Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
My vacuum won't work-
The lights come on indicting it is getting power, but I get no suction and no motor noise
  • 281 Answers
Sounds like the motor might have bit the dust.try this,unplug the vacuum and reach under where the brush rolle is and try to turn the roller by hand a few times,if you can't turnit then then the roller is jammed.take the belt off and then turn it on and see if it runs then.let the motor cool down first the motorguard might be keeping it from running.just let it cool down for about 20 minutes then try it
Posted on Apr 23, 2009
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I bought Dyson DC16 in 2008. Charged full but it only last for 1 minuet. Should I get a new charger? Is Dyson going to send me a new charger?
Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
Shorting the battery like an Aircraft battery then re-charging won't fix it.
Jun 09, 2011 | Dyson DC16 Root 6 Bagless Handheld...
After charging,the vac cuts out after a minute or so. any help please?
Jan 11, 2011 | Dyson DC16 Root 6 Bagless Handheld...
Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
Oct 19, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My Miele capricorn has started making an odd noise. It seems like something is blocking the engine. I've turned if off and on, and reset it and it still have the odd, almost loud barking noise. The power...
Greetings,
This is a major problem. The Miele vacuums motor should never make a loud noise, period. The way the motor is designed, it's quiet and should be quiet for the life of the motor. There are two motors on your Miele canister. One of the motors controls only the suction of the vacuum, while the other motor controls the power brush. Which one of your motors is making this horrible noise? You can tell this by removing the wands and power brush so that you just have the handle of the hose by itself. Now turn on the vacuum, do you still hear this noise? If yes, then this is a problem with your suction motor, and you need to bring this in to have an authorized Miele repair center take a look at it. The reason I say that is because you have a 7 year warranty on that suction motor, so if something is wrong with that motor, then this will be covered under Miele warranty. If it's the power brush motor that's causing the sound, this probably will not be covered unless the vacuum is under 1 year old. If it is the power brush, please just use the clarificaiton request here on Fixya and let me know, I'd be more then happy to try and walk you through diagnosing the power brush motor with you.
I hope this was helpful to you. If you did find this helpful, please be sure to click the thumbs up icon in the repair. I really appreciate it.
Chris J.
Mar 21, 2010 | Vacuums
Blown vacuum fuse?
Sounds like you got a clog in the hose, which depleted the suction. After getting clogged the motor was working overtime and burned up. If your vacuum is still under warranty you should bring it to a warranty repair center to be fixed. Changing a motor in a vacuum is almost as expensive as buying a new vacuum cleaner. So if your vacuum is out of warranty I think you should probably buy a new one.
Oct 09, 2009 | Vacuums
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
182 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
