Question about Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV
Sony Projection TV - glowing blue in corner of screen
About 1 month ago the corner of my screen (Sony KDF-60XS955) started glowing bright blue. It expands off and on like the northern lights to fill about 1/4 of the screen. I just replaced the lamp with one I received directly from Sony, and the glowing remains. Does anyone have any suggestions?
  • 5 more comments
  • Anonymous Mar 05, 2009
    SONY KDF-60XS955. REPLACED PROJECTION TUBE ABOUT A YEAR AGO. ABOUT TWO MONTHES AGO BLUE SHADE IN THE RIGHT HAND LOWER CORNER.
  • jimjac8151 Mar 08, 2009
    My TV screen is turning blue.Started on right side spreading to the right. Replaced rear projection blub approx. 1 yr ago. Model # KDF-60XS955
  • Anonymous Mar 29, 2009
    I have a similiar problem except on the lower left side.
  • jimdougherty Apr 07, 2009
    We have the same "blue" corner in the bottom left hand section of the screen. We replaced our bulb about 4 months ago. It seems that most who wrote in with the problem had the problem "after" they installed a new bulb. Could there be a correlation?
  • civicgsr96 Apr 21, 2009
    My TV just started to get a blue section in the bottom middle of the screen and it seems it is spreading up the middle.
  • Bassim Apr 25, 2009
    I have exactly the same TV and exactly the same problem! A Sony technician came and told me that there was a recall last year because of the this problem!
    Does anyone have any information about the recall?
  • Buzzlitonian May 19, 2009
    Bought the same TV from Sears 2.5 yrs ago. I Just replaced the lamp.
    Discovered the old lamp has a tiny screen at the top of it for air flow. It was clogged with fine dust. I am convinced this a design flaw with heat. Nothing mentioned in the Manual either to keep it cleaned. The lamp when installed is next to the FIRST piece in a 3LCD lighting engine system. A mirror/glass/silicon device called an Integrator Lighting System Polarization Changer Element. Because of the lack of air flow across these hot halogen bulbs what we are seeing is distortion in the polarization device, warping it along the edges or direct center where the heat is the hottest, yep a corner for heat to escape, which is where we start to see the problem. The light that passes through is affected as a slight shadow (like when a cloud starts to block the sun, but because of polarization it has an opposite effect, to lighten up or change the amount of light as a brighter spot on our screens). I don't think we can just replace it (the single part). So, now, the new lamp is much brighter than the older one and my lavender spots show up easier. There is no fix but to replace the the whole light engine. I don't know how much they cost, but they are basically the TV. Temporary fix from worsening, is to clean the tiny screens on the light bulb every so often. I will do it every 6 months or so. I am bummed about this, too. google search for 3LCD light engine may show you all a picture of how this technology works. Created by EPSON few years ago. TV manufactures bought into the idea and relabled it as 3LCD (3 small red, blue and green LCD's about the size of a postage stamp) Light passes through once (720p) or twice for HD 1080p and then projected through a similar camera lens onto our screens. So, the final word is HEAT. Check the fan, air flow blockage from back of set, nothing blocking the front, keep the dirt out.
  • 42 Answers
That sound like the optical Block or otherwise known as the light engine
This still may be covered by sony's warranty
I would call them and see it is a very expensive part
Posted on Feb 08, 2009
Blue dots on screen. Blue band on on/off side of screen.
blue dots on screen,bright blue haze right corner to north westpast center of screen.
May 24, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Problem with sony 60" rear projection TV
I'm afraid, it is problem of optical block unit (light engine) that produce picture by 3 lcds inbuilt, the blue lcd and its related uv filters become defective and causing this kind of blue hue on screen.
Complete optical unit block (light engine) will be replaced by qualified tech to get tv fixed, light engine is costly part so ask an estimate before sending tv in.
Thanks.
May 21, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kdf60xs955
The light engine is bad. Contact Sony. Even out of warranty they have been replacing some of these.
Mar 30, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Tiny Blue Dots all over scree. Now wont turn on.
is munes the same way, if it is try to clean
back mirror. if that don,t you need to call sony.
because it your eng is bad wicth is whear the pix come from.
Aug 25, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Bright blue on the top right corner of the screen
Throw the thing away! I have the same problem. can get no help from Sony...Technician says it is the light engine...cost: $1177.00 to fix. Foget it. Old saying "Sony-No-Balogna" New saying "Sony-is-a-Bunch of Balogna. Would never suggest a Sony product to anyone.
Aways had RCA's...each lasted at least 10 yrs with no problem. I have had this set for only 21/2 years.
Jul 13, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Blue dots and blue cloud. Sony 55" LCD
Sounds like magnetic interference,Do you have a speaker close to that corner?If so you need to relocate it a little farther away.
Jan 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega KDF-42WE6 55
Sony wega blue dot or star pattern on screen
http://esupport.sony.com/perl/news-item.pl?news_id=206&mdl=KDF42WE655
Models: KDF-42WE655, KDF-50WE655, KDF-55WF655, KDF-60WF655, KDF-55XS955, KDF-60XS955, KF-42WE620, and KF-50WE620
Sony LCD Rear Projection TV - Optical Block Problems
Jan 16, 2008 | Sony Grand WEGA KF42WE610 42" Rear...
Sony Grand WEGA KDF-60XS955 60" Rear Projection HDTV Logo
565 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
