The fan is blowing out rather than drawing downdraft...the hole cut in the floor do not allow me to just turn it...help
SOURCE: installing downdraft venting
Richard, you should be ok, you may want to check it periodically to make sure that grease isn't building up in the low spot... You are adding a couple of bends, but it should still draw well.
SOURCE: Is there a vent cover for the downdraft vent. The
not that I know of but the fans on these ranges usually have multiple speeds. Try using the lowest. The fans are very strong on them. Hope this helps. good luck.
