Question about Maytag Neptune MAH5500B Front Load Washer
Waher over fills
Washer over fills have to open door to get water out
  • 20 Answers
Get a new washer, do away with the mold machine!
Posted on Feb 13, 2009
Maytag Centennial washer mvwc400xw0 washer won't fill
It could be the door lock, the water valve, screens on hoses and valve, or the drain pump
Nov 05, 2017 | Maytag MVWC400XW - CentennialR...
Washer turns on and stays filling water and does nothing else
If your machine fills but does not start the agitation cycle, the limit switch which detects that the lid is closed is probably defective. (Same as when the machine is washing, but you open the lid and it stops.) It's an inexpensive part to replace.
Aug 31, 2012 | General Electric Washing Machines
WASHER KEEPS FILLING .WATER ALL OVER FLOOR.
If the washer keeps filling even after being turned off and pulling the plug then you have a bad water valve.The water valve is the part where the hot and cold hoses hook to the waher.Once in awhile you can remove the valve and clean it out and it will work, if not then you need to replace it.Hope this helped.
Jun 24, 2011 | GE WWRE6260D Top Load Washer
Washer filled with water...will not agitate or spin or drain
You may have a bad or broken lid switch.The waher is thinking that the lid is open.
May 02, 2011 | Washing Machines
Code F 33 on whirlpool duet waher. Sevice guy
i think that has to do with not filling .. does water enter machine. is it filling slow?
Apr 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My machine is not aggetating it just keeps filling with water
if the water is not over flowing on the floor.make sure your washer is off,then pull the drain hose up to the level of the back control panel you should here water flowing out once this stops.keep the hose up for aminute and restart your waher and it should fill up to the proper level and shut off and start washing
Sep 26, 2009 | Maytag Legacy Series Top Load Washer
Water
If you say new is that brand new or a few months old
Take off the water connection at the rear of the machine and check the filter which inside the valve opening. (Turn the water off at the fawcet first and switch the machine on as if to do a load which should reduce any pressure in the pipes , just in case put a cloth around the connector when you unscrew it).
If that is clean call the company out as it is probably a failed fill valve
Jul 01, 2009 | Whirlpool GHW9100L Front Load Washer
My washer fiils with water when its off.
the solonoid on the fill valve is stuck open. you can take the valve apart and see if there is any sand or small pebble blocking it from closing. if so, clean it and re-assemble the valve and test it. if that does not fix it, you will have to replace the fill valve. it is not difficult to replace the valve. let me know if this solves your problem. shane
Jun 19, 2009 | Washing Machines
Whirlpool Duet washer leaking during clean washer cycle
the highest water fill cycle for your waher is the clean cycle.it will fill up with 2x the normal amount of water in this cycle than any other.look for a cut or wrinkle in your door boot(grey rubber outer ring that seals between door and boot)if you find one,only fix would be to replace door boot.also clean inner door glass that comes in contact with door boot ring,any hard water build up or sediment(dog,cat or human hair)will break the seal and allow it to leak.good luck
Sep 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Waher
ckd pump lean washer back against wall pump next to front ..2 clips hold pump to motor 2 clamps on hoses pump slides off motor ..also ckd hose from pump to drain underneath
Sep 10, 2008 | Roper RAX7244KQ Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
27 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
