Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
Brushes won't engage
When I press the button to engage the brushes, nothing happens.
  • 22 Answers
Sounds like the brush belt is broke
Posted on Feb 09, 2009
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Vax match won't discharge solution or water
please see the videos for troubleshooting and help:
http://support.vax.co.uk/help-videos
God bless you
Jul 24, 2012 | Vacuums
Dyson Dco7 animal not picking up from floor. Checked all connection valves and cleaned filter and brushes. Also check tube for cracks and nothing there. Wand suction is great just almost non on floor...
I would check the "U" shape tube under wand that goes under body of machine. There is a button to release it. I would also check to make sure that your brushes are spinning properly. When you tip the vacuum back the brushes engage. Carefully place your hand on the brushes to see if they stop. If they do then your belt is stretched and you need to replace the clutch assembly. That part is not an easy fix. You can also check the tube that leads from the bottom plate to the housing. It will pop off at the housing with little pressure. Those are the most common places to check. Good luck
Aug 16, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Jun 20, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
My brush assembly fell off!
They lock into that blue arm with the two holes in it. The erm is plastic and has the spring loaded latches that hold the brushes in. If the latches have failed the brushes won;t stay in. The other option is the latch pins on the brushes have brocken or worn out. Turn the machine over and try to make the brushes latch, also push the brush release buttons several time to make sure they are working. Good-luck.
Kirk Thompson
San Juan,PR
Aug 29, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
6 rotating brushes
When you turn on the Vac with the brush strip NOT installed does the part that engages the brush strip turn at all? If so, when you install the brush strip see if the will turn when no pressure is applied to the brushes (tilt the Vac back). If none of this works, then the switch that engages the brushes when the unit is not fully upright may be broken. If the part that engages the brushes turns but won't turn when the brush strip is engaged then one of the parts that mate up it most likely stripped. Let us know what you discover!
Aug 23, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
151 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
