My 3 Crest Audio CA9 bought in 1997 have had protect problems : after some minutes of perfect work, the protect stopped one channel. It happened in 2001, just after the end of the warranty.
Crest Audio has issued a retrofit kit to replace SMD input board by a standart-components one, it costed me several hundred of euros each to fix this problem.
Now the problem reappears. In the service manual the solution is "change preamp board". AGAIN ???
These amplifiers are not reliable at all !
So my question is : has somebody the service manual for this CA9 upgrade ? Or can you help me to solve the problem ?
Thanks,
Bernard
If you are bridged in parallel instead of in series the amp wont support the load so it turns the power protect on till the amp cant handle nomore then the amp will go if you have two subs bridged run them left speaker possative to to the amp possative for bridged mode then laft speaker negative to the right speaker possative then right speaker negative to your amp negative for bridged mode if you have them left and right speaker possative to amp possative and left and right speaker neggative to your negative to your amp thats parallel the ampwont support the 2 ohm load
Dust in the unit - clean with Canned air like a computer.
or Delamination on the printed circuit board.
Don't forget to clean all contacts on the backside of the unit!
If cleaning doesn't work - head to the local Crest "AUTHORIZED" Service Center.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
thanks mlufkin84
The problem is that I've NEVER use my amplifiers in bridged mode. The problem is on the preamp board - all clues I've found match the service manual, but this service manual is for the original CA9 and not for this upgraded model.
Bernard
Well, I've found the schematics on the crest audio website :
http://www.crestaudio.com/media/schemati...
after some hours, my CA9 is OK ! :-)
