Question about Whirlpool 5"x36" White Bathroom Drop-in Bathtub Spa Jet
I bought a whirlpool bath from mfi with 6 jets when i come to con
-cent didnt have any pump or pipes and dont want to have to threw away where can i get a whrilpool sytem to fit a rigth hand side bath
  • Anonymous Apr 02, 2009
    I have the same problem with a 12 jet inset bath brought from MFI that has no pipes or pump SNY1182
We have bought build in bed room furniture from MFI half of metrial arrived not other half and instular did not finish the job where can I buy the other half to match the colour
Also Mr.John Walton instular conne us £3000.00 not did the other room
Please esponds to amineh145@hotmail.com
Posted on Apr 23, 2009
  • 34 Answers
Www.irawoods.com They should have all you need
Posted on Feb 09, 2009
My new jacuzzi 6 jet tub is only working on one side. What could cause that?
Probably control panel or if there are separate pumps for each side, that side's pump probably doesn't have a relay working with bad switch from the control panel.
Mar 31, 2015 | Whirlpool Jacuzzi Bath Tub with Jets
What cleaner gets the bad smell and crud out of jacuzzi jets?
Here is a link to a site that sells jetted tub cleaners.
Bath Parts Plus Bath Pump Spa Part Spa Accessories Powered by Network...
Any of these cleaners work very well at removing the smell from a jetted tub and the bacteria in the pipes as well.
Rod
US Parts Center
Mar 15, 2014 | Jacuzzi Home
I want to clean the jets in my tub they look mouldy
Cleaning your Tub
There are several options for cleaning the piping on a jetted bathtub.
The reason you have a residue on the bathtub surface when you are done bathing is because there is bacteria built up in the plumbing of the jetted tub. In order to remove that and reduce the amount of "yucky stuff" coming into the tub when using it, we recommend a regular usage of a jet cleaning product about once every couple of months
Here is a link at the bottom to the cleaning products I can find right now. There may be others out there that I am not aware of but I do know these products work well in all jetted bathtubs.
US Parts Center
Feb 27, 2014 | American Standard 9330.014 Adhesive Bath...
How to start the jets on an MTI FURO MTDS 59
Checking the circuit breaker for power to the pump is obvious however the control that turns the bath pump on/off may be the real problem.
MTI has what control box to operate the pump?
Check there first because that may be the problem before the bath pump is a problem.
We would need to know the model number of the bath pump and the control box if there is one that the bath pump plugs into.
Rod
US Parts Center
888-521-6183
Mar 11, 2013 | MTI Furo MTDS-59 AST59
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
Maxx jetted tub quit pumping water, pump motor just races.
When the bath pump runs and you get no water going through the jets in your bath Jet trim then the impeller has probably spun off the shaft of the motor.You will not know if this is the case until you take the bath pump out and remove the front cover of the bath pump and check the impeller.If this is the case it usually has to be replaced.
Rod
US Parts Center
888-521-6183
Feb 22, 2013 | Home
Motor work but jets do not operate
You can hear the pump come on but get no water through the jets?Is the motor running or is it just humming
Feb 10, 2011 | Jacuzzi 9235-959 Nova 6 Whirlpool Bath 6'-...
I have the zuma whirl pool tub. the jets go on
This is an automatic feature to dry out the pipes and prevent mold. The next time you turn on the pump after leaving these tubs for a few weeks you get lots of black **** in the water and this is what this feature prevents. Sounds like the tub is working fine :)
May 23, 2010 | NRS Zuma Tub Only - R7236T - Standard
Whirlpool bath jets
open the side panel and there will be a sticker on or near the pump with all the info
Dec 23, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Jacuzzi bath
Many time leaks around pumps are a simple o-ring that needs to be cleaned and/or tightened. If the jets are leaking from the back side then the jet will have to be removed and resealed.
Good Luck, Phil
Oct 06, 2008 | Jacuzzi Signa 6 Whirlpool JAC-B540...
Whirlpool 5"x36" White Bathroom Drop-in  Bathtub Spa Jet Logo
237 people viewed this question
Top Whirlpool Home Experts
Donni Steen
john h
Mike
Are you a Whirlpool Home Expert? Answer questions, earn points and help others
