Question about Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook
Disable network access to registry!!
Can you tell me how to disable netwrok access to registry and also how to disable administrative shares in dell inspiron 1525 laptop.
  • richin29
    richin29 May 29, 2009
    i am having vista home premium os
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    What operating system are you running on your laptop?
    Problem Solver:
  • 7 Answers
Are you running winxp os? if so go to control panel click on administrative tools then on services, look down the list until you see what your looking for and disable it. I hope this helps.
Posted on Feb 15, 2009
Hp error codes
1. Open your Network and Sharing Center. You can do this through the control panel or by clicking on the wireless (bars) icon in the task bar.
2. On the top left of the Network and Sharing Center page, click on Manage Wireless Networks.
3. A list of Networks appears. Either move your wireless network to the top of the list, or delete the additional networks so that only your main wireless network remains.
The "Limited Connectivity" sign should now turn off and you should be connected.
OR
1. Disable the IP Helper service: 1. Hold the Windows key and type R, enter "services.msc" (without the quotes) and press Enter
2. Scroll down to the IP Helper service, right click on it and select Properties
3. In the dropdown box that says "Automatic" or "Manual", set it to Disabled and then click on "Apply"
4. Then click on "Stop" to stop the service from running in the current session
5. Click OK to exit the dialog
2. Disable the DHCP Broadcast Flag:
http://support.microsoft.com/default.aspx/kb/928233
Important: This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
http://support.microsoft.com/kb/322756 (How to back up and restore the registry in Windows)
Windows 7 cannot obtain an IP address from certain routers or from certain non-Microsoft DHCP servers
To resolve this issue, disable the DHCP BROADCAST flag in Windows 7. To do this, follow these steps:
1. Click Start, type regedit in the Start Search box, and then click regedit in the Programs list.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
2. Locate and then click the following registry subkey:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\{GUID}
3. In this registry path, click the (GUID) subkey that corresponds to the network adapter that is connected to the network.
4. On the Edit menu, point to New, and then click DWORD (32-bit) Value.
5. In the New Value #1 box, type DhcpConnEnableBcastFlagToggle, and then press ENTER.
6. Right-click DhcpConnEnableBcastFlagToggle, and then click Modify.
7. In the Value data box, type 1, and then click OK.
8. Close Registry Editor.
By setting this registry key to 1, Windows 7 will first try to obtain an IP address by using the BROADCAST flag in DHCP Discover packets. If that fails, it will try to obtain an IP address without using the BROADCAST flag in DHCP Discover packets.
About the second issue that your computer is not shutting down properly, you can perform a clean boot and check which application is causing this issue.
Perform the following steps to perform a clean boot:1. Click Start, type msconfig in the Start Search box, and then press ENTER.
User Account Control permission.
If you are prompted for an administrator password or for a confirmation, type the
password, Or click Continue.
2. On the General tab, click Selective Startup.
3. Under Selective Startup, click to clear the Load Startup items check box.
4. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
5. Click OK.
6. When you are prompted, click Restart.
7. After the computer starts, check whether the problem is resolved.
If the issue is resolved check which third party is causing the problem, referring the link given below:
http://support.microsoft.com/kb/929135
Also you need to uninstall and reinstall the problem software on your computer.
Reset the computer to start as usual
After you have finished troubleshooting, follow these steps to reset the computer to start as usual:1. Click Start, type msconfig.exe in the Start Search box, and then press ENTER.
2. If you are prompted for an administrator password or for confirmation, type your password, or click Continue. On the General tab, click the Normal Startup option, and then click OK.
3. When you are prompted to restart the computer, click Restart.
Aug 03, 2014 | HP ProBook Computers & Internet
Tip
Windows Xp: Speed Up Your, Speed Up Your Network and Internet Access
Increasing network browsing speed
Does your computer slow down when you browse your local area network and connect to other computers that are sharing data? One of the most common causes of this slowdown is a feature of Windows Explorer that looks for scheduled tasks on remote computers. This effort can take some time on some computers and can really slow down your browsing. The window with which you are browsing the network may appear to freeze momentarily, as the system is waiting for a response from the remote computer.
Windows XP: Speeding Disk Access
Although this problem is a complex one, the solution is very simple. Instead of having to wait for the remote scheduled tasks, which is useless information to anyone who is not a system administrator remotely configuring scheduled tasks, you can disable this feature.
In order to do this, you will have to change the System Registry and delete a reference to a key so that this feature will not be loaded. To do this, follow these steps:
1. Open up the Registry Editor by clicking the Start Menu and selecting Run. Then type regedit in the text box and click the OK button.
2. Once the Registry Editor has loaded, expand the HKEY_LOCAL_MACHINE key.
3. Next, expand Software and then Microsoft.
4. Locate Windows and expand that as well.
5. You will want to be editing the main system files, so expand CurrentVersion.
6. Because this feature is a feature of the Windows component known as Explorer, expand the Explorer key.
7. Next, you will want to modify the remote computer settings, so expand the RemoteComputer key and then expand the NameSpace key to show all of the features that are enabled when you browse to a remote computer.
8. In the NameSpace folder you will find two entries. One is "{2227A280-3AEA-1069-A2DE-08002B30309D}" which tells Explorer to show printers shared on the remote machine. The other, "{D6277990-4C6A-11CF-8D87-00AA0060F5BF}," tells Explorer to show remote scheduled tasks. This is the one that you should delete. This can be done by right-clicking the name of the key and selecting Delete.
Tip:
If you have no use for viewing remote shared printers and are really only interested in shared files, consider deleting the printers key, "{2227A280-3AEA-1069-A2DE-08002B30309D}", as well. This will also boost your browsing speed.
