Question about Hitachi 53UDX10B 53" Rear Projection Television
I have a green glow kind of like shadows, is this the red bulb?
Green glow , mostly at the center and top left of screen
  • 42 Answers
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Posted on Feb 08, 2009
Projector cp-sx635 lamp indicator glows red (RED). intimate trouble shoot pl
sounds like the bulb will not fire up. most likely cause is the bulb needs replacing
Jan 03, 2013 | Hitachi CPSX635 4000 Lumens LCD Projector...
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
We got a free hitachi projection tv that i believe has a bulb malfunction. on the left half of the screen has a red shadow we cant afford a hundred dollars for an estimate then whatever the price of the...
You might need to adjust the red screen drive control, turn the Red down and see if that clears it out. Sounds like the Red Tube is over driving the Green and blue Tube.
Find the Focus and screen control block there will be 3 controls on Top 3 right under them R-G-B they adjust the Focus to each tube and screen drive for each tube. also you need to clean the lenses off top of each tube they get dirty and dusty and it would help to clean the mirror
Sep 13, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Green glow on the screen,top center/left
Does this look like it is three d and thecolors don't line up?
If it does then you need to replace the convergence Ic's
Hitachi makes a kit for that tv that would be available through a local parts distributor
If you are not experienced with soldering and component removal then have a local tv shop do it for you
I would not pay over $250.00 to get it done
Good luck
Feb 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Red & green shadows
Replace the two STK392-120 Convergence Ics you can get replacements at the following link with step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jan 15, 2009 | Philips 60P8341 60" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Strobing and sunburst effect on my plasma vizio p4
no bulbs in a plasma..
sounds like a video problem or centering problem ...see if can change the resolution or put it on auto and reset all to default through the menu.
Mar 17, 2008 | Televison & Video
Red & green lines
Sounds like you have hardware failure in the convergence circuit. Some combination of the IC's, fuses, and/or resistors has failed. Repair cost is $250-$400 parts & labor
Dec 02, 2007 | Akai PTH5498 54" Rear Projection...
Green and red color problem on bottom left to a little past the middle of the bottom of screen
the convergence ic's are breaking down and require replacement should cost under $ 250 depending on your service shop.
Nov 18, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
71 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
