Question about Mtd 22" Yard Machine Push Mower
Shear bolt holes are not lining up.
I am trying to replace my shear bolts on both sides of the auger. The right hand side went in with no problems. The left hand side is not lining up, I cannot even see the shear bolt hole in the rake. Any ideas?
  • toriley Feb 09, 2009
    Thanks, the problem was locating the old sheared pin. It blends in with the rake and the grease! Anyway found it and punched it out. Thanks again.
How to replace shear pin horizontal blades spin free motor won't drive them
Look close to the middle of the auger. you should see small ( 1/4") holes where the shear pins were. Just line up the holes from shaft to Auger and put new Shear pins in there. Sometimes they look like Clevis pins and sometimes they look like a simple 1/4" bolt and nut
Jan 04, 2016 | Garden
Both augers turn when not trying to clean snow,as soon as I try to use it and snow gets to the augers,only one auger moves on my ariens 520 snowblower
It sounds like the auger always turning is the auger engagement handle/line/connections are not adjusted correctly. They/it is too tight causing the auger to engage before it should. It may be up at the handle where you loosen a jam nut, screw in or out a threaded shaft, and retighten the jam nut. (If you have ever adjusted a bicycle brake it is similar.) (I have a craftsman, made by MTD, and I think I saw MTD also list Ariens.) Or it could be an adjustment somewhere else (but I'm not sure where).
As far as one auger moving and the other not, you may have a shear-pin (shear bolt as the manual calls them) on each side of the auger's shaft (my craftsman has one on each side), and the one on the side that stops turning is sheared off. (It moves without snow present due to the driveshaft inside the outer auger shaft turning, but it won't turn under load (snow).) You may confirm a sheared-pin by turning the machine off and try to turn the auger blade. If it turns somewhat easily, that's a bad shear pin. Remove the old shear pin. If the old one is as long as the new one, that aint the problem. The shear pin in the image is one kind. Mine appear as a straight bolt (no grooves), threaded the entire length. You will have to rotate the auger blade until it aligns with the hole in the shaft. Use a nail that fits and rotate the blade until the nail goes in. Remove the nail and screw in the shear bolt:
The auger clutch control up at the handle looks like this:
25398197-u3i4ko1tk2s0xlbbi4fvvtzj-2-2.png From my manual
Auger Control
  • To check the adjustment of the auger control, push forward the left hand clutch grip until the rubber bumper is compressed. There should be slack in the clutch cable.
  • Release the clutch grip. The cable should be straight. Make certain you can depress the auger control grip against the left handle completely.
  • If adjustment is necessary, loosen the hex jam nut and thread the cable in (for less slack) or out (for more slack). Recheck adjustment. Tighten the jam nut when correct adjustment is reached.
Here's another view of that:
I hope the above info helps you take care of both issues.
Feb 03, 2015 | Ariens Garden
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
Mtd yardmachine snow blower 305 cc auger wont turn
This is a fairly frequent problem that is easily fixed. What happened was the snowblower's auger was either overloaded or got jammed (ice, debris - something other than snow). Rather than twist, damage or break the auger itself, an inexpensive part called a "shear pin" is designed to fail. A shear pin employed between the auger sleeve and drive shaft that is inside the sleeve. You may have broken one if one side of the auger spins) or both (if both sides of the auger spins). Purchase several replacements for your particular machine to have on hand. Do NOT replace s shear pin (or shear bolt) with a regular bolt under any circumstances! Check the video linked below on how to replace the shear pins. Good luck!
Feb 09, 2014 | Yard Machines 28" Two-Stage Snowthrower
Snow thrower let auger not spinning with right side
If you look on the auger shaft you will see some bolts, they are called shear pins. They are there to break if something gets in the auger and jams it, the bolts will shear off to prevent damage to the auger or something else. What you have to do is replace the shear pin or pins on the side that is not turning. Hope this is helpful. All the best and good luck.
Feb 02, 2011 | Craftsman sears 18" Chain Saw Chain (...
One side of the auger doesnt turn
I'm assuming that you are speaking of a snow blower auger. It most likely has sheared a cotter pin or bolt that couples the auger to it's shaft. Turn the auger slowly looking for a small hole somewhere along the shaft. When found, hold the auger and turn the impeller by hand until the inside shaft lines up it's hole (there may be a sheared piece of metal in the shaft hole). Use a pin punch to drive out any remaining shear pin and fit a recommended new pin or bolt. Hope this helps!
Dec 08, 2010 | Garden
I have a 5/22 2 stage MTD snowthrower and from behing the machine, the right side auger is not spinning. The left side works fine, when the engine is off, the right side spins freely while the left is...
your shear pin(s) are broken on that side they will look o.k. but are snapped off inside drive them out with a large nail or center-punch,don't use a regular bolt to replace the shear pin as they will fit,because if it gets plugged again the gearbox will be your next expensive shear pin to replace
Feb 24, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
One side of my ARIENS ST928 SNOW BLOWER doesn't work
most likely you have a broken shear pin. Look on the side that works, there should be a bolt or pin through it. The side that is not working is probably broke off. Find the hole in the auger and line it up with the inner shaft and replace with proper shear pin/bolt. Shear bolts can be obtained from most outdoor power equipment shops. I do not suggest replacing with standard bolt as it can cause damage to you gear box it auger gets jammed.
Dec 18, 2008 | Ariens Garden
Mtd 22" Yard Machine Push Mower Logo
70 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
