Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Water heater with electonic igniter will not work in power outage
Is it possible, safely, to bypass the igniter and have hot water during a power outage? It is a gas water heater and the gas flow is not interrupted, only electricity to the igniter is affected.
  • 1 more comment
  • garyhwhite Feb 08, 2009
    It is a Rheem 21VP50-1 heater
  • Anonymous Mar 20, 2014
    I have gas and electric power but steel water heater is off American standar is the brand
  • 34 Answers
What type of heater is this? I need to know the model name and make and then we can go threw the process of how to do it. Most gas heaters do not have power to them and I only know of a few tankless heaters that do.
Posted on Feb 08, 2009
  • bigslimaba Feb 08, 2009
    Ok looked at and no one this type of heater it can not be bypassed. Sorry ....I will most likely result in a fre or other major problem...you a had to have one of the few heaters that you could not bypass the igniter.
  • Rheem Master
  • 1,819 Answers
There are super efficient gas water heaters that do require power to work for two reasons, 1. to ignite the gas, and to exhaust the gas using a power motor/fan exhaust system. very efficient but need power to work. and there is no bypassing.
Posted on Apr 20, 2016
    Welcome Back:
    Visited the website for 2 consecutive days.
It is flo gas superser it's call.nothing else I can find on this heater.the switch on top don't work I try a lot to start again but not working.
Posted on Apr 16, 2016
Ihave all valves open on hot water tank not getting hot water
If it is a Gas water heater, check the pilot and/or the igniter. If it is an electric heater, check to ensure the the power source is available. If power is available, it could be the thermostatic controller or possibly the heater elements are burned out.
Mar 13, 2015 | Water Water Heaters
I get a c2 11on my rheem ptg2-42pvp remote and intermediate ignition and have done all tech advised steps
1) Before calling service technician, open following links for Rheem tankless troubleshoot resources including Rheem chat, contact, phone, general maintenance manual:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
2) Error codes are start point for troubleshoot.
C2 11 is 'no ignition' and can include air in gas line, bad solenoid valve, loose wires, incorrect polarity on electric outlet, bad grounding, bad igniter, etc.
Multiple error codes can mean PC board failure, so far it appears the board is not the problem.
Next step is testing gas pressure, and testing parts to see where exact problem is located.
Cause can include multiple issues.
3) If technician has already given preliminary help, contact Rheem for name of service technician qualified to test parts, or possible help testing parts yourself. 1-800-432-8373
4) There is no perfect water heater, but non-electronic tank-type are less maintenance, cheaper in long run, easier to fix yourself, and hot water is available in power outage.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
5) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 30, 2011 | Water Heaters
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
Pilot light keeps going out during hot days
Solution is probably better ventilation to gas water heater.
On hot days, heat and lack of ventilation can cause pilot outage.
Hot air causes oxygen molecules to move farther apart, and combustion is no longer supported so pilot goes out.
Open following links:
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Jul 04, 2011 | Rheem Water Heaters
How can I wire a WH40 timer to a tankless water heater with 2 9kw elements? 240v 75amp 18kw. I do have # 8 AVG wire and 2 double breakers 40amp each. Tank you
You probably could but my question would be "why?" Water heater timers are made to turn power off to waterheaters during the times that we dont need hot water, like in the middle of the night or while you are at work. This keeps the hot water heater from working during those times and wasting energy (gas or electric). Tankless water heaters already have this builtin because they only work when you actuallty turn on the hot water. If the hot water faucet is not turned on, the tankless heater never comes on. It does not use a bit of energy until the hot water is actually turned on. So it will not be using energy during the night or while you are at work. So there really is no reason to do what you are thinking about unless you have another reason that I cant think of. Tankless heaters are great and this is why they save 60% of energy of conventional tank heaters.
Mar 27, 2011 | Intermatic WH40 - Water Heater Time Switch...
Our Rinnai tankless water heater is producing water as hot as pre
Power outage will reset Rinnai unit to that temperature. Read manual for more info.
Nov 28, 2009 | Rinnai Water Heaters
My rv water heater ignites, I have a steady flow of water in the sinks from the hot water spicket, but no hot water. The bypass valve is positioned paralllel to the cold water valve. I am not sure of the...
If your lighting and not getting hot water then you have a valve closed or your by pass is in the wrong position, if it is burning on gas it will heat water
Sep 06, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
601 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Mike Cairns
Mike Cairns
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
