Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
KUdI02FRss broken/Flashing Lights...
Hi all,
I am having an issue with my KUDI02FRss1.
The lights are flashing intermittenly (Heavy Duty Wash/Regular Wash) and Cancel if I press that one too.
No other lights or buttons are responsive.
Canceling the power (shutting off breaker) has not worked.
Is there a reset combination?
HELP!
  • suparnaji Feb 09, 2009
    I am having a similar problem. The normal and cancel lights keep flashing and no amount of pressing any buttons changes anything.
5 Suggested Answers
COXY
  • 76 Answers
SOURCE: Diswasher won't start
Try holding the reset button in for about ten seconds.
Posted on Nov 27, 2007
ndguy2481
  • 251 Answers
SOURCE: ////////////////////my kitchenaid dishwasher lights are flashing
yes u need to call an electrican u have to much load on that side of the house
Posted on Nov 27, 2008
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
  • 760 Answers
SOURCE: blinking lights, not washing
Usually blinking lights are indicating bad touch panel buttons. Remove kick plate, (black panel under door) and find service instructions there. It will tell you how to test button panel, as well as any codes flashing. Also will tell you hot to try a reset.
Posted on Jul 26, 2010
How to repair - no water is entering the dish waterr
Your dishwasher is equipped with a safety system which is able to detect any operating problems. These anomalies are reported by
one or two wash cycle indicator lights "E" will flash rapidly.
Any flashing combination of LED diodes (Intensive wash, Regular wash, Eco wash, Rapid wash, Soak and Crystal care) means different error code. Take a note of which lights are flashing?
If you have problem with fill water than following two LED should be flashing.24428775-0h3kxpflbez5mdeb5anq3st4-3-0.jpg
In this case could be:
  • Water valve disabled
  • Turbine disabled
  • Control board faulty
Dado
May 15, 2014 | Ariston Technologies LL65 Built-in...
I have the CW447 integrated dishwasher which won't fill with water
Like most electrical appliances what worked for me was turn it off at the wall for 10 mins, then turn it back on. Did you get an error code? Check the pipes are not twisted and that the water supply is turned on full. Let me know how you get on
Apr 13, 2014 | CDA WC430 Dishwasher
F&P Dishwasher Fault
Most likely you have fault code E1 which means door is not shut properly. It is likely the door springs need adjustment as the door might be opening mid cycle.
Refer manual
http://www.fisherpaykel.com/vault/pdfs//pdf_usecares/599350D_DW60ugm_AUSGw.pdf
Mar 18, 2014 | Fisher and Paykel Dishwashers
I have a dewalt dc618 finish nailer When I go to shoot the lights on the gun start to flash and will not shoot ?
Continuous flashing indicates low battery charge or poor battery connection. If lights flash 4 or 5 times indicates possible control module fault.
Oct 28, 2013 | Dewalt Heavy - Duty 18 Gauge 2" Brad...
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
Blinking lights, not washing
Jul 21, 2010 | KitchenAid Dishwashers
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
The Heavy Duty and the Daily Cycle lights are
to better assist you can you provide me with the ERROR code, if is any.
Thank you
May 15, 2009 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Hotpoint Dishwasher BF1620
ive not worked on hotpoint dishwashers,does the dishwasher drain? at the point it plays up is it supposed to be filling or washing.check the filters inlet valve etc.do you still have the manual for the dishwasher.the flashing lights are most likley a fault code but we dont get hotpoint dishwashers in australia.sorry i cant be of more help.Ian
Mar 21, 2008 | Dishwashers
KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
94 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
