Question about Sharp XR-1S Notevision DLP Projector, 800 x 600 SVGA Native Resolution, 1100 ANSI Lumens, 1500:1 Con... Multimedia Projector
Color shifting Very quickly after firing up projector, the color shifts from normal to red and after adjusting will shift to green then back to red or green. We can't get through a movie without having to adjust at least a dozen times. Help
  • 93 Answers
This common to dlp projectors! THe DLP wheel has a problem.it has lost its alignement
the best way to solve this is to gt a new dlp wheel replacement
Posted on Feb 08, 2009
Is there a way to "fix" or adjust registration problem?The red is shifted low and blue is shifted to the left.
Yes! Most rear projector sets have a utility to align the red, green and blue colors.
You didn't include the make & model number of your TV set, but if you look at the menu section of your set, you should be able to find this setting - it may be hidden in an "advanced" submenu. Make sure you take the time to do all three colors. The more finicky you are with removing red, blue and green tinges - the better your picture will look.
Sep 30, 2013 | Televison & Video
Sony kds-r60xbr2 televison
Make sure that you do not have a magnetichc feild around the TV.
Sep 06, 2008 | Sony KDS-R60XBR2 Television
1988 chev trans takes high rpm to shift from 1st to 2nd and some times it wont down shift when you slow down and hit the gas again
Check the adjustment of the transmission T.V. cable. Sometimes they also stick. Try driving it at 30. Shift to Neutral, stab the gas pedal to the floor quickly a couple of times. Then shift back to drive. Then see if it shift normal.
Jul 13, 2010 | 1988 Chevrolet C1500
My E771 monitor colors suddenly shifted with
Possibilities:
1. video-card gone bad;
2. video-cable gone bad;
3. video-cable not tightly-connected to CRT;
4. video-cable not tightly-connected to video-card;
5. "red" gun inside CRT gone bad.
Disconnect the video-cable from the computer, and try again to adjust the "red". If red-free, then it's time to responsibly recycle the CRT.
Reconnect & wiggle the video-cable, to see if that induces any "red" onto the CRT.
Connect the CRT to the VGA-output port on a notebook computer, to see if that video-card generates "red" as one of the primary colours.
Give the CRT a strong "whack" on the side, to see if "red" makes an appearance.
May 07, 2010 | ViewSonic E771 17" CRT Monitor
Copy of instuctions for fighter squadron
Flight and Weapons
Joystick
Button 1 fire main weapon Button 2 fire guns Keyboard
E engine on/off Ctrl P props feather on/off P toggle autopilot + increase throttle - decrease throttle F flaps down Shift F flaps up G landing gear up/down B toggle wheel brakes Ctrl E eject T target Space fire guns 1 select main weapon M.G. 2 select main weapon cannon 3 select main weapon all guns 4 select rockets 5 select bombs 6 select bomb bays A arm master weapon Enter weapons release D toggle bomb bay door Wingman Commands
J as you were K form up on my wing L attack my target ; disengage ' return to base Rudder/Trim
< rudder left > rudder right / rudder center Left Arrow trim left Right Arrow trim right Up Arrow trim up Down Arrow trim down Ctrl Left Arrow rudder trim left Ctrl Right Arrow rudder trim right View Selections
F1 set designation padlock F2 external F3 chase F4 weapon F5 next vehicle Shift F5 previous vehicle F6 command vehicle Shift F6 A.I.-controlled vehicle F7 next crew Shift F7 previous crew F8 tower view F9 quick view 1 F10 quick view 2 F11 quick view 3 F12 quick view 4 M in mission map Shift M in mission map close-up Overlays
H toggle HUD Shift H HUD mode Ctrl H HUD color Shift I HUD intensity up Ctrl I HUD intensity down Alt M target state R target map range Alt W weapons state Alt V vehicle I.D. state Alt I I.D. state Inside Plane Views
Numpad 8 foward Numpad 2 aft(behind) Numpad 4 left Numpad 6 right Numpad 5 up Numpad 0 down Shift Numpad 8 pan up(digital) Shift Numpad 2 pan down(digital) Shift Numpad 4 pan left(digital) Shift Numpad 6 pan right(digital) Ctrl Numpad 7 shift up Ctrl Numpad 1 shift down Ctrl Numpad 4 shift left Ctrl Numpad 6 shift right Ctrl Numpad 8 shift aft Ctrl Numpad 2 shift fore [ zoom in ] zoom out Shift Numpad 5 center your view System
Z screenshot Esc end mission Shift Esc pause game Ctrl Esc end program Ctrl - reduce window Ctrl Equal Sign enlarge window Shift - reduce gamma Shift + increase gamma Network
~ radio chat
Sep 22, 2009 | Activision Fighter Squadron for Windows
Panasonic pt-47wx53g red is out of convergence range
Have you moved the TV recently?, if so the red can(Red source) in the back bottom of the TV may have physically shifted in its holder, this is common when a rear projection tv is moved, jostled. Take the back off, look at the three cans,Red, Blue, Green, see if they all look like they are nested the same, bet the red is shifted a little.Good Luck with it!
kskip69
Aug 22, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Red shadow to left of main image InFocus LP750
You have to open the LP750 and check the alignment of your color lenses. You might be needed to adjust, also check your lamp too.
Jul 23, 2009 | InFocus LP 750 Multimedia Projector
Color fades when wathcing TV from greens to reds and also get dark.
Typical problems with lcds.. When they get hot, the color tends to shift. The reason your seeing the problem on the red and green is because of a lack of blue.. Makes sence if you think about it as blue is the hottest wave of light, so the blue panal is getting too hot or possibly the polarizing filter on the tv..
Lamps can cause this somtimes as they tend to shift twords the higher waves at the end of there life.. So if you have another lamp, try it out.
Another possible cause is the driver board for the lcds.. If there is a chip that has a small short, it will overheat as well and cause it not to function properly. I see this all the time on lcd projectors. 1 of 3 things.
Jul 26, 2008 | Sony KDF-E42A10 42 in. LCD Television
Problem with color shift
Hi there
This might be a faulty Mainboard - that will need repair or replacement - and is quite expensive.
First check by using another cable , if the problem still occurs then the above will most probably apply.
Mar 30, 2008 | Sanyo PLC-XU73 Multimedia Projector
Color shift
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Mar 29, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Sharp XR-1S Notevision DLP Projector, 800 x 600 SVGA Native Resolution, 1100 ANSI Lumens, 1500:1 Con... Multimedia Projector Logo
257 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
