there and does nothing
Feb 10, 2015 | LG Washing Machines
Hi i have whirpool awm 8900 and i have fault f11 what is this?
In your service manual it states for the f11 code
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
globul1a.gif Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU) globul1a.gif Check the Drive system for any worn or failed components globul1a.gif Check MCU globul1a.gif Check CCU globul1a.gif Check Motor globul1a.gif Check Wire Harness
If you have any further questions message me back I await your reply Thanks again Rick
Jun 20, 2011 | Whirlpool AWM8000 Front Load Washer
Maytag MAH8700 AWM will not spin during rinse cycles
As you said in the question you are washing machine need to get services during rinse washing machines should spin.Try selecting only rinse option only.If it does not spin means just services it will be fine.Thanks for you are question.
Jun 17, 2011 | Maytag Washing Machines
During the washing process the washer stops and the code F11 comes up. I have a Kenmore Elite He3t. Modle # 110.42926201
Hi, The F11 fault is actually described in the tech sheet as a "Serial Communication Fault" involving the MCU (the washers computer) and the DC Drive assembly that runs the motor. If you are not familiar with a DC drive, it is simply a controller for the motor that varies the voltage to the motor to change speeds. This is so the washer can crawl slowly to tumble your clothes as well as spin at the ridiculously high speeds using the same motor. I would argue that "Jay's" is wrong about the door latch - there is a different specific code for that malfunction (I think it flashes F and DL). I wish it was the door lock - that's cheap, unfortunately, I think you are in for a MCU @ ~$200.
Take care
Jun 23, 2010 | Washing Machines
Whirlpool AWM 5080 stops during cycles
Sound like could be faulty pump however you need to make sure no
Could be pump at fault 1st you need to make sure no coin stuck in there ...
Mar 31, 2010 | Whirlpool AWM6100 Front Load Washer
WHirlpool 1600 Washing Machine AWM 8163 model. The letter ''P'' appears on the display screen and the washing cycle will not complete. Tried the other cycle and unfortanetly the motor sounds but the...
Removed the top cover of the machine and cleared out the hoses and the plastci chamber, which was full of limescale which had built up and also unscrewed the front outlet cover, again that had become clogged up with alsorts debris. Now it works a treat.
Dec 12, 2009 | Whirlpool Washing Machines
My Whirlpool AWM 8163 is flashing FP (orPF). Anybody have any ideas? Many thanks
You need to clean your filter once you have drained the water out look in the hole you will see a little impellor there might be an object loged in
Sep 16, 2009 | Whirlpool AWM8163 Front Load Washer
WASHING MACHINE awm 8163
The door will never open unless the timer is in the off position. Sometimes there is an additional time delay before it will release. If someone tried to force the door they probably bent the latch release. It needs to be replaced.
May 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
May 23, 2007 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWM8143 Front Load Washer Logo
396 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
