Question about Apple iPhone Smartphone
Iphone shows battery icon when on charge but will not switch on
When i plug it into the mains the screen just shows up as the battery,
for some reason it will not charge or go past this charge point therfore won't turn on
when i take the mains out, the phone asks for it to be reconnected to charge. does anyone have any ideas???
Many Thanks....
  • 21 Answers
Similar solution for a lot of Apple Iphones probles. Best thing to do is to put it into recovery mode.
Hold the Power and the Home buttons together for between 20-30 seconds, it should then ask you to connect it to itunes. Do this, itunes will tell you you have an iphone in recovery mode then give you the option to restore it to the latest version.
Hope this helps
Alen Boardman
Posted on Feb 13, 2009
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
Mar 08, 2015 | iPhone 5c Cell Phones
Message on my iPhone shows icon for iTunes to plug in a charger. What do I do?
Charge the phone at least overnite. Sometimes a replacement phone may arrive with a totally dead battery and the charger may not be able to put out enough current to operate the phone and charge it at the same time. If you want it to charge faster use a plug in charger with an output rating of 2 amps. They usually have 2 USB outputs and can charge two devices at the same time. If you only charge one device it's a piece of cake for the charger. .
Sep 10, 2014 | Apple iPhone 4S
What do you do if your iphone screen stays black?
Plug it in to a wall charger to confirm the battery has some charge. Within a minute or so, you should get the charging icon on the screen
Jun 27, 2014 | Apple iPhone Smartphone
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
My iphone is not showing the chargfing icon yet it is charging, slowly
You may please keep in mind that iPhone battery may drain instead of charge if iPhone is connected to a computer that's turned off or is in sleep or standby mode. If you charge the battery while syncing or using iPhone, it may take longer to charge. About not showing the charging icon, please try resetting the phone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts after some time with apple logo on the screen. -- MS Ramakrishna
Oct 13, 2010 | Apple iPhone Smartphone
How do i charge my ipod
To charge the battery, choose one of the options below:
  • Connect the device to your computer (not your keyboard) using the included cable to charge the battery and sync. Your computer must be turned on and not in sleep or standby mode. If the device is connected to a computer that's not turned on or is in sleep or standby mode, the battery may drain.
  • Connect iPhone or iPod touch to a power outlet using the included cable and a USB power adapter to charge the battery.
An icon in the upper-right corner of the screen shows battery charging status. If you charge the battery while syncing or using iPhone or iPod touch, it might take longer to charge.
Note: If using a portable computer, make sure it is plugged into power and that the lid or display is open. If the lid is closed, the computer may go into standby, sleep, or hibernation mode and iPhone or iPod touch may not charge.
Important: If iPhone or iPod touch is very low on power, it may display one of the following images indicating that the device needs to charge for up to ten minutes before you can use it. If the device is extremely low on power, the display may be blank for up to two minutes before one of the low-battery images appears. If you don't see the white charging or plug icons, your iPhone or iPod touch may be connected with a FireWire cable. Disconnect the FireWire cable and connect the iPhone or iPod touch to a USB cable or dock.
that should be everything you need to know about charging an iPod Touch. If you require further assistance please feel free to followup with additional comments. If this solution solved the problem please feel free to rate it. Thanks and have a great day-Midwest-Tek
Aug 20, 2010 | Apple iPod touch Second Gen (8 GB,...
I phone Frozen or F'd?
try removing the battery,for 30 seconds , then replace , as u switch the fone on, plug it into the charger, this may help to re-boot your fone....
Jul 26, 2009 | Apple iPhone Smartphone
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
82 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
