Question about La Pavoni Pub V1 Espresso Machine
Steam outlet on the la pavoni ubarv2 machine
The steam water comes out merky when making maccido drinks
3 Suggested Answers
LaPavoniBoy
  • 36 Answers
SOURCE: Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Posted on May 28, 2009
SOURCE: Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Posted on Jul 24, 2010
System is not priming
This is normal after you leave the machine unused for a long time. The water dirt or scale or both make many parts to stuck like glue. The presure pump might be stuck if even if you here the noise of the vibration the outlet have been blocked. another part that can be stuck for the same reason is the water solenoid. Both can be fixed by remove them desasemble them and clean them with a wire brush. If you have a litle technician knowladge this is a very simple operation. Of course if you persist you might unsuck by trying the procedure you mention but it seems that now it is hard to be hapen.
Good Luck
Remember to vote for this answer.
Feb 28, 2010 | La Pavoni Espresso Si PAB-16 Espresso...
Espresso machine problems
Hello les laj,
You should first try to take a look at the manual. If you coninue with problems, let me know.
 Manual: http://www.lapavoni.com/PDF/MAN_barENG.pdf
You can find the installationsection on page 7
Jul 17, 2008 | La Pavoni LaPavoni Bar S3 Semi-Automatic...
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Unregulated pressure then safety valve releases pouring out steam
It seems to me that your pressure stat which is inside the base of your machine needs replacing. I would try to give it a good descale and if this doesn't do the trick then a new pressure stat is what you need. Prob around £20 if you buy it and do it yourself. www.theespressoshop.co.uk and just click on the little la pavoni machine for full parts list.
All the best
LaPavoniBoy
Apr 13, 2009 | La Pavoni PC-16 Espresso Machine
Our La Pavoni Lusso machine has not been used for a couple of months. We put water in to prime the pump, and nothing comes out. We can hear the pump going, and the heater indicator light is working. Any...
Try opening the steam nozzle while trying to pump the water through as this will get rid of any air locks. Otherwise it may be a build up of scale in the boiler or the pump itself. Try that and descale if you can.
All the best
LaPavoniBoy
Mar 07, 2009 | La Pavoni Lusso PL-16 Espresso Machine
Water leaking from the group
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Feb 18, 2009 | La Pavoni PC-16 Espresso Machine
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni Losso Espresso machine not working.
Fill the tank with a strong De scale soulition , sounds like its blocked with limescale. REMEMBER to rinse thru clean water several times after the process...
Feb 08, 2008 | La Pavoni Lusso PL-16 Espresso Machine
Pavoni, no steam from steam wand
i havent heard of this issue , it could posibly be the bent steam wand , but the nozle is made to be that way, because the pavoni eurpicola doesnt produce enough steam pressure , it enables you to create better froth
Oct 25, 2007 | La Pavoni PC-16 Espresso Machine
No pressure
I have the same problem are awaiting reply from la Pavoni direct...I suspect there is a fualt with the pressure gauge as it is steaming up too!!
Jun 10, 2007 | La Pavoni PC-16 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
