Question about Samsung SCX 4521F All-In-One Laser Printer
Cannot scan from scanner to pc
Why won't it let me scan anything to pc.
  • 3 Answers
Have you installed all the software that came with that printer.
Also goto START o your desktop then goto SETTINGS THEN PRINTERS and make sure it is set to your default printer.
Also inside the package you are using to scan you must set on the options add twain scanner, which then you sellect your printer.
Posted on Feb 08, 2009
I'm getting this message "The operation could not be completed. No other information is available about the problem." I had a paper jam..fixed it and now it won't scan anything without that er
1. Quit neat app.
2. Turn off scanner.
3. Unplug scanner from computer and outlet.
4. Wait a minute.
5. Plug scanner into outlet and computer.
6. Start Neat app.
Hope this helped.
Feb 21, 2013 | Neat Company NeatDesk Scanner for Mac
When scanning with the native scanning software, the scanner runs very fast but file size is huge. When I use Adobe 9 to scan, my files size is much smaller but the scanner pauses after each page. I need...
I would expect the problem with the Capture perfect fike size is down to the compression chosen for the output file. Ideally black and white inahes should be Group 4 TIFFs and Colour or Greyscale should be JPEG. Alternatively you may want to check the scanner is set to 'scan ahead' in the twain settings in Acrobat. If it is set to anything else the scanner will slow down to allow the PC to process every image. With 'Scan Ahead' turned on the scanners memeory buffer the PC speed a little giving you faster scanning.
Jan 25, 2011 | Canon DR-5010C Path-Through Scanner
CANON MX 320 SCANNER PROBLEM
You need to control the scanner thru your PC with canon software that came with your scanner otherwise you cant scan anything..first open the printer/scanner software ,select scanner,then place your document and command "scan" on your PC..thats it..
Jan 05, 2010 | Canon PIXMA MX310 All-In-One Printer
How do i use the scanner on my Canon MX310 ?
You need to control the scanner thru your PC with canon software that came with your printer/scanner otherwise you cant scan anything..
First open the printer/scanner software on PC,select scanner,then place your document and command "scan" on your PC..On this window you can also alter the scanner preferences..thats it..
Nov 13, 2009 | Canon PIXMA MX310 All-In-One Printer
Symbol ls 4000i not scanning
The first beep is a Good decode beep, the four beeps later are telling that the connection to your PC is not working properly.
Jun 07, 2009 | Symbol LS 4000i Handheld
My pc doesnt recognise the scanner
OK.
The first thing I would try a different cable between the PC and scanner just in case it's faulty. Use a 6-foot USB) cable.
If this doesn't fix the problem:
Disconnect the scanner.
Remove the scanner driver so that we can start from scratch.
Go to http://www.mustek.com/mustek/supportdrivers.php and select your scanner model.
Download the twain driver and panel zip file.
Extract the file and install the driver
After installation, restart your system.
Once the system has restarted, reconnect the scanner.
Check the scanner icon on the control panel to make sure that it has installed successfully and that the red X is not shown.
If this does not work let me know.
May 18, 2009 | Mustek Plug-n-Scan 1200 UB Plus Flatbed...
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
Mar 30, 2009 | Acer Scan to Web 3300U Flatbed Scanner
Anything is being transfers to PC
Do you test with the notepad of Windows ?
Did you scan the appropriate barcode ?
Sep 02, 2008 | Symbol LS1908T Wired Handheld Barcode...
Scanner & Printer All-in-one
PLEASE READ **CAREFULLY
Do you want to scan in a document or a picture?
If it is a picture, go to your photo program. Under FILE choose IMPORT then SCAN or TWAIN or your actual scanner (if it shows there.) Have your photo in the scanner ready to go and click on the above. This will scan the picture into your program and you can do any adjustments or cropping needed and "save as" where you want in your files.
A document can be a little more tricky because sometimes your existing document program( Word or whatever doesnt match the document format. However, on many scanners you can choose which program you want to open the document. If your document program will not open it, you can choose" word pad" and once it is there you can save it as an rft document then try opening again in your document proggy. There are many workarounds here to convert documents that didn't come from your program, but with a little patience it can be accomplished.
**Now that I have given you this information, I'll ask you. Do you have the scanner driver installed on your PC? If you do not you won;t be abl;e to scan anything onto your PC, however, you can go to the manufacturers site, click on support or downloads and download the correct driver for your scanner and operating system to your desktop. Be sure to turn off all running programs while you download and install. Once it is on your desktop it will be an exe file. Just click on it to install. Your scanner will then work with your PC and you can scan whatever you want using your programs to do it-picture or document. Good Luck to You.
Aug 10, 2008 | Office Equipment & Supplies
Samsung SCX 4521F All-In-One Laser Printer Logo
138 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
