Question about Canon Office Equipment & Supplies
Printing problem when i started printing from cannon2230 machine then machine show instruction that is recieving priting but just give a error check network connecion pls just solve my problem
  • 26 Answers
Hello
try to "OFF-ON" it
Posted on Feb 08, 2009
Always get error message in printing manager.
There is too little information to allow us to diagnose this problem. And by now, we suspect you have resolved it, one way or another. For others who may have similar problems, and not sure what info to provide, give us a call. We're Hanover Technical Sales, Inc. Kroy's premier dealer. Call (757) 357-2677 and ask for Don. Indicate that you got this phone number from FixYa.
Oct 10, 2014 | Kroy K 4350 Printer
Why cannon ip3000 can't print in only black and white although I choose grey scale priting?
Not sure of the QUESTION..? Do you want to print colour or black and
white..? Anyway,try this, bring up image , at top left click on Fix , at top
right click on Auto Adjust then go down to Adjust Colour click on and
hold Saturation Slider move to left to remove colour ,right to add colour
go to print and it should give you a black / white image. Remember to
return image back to original colour or image will return to file in b/w
hope this works for you..goodluck...T.C.
Mar 31, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
Have an HP Laserjet M1319 Fax Machine. Fax line appears to be working but I can't send or receive faxes. It shows"receive" when they come in, but won't print them up.
Sometimes these machines will give you automatic messege "Recieve."
If this is only plugged in the fax machine, can you hear the machine dialing or hear the machine recieving a dial tone?.
Some machines have the audio sound turned off, so it is quiet when the machine is doing fax transmissions to limit the noise.
If you can turn it on you can make this eaisier to resolve. If it is on then you can make this more simplier.
Make sure the settings are set right, Junk mail turned off, set up the fax answer mode to print, and not store, check to see if the auto confirmation can be turned on. When this mode is turned on for this process at least you can get a print out on the fax copy, some will give an error messege.
If you can put an analog phone into the fax line, use another phone to call that number and see if it rings. This will ensure the phone line is working well.
If this line has a phone line converter, digital to analong, this may cause some of the issues. More and more people are trying to use the internet as their phone line as a fax.
I would like to know if any of this resolved the problem. There are more questions I have to this type of problem.
Good luck.
Oct 16, 2009 | HP Office Equipment & Supplies
I have a Sharp Ux B700 that does not print. I have had it a couple of years. I odn't use it often. I have changed the ink cartridge but still no print (either in copying or report printing...
Does the carriage move side to side when you print? If it does, you have a bad cartridge. If it does not, did the display show any error messages? Does it fax out correctly?
Just in case you have not checked, please make sure the protective tape on the new cartridge print head section is removed.
Good luck and please let me know how it goes.
Sep 11, 2009 | Sharp Office Equipment & Supplies
When printing is give it prites in 4 colour always
put that color chart on the glass with the darker end facing the let, and then press start. You will have to do it about 3 different test, so keep follow the intruction.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
Ricoh aficio 2045eSP
Please make a power off and then start it. Let it to initialize then install the Ink Bottle. Make it off again. and then power on.
Try to check it out and print.
Hope it will solve your problem. Otherwise let me know if you need further assistance.
Regards
ELLIN
Sep 20, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
BROTHER "MFC-3820-CN" TROUBLESHOOTING
You need a new print head.
You could try cleaning the one on there, but all brothers similar to yours are plagued by this problem.
To clean it try:
SWITCH MACHINE ON WHILST HOLDING DOWN MENU/SET KEY, THIS PUTS MACHINE INTO FACTORY SETTINGS MODE.
(MAINTENANCE WILL SHOW ON LCD)
ENTER CODE:84 & WAIT WHILE MACHINE PERFORMS A FORCED CLEANING CYCLE.
(cLEANING WILL SHOW ON DISPLAY)
NOW ENTER CODE:09 & MACHINE WILL PRINT OUT ITS PRINT QUALITY CHECK SHEET.
(IGNORE INSTRUCTIONS PRINTED ON CHECK SHEET)
CHECK QUALITY & REPEAT BY USING CODE:84 IF NEEDED.
(YOU MAY HAVE TO DO THIS SEVERAL TIMES BUT YOU SHOULD SEE A STEADY IMPROVEMENT WITH EACH CLEANING CYCLE)
WHEN FINISHED AND QUALITY IS GOOD, ENTER CODE:99 TO RETURN TO STANDARD MODE.
PRESS MENU/SET 4, THEN MONO FAX START TO PRINT OUT
PRINT QUALITY CHECK SHEET & FOLLOW ON SCREEN INSTRUCTIONS.
Feb 11, 2008 | Office Equipment & Supplies
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Dec 06, 2007 | Canon LaserClass 2060P Plain Paper Fax
55 people viewed this question
old marine
old marine
