Question about GE 29875GE2 Digital Answering Machine
Answerer responds after only 1 or 2 rings.
How to I extend the time so the answerer does not come on so quickly?
I am an 83 year pld and I have a ge answering machine and i want to extend the number of rings from 4 to 6
the model number is 29875ge1-b
the serial number is 61794103
it is a digital messaging system
other info on back of machine is atlinksusa inc
Posted on Mar 01, 2009
How do i change the number of rings before it goes to answering machine. We would like 5 rings instead of 3. Also sometimes when people call in it says our system is not set up yet.
Make sure the answering system is ON.
Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
Press key [9] to enter Ring to Answer menu on handset.
Use the CALLER ID-VOLUME (up/down-arrow) button to choose 5 rings.
You can download the manual here.
Feb 06, 2011 | GE 25942GE2 Cordless Phone System
Set number of rings
If you have the Digital Answerer in White with Extended Recording Time TAD-3808, then slide the Ring Select switch on the right side of the unit to the desired number of rings. TS = toll saver and answers after 2 rings if there are new messages; , otherwise, it will answer after 4 rings.
All of the Radio Shack answering machne manuals can be accessed here: http://support.radioshack.com/productinfo/ProductResults.asp?Name=Telephone_Answering_Devices&ID=002004 .
For the 3808, see http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3808&Name=Telephone%20Answering%20Devices&Reuse=N for the manuals.
I hope this helps.
Jan 15, 2011 | Radio Shack 3808 Digital Answering Machine
How to set number of rings before answering turns on
http://www.home-electronics.net/USER-GUIDES/26992_DOM_EN_CL_IB.pdf
Jun 10, 2010 | Uniden Cordless Phone
GE answering machine 29870 How do I change the number of rings beffore the machine picks up
SETTING THE RINGS TO ANSWER
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET to enter
the incoming message length menu.
Mar 24, 2010 | GE 29870GE1 Corded Phone
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
Wanted to know if i can check messages by calling in
CLICK HERE for the user manual.
The following is on Page 19....
REMOTE ACCESS
You can access your answerer from any touch-tone phone
by entering your 4-digit security code (the default security
code is 0123). The remote functions do not work with rotary
or push-button pulse-dialing phones. You can cut out the
wallet-size remote card near the back of the User’s Guide
so you know the touch-tone commands when you're
picking up messages from another location.
To access your answerer:
1. Call your telephone number.
2. After you hear the beep that follows the greeting,
enter your 4-digit security code. To bypass the
greeting, you can enter your 4-digit security code at
any time while the greeting is playing.
3. The unit plays the remote menu after the correct
security code has been entered. Menu selections can
be made at any time while the menu is playing.
NOTE: The unit answers on the 10th ring when it is
turned off or the memory is full. To access the
answerer, enter the 4-digit security code after the
beep. If memory is full, play messages and erase
some of them to restore memory. If the answerer is
off, press 2 to turn it on.
NOTE: After the unit plays the remote menu, it will
wait several seconds for a command, then disconnect
Thank you for using Fixya - a FixYa rating is appreciated!!
Jan 28, 2009 | GE 29869GE2 Digital Answering Machine
Answerer won't pick up
i lost the book how to put numbers in memory.
Dec 08, 2007 | GE 29897GE2 Corded Phone
Cordless Phone
You did record a message on the answerer, didn't you? Mine displayed that until I recorded the outgoing message for the answerer. You do not need any service from your phone provider. The answerer in the base unit simply records the caller's message when you don't answer after a set number of rings. The manual tells you how to name the handset, which is a nice feature if you don't wish to use "unit 1, unit 2, etc".
Aug 28, 2007 | GE 28112EE2 Cordless Phone
GE 29875GE2 Digital Answering Machine Logo
383 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