Once you have deleted the key, you just need to restart and the changes will be in effect. Now your network computer browsing will be without needless delays.
on Feb 20, 2010 | Computers & Internet
I can't get my Netgear router to work on my new laptop with Windows 7. I can't connect to the network. Netgear doesn't show up at all on my laptop.
Windows 7 has various changes from previous operating systems, you need to disable the built in firewall to establish contact.
You also need to go to the netwrok and sharing centre and choose to setup a network.
Apr 11, 2010 | NetGear WGR614 54Mbps Wireless Router...
Wireless lan disabled. where is button to enable
for windows XP - go to control panel - network connection - eneble wireless LAN
for windows vista - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
for windows 7 - go to control panel - network and connect sharing - manage netwrok connection - right click wireless icon then enable
Mar 28, 2010 | HP Pavilion dv5tse Notebook
File sharing problem after installing Netgear DG834G ADSL/Wireles
- Run the Windows Network Wizard in each computer on the network.
Mar 10, 2009 | NetGear DG834G Router
Windows XP Does Not Allow Inbound/Outbound Connections
some malware has restricted access to administrative tasks,
try to download SPYBOT
check your system +-20 min
Nov 26, 2008 | Dell Microsoft Windows XP Home Edition
Access denied to network to laptop
Disable all firewalls, both on laptop and on computer that shares the printer.
Ensure that laptop and desktop sharing the printer are both on same Domain or Workgroup.
If this does not fix it, call back the Geeks and thell them to acces the router configuration, and configure router internal firewall.
Put both laptop IP and computer sharing printer IP in the range of thrusted IP on router settings.
Sep 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
File sharing
it is possible
If you have multiple computers in your home and they are connected through a home network, you can share files among your computers. That means you no longer have to copy files to a floppy disk or USB flash drive to transfer them to another computer. Once you configure your computer to share files, you (or another user with the appropriate permissions) can, by using Windows Explorer, open them from other computers connected to the network, just like you’d open files that are stored on a single computer. You can also choose to have folders visible—but not modifiable—from other computers on the network.
To share files on your computer with other computers on a network, you need to:
Share a folder on your computer. This will make all of the files in the folder available to all the computers on your network (you can’t share individual files).
Set up user accounts on your computer for everyone who needs to connect to your shared folder. If any of the accounts are Limited User accounts (unless an account is a Computer Administrator account, it is a Limited User account), follow the steps in Set permissions for files and folders to enable them to open your files.
To access shared files that are on another computer on your network, you need to:
• Connect to the shared folder from other computers on the network. This procedure is described in Map a network drive.
Note: By default, file permissions only allow your user account and administrators on your local computer to open your files, regardless of whether a person is sitting at your keyboard or at another computer. It may help to keep these three things in mind when setting up file sharing:
• Files have user permission settings.
• Every computer has its own user database.
• Some accounts are administrator accounts and some aren’t.
Configure your computer to share files To share a folder on your computer so that files stored in the folder can be accessed from other computers on your home network
1.
Log on to your computer as an administrator. For more information, see Access the administrator account from the Welcome screen.
2.
Click Start, and then click My Documents.
68599-click-my-documents.gif 3.
Right-click the folder that you want to share, and then click Sharing and Security.
68599-click-sharing-and-security.gificotip.gif Tip: If you want to share your entire My Documents folder, open My Documents, and then click the Up button on the toolbar. You can then select the My Documents folder.
4.
If you see a message that reads, As a security measure, Windows has disabled remote access to this computer, click the Network Setup Wizard link. Then follow the instructions in How to set up your computer for home networking. On the File and printer sharing page of the Network Setup Wizard, be sure to select Turn on file and printer sharing. If you do not see this message, skip this step and go to step 5.
68599-click-network-setup-wizard.gif Note: If you do not see the Network Setup Wizard link or the Share this folder on the network check box, your computer probably has Simple File Sharing disabled. This is a common change made to computers used for business. In fact, it happens automatically when a computer joins an Active Directory domain. You should follow these instructions to share a folder instead.
5.
In the Properties dialog box, select the Share this folder on the network check box.
68599-click-share-this-folder.gif 6.
If you want to be able to edit your files from any computer on your network (instead of just being able to open them without saving any changes), select the Allow network users to change my files check box.
68599-click-allow-network-users-to-change-my-files.gif 7.
Click OK.
68599-click-ok.gif Windows Explorer will show a hand holding the folder icon, indicating that the folder is now shared.
To connect to the shared folder from another computer, follow the steps described in How to map a network drive.
Note: By default, only you and other people with an administrator account on the computer sharing the folder will be able to open your files. To limit access of specific users with an administrator account on the computer sharing the folder, read How to set permissions for files and folders.
Aug 14, 2008 | Microsoft Windows XP Professional
Install problems
Hi are you trying to install the Router config software . Check to see the Network access connectivity - if its restricted or limited access , if it is so rectify this and login as administrator , also ensure that the IP address or name of your comp is unique.
May 06, 2008 | Dell Inspiron E1505 Notebook
Networking problem
Make it sure if the user you used in the laptop is administrator right because you need the administrator right to access some network computer. check also if the desktop share folder is share with full access it maybe the right is read only.
Apr 23, 2008 | Dell Inspiron XPS M140 Notebook
Dell Inspiron 1525 Laptop Jet Black (15.4" Wide Screen with true life, built-in Webcam, Intel Pentiu... PC Notebook Logo
1,519 people viewed this question
Alun Cox
