Question about HP Office Equipment & Supplies
HP C6150 All in one won't feed paper from main tray.
Error message says that tray is out of paper (its full). If I shove the tray in and out and hit OK it usually works.
I did fix it. Please sign up for my Premium Assistance Plan to find out how!!!!!!
Posted on Feb 09, 2009
HP P3015N tray two paper pickup issue
Issue is worn out feed rollers. There are three. One in the tray itself and two after you remove the tray. Look up into the printer from where you removed the tray and replace those two rollers
Jan 09, 2013 | HP LaserJet Enterprise P3015d BW laser...
Paper feed error message. spits it out fast and
Your printer has a fail safe mechanism that pushs the paper that it's processing out to prevent any other jams during the printing process. Your rollers must have something jamming it's movement during printing. You will need to open the printer through the panels on the back, front, and side to ensure that you see the rollers and remove any paper or debrise blocking hitched on the rollers or in the printer. You may also want to ensure that the holders on the sides of the paper tray where the paper comes in are lined up correctly. Also, make sure not to pack the paper tray to capacity. Only use the tray half full.
Nov 29, 2009 | HP Designjet 70 InkJet Printer
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
Brother HC4040CN displays error message NO PAPER even though paper tray is full. Will not feed paper from Main tray.
The paper sensor flag above the paper tray on the printer chassis is either stuck or has broken of. You need to take the printer for repairs.
Aug 04, 2009 | Office Equipment & Supplies
What is message: 41.3 paper error ?
Hi there
41.3 on a lj 4+ is a paper Feed related error normally caused by dirty or worn paper feed tyres if you are getting this error whilst feeding from the paper tray at the bottom of the printer stack a few sheets on the manual feed tray on the front if you dont get the error
clean all your feed wheels or order a service kit and replacement replacement tyres
Regards AL "alstech"
Jun 07, 2009 | HP LaserJet 4 plus Printer
Error message on 4050n printer "manually feed hp tough letter"
What error message is on the display?
To solve one common problem, try this: Take out the paper tray. Slide the blue fence at the back away from the paper (toward the back of the tray) then slide it back to the correct position for the size of the paper. Replace the paper tray and see if the error message still appears.
Jan 20, 2009 | HP LaserJet 4050n Printer
"Out of paper" error message
i would try clening the paper feed tires and roller and if that dose not work i woudl replace them.also pull the paper tray out adn look in top of the printer where the paper feeds out of the tray to see if the is a peice paper is blocking the sensor that reads that the printer has paper.
Apr 03, 2008 | HP Photosmart 3210 Printer
Out of Paper. Load Paper Error
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
99 people viewed this question
Ben Johnson
