Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Compressor starts/stops alot. Compressor is hot coils are cool
The compressor keeps turning on and off alot. Not holding temp in both refrigerator and freezer. Coils are clean, fan is on. If i let it sit unplugged for a hour or so it will come back on and act as normal getting to temp then a couple hours later the compressor will start/stop alot and it will loose temp. Unit is a Side by side Amana ARS2464BW
You might try a new relay switch first it is much cheaper than a compressor. I had a Kenmore doing that same thing and I someone advised me to change the relay and it now works wonderful.
Posted on Apr 24, 2009
  • Kenmore Master
  • 19,396 Answers
The compressor is covered for at least three years, give a call to the number listed on the owner's manual to validate warranty and get the replacement.
Posted on Feb 08, 2009
    President:
  • 1,902 Answers
Have you checked the power and the amps going to the compressor? Your compressor is getting hot and then it is freezing up and trying to going into cycle but the piston over heats and the relay cuts out the compressor, that is why when you let it cool down it works ok. You will need to get a new compressor. If you have a warranty the compressor is covered
Rangemaster sxs cream . Why is my fridge and freezer the same temp ???? If anybody could give me an answer or solution.
Jason,
MOST refrigerators get there cold from the freezer side and circulate it via a fan that's also normally inside the freezer. There are three motors normally in a refrigeration system. The inside Evaporator fan motor that circulates air across the evaporator coil inside the box, the Condenser fan motor near the compressor that cools the freon after compression, and the compressor itself. If you open the doors (and sometimes you may have to hold in the door switches) do you hear a fan running? If not you could have a couple things going on: 1. The fan(s) has failed. 2. The freezer Evap coil may of iced over and the fan too is frozen stopped. 3. Your condensing unit:(compressor, condenser fan, condenser coils) has a problem.
It is important to know if the compressor itself is running. If there is a loose connection to the compressor via the start/over load relay (normally attaches directly onto the compressor), or if the start/over load otself is bad the compressor will not run. Best way to tell is via gauges but I doubt your frig has ports. Check to see if your compressor is really hot. Could be bad start/over load relay or bad compressor. Try unplugging your frig for say 30 min then, with your hand on top of a cool compressor, plug the frig back in and see if compressor smoothly vibrates for at least 5 min without becoming very hot or shutting off even though fan continues to run. The fact your fan is running TYPICALLY means the thermostat is calling for lower temps and the fan/compressor kick in together.
Oct 11, 2013 | Refrigerators
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
The freezer just stopped being cold and food thawed out. It is cool and their is slightly cool air blowing. Refridgerator seems to be holding its temp. It is running but seems quieter than normal
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Refrigerators
My compressor gets hot and stops ,i have cleaned out the coils
is there a condensor fan motor down by the compressor that is not operating? this is to keep the compressor cool during operation.
Oct 24, 2009 | Kenmore 57029 Side by Side Refrigerator
Refrigerator freezer not cooling or freezing took off back cover. fan operates. compressor is hot, when pluged in humming noise then drops out.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Crosley CFFH10W Top Freezer Refrigerator
Samsung frig stopped cooling-
most new fridges have a self defrost mode once or twice a day because the coils ice up if it collects alot of moisture. it shuts the compressor down and turns on a heat coil to defrost (which can take up to a half an hour). usually on a timer that is adjustable.
Jul 20, 2009 | Samsung RS2630SH Side by Side Refrigerator
The refrigerator and the frezzer stop working. I have power because the lights are working normally. Can i fix it.
How to check stuff>
Jul 12, 2009 | Whirlpool ET1FHTXM Top Freezer...
Compressor is extremely hot
Compressor will be hot to the touch. You stated the fan was replaced and then said the fan is not cooling. If you replaced the fan and it is now operating, reinstall the panel you removed to install the fan motor. That panel determines proper air circulation to cool the system.
Jun 14, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
344 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
