HDMI input issue with a Samsung 52 650 LCD, Yamaha 663 7.1 reciever HDMI issues, Scientific Atlanta Digital HD Cable Box I recently had to unplug my Samsung Reciever from my Samsung LCD and cable box. When I reconnected and rebooted everything, I was unable to make a connection via the HDMI cable. LCD only gets snow which itermittenly turns on and off, on and off; sometimes there is a picture instead of the snow, but its very red and just truns backto the on and off snow. TV does this as soon as I connect the LCD to the Reciever via HDMI only. When I connect the LCD via HDMI directly to my cable box and hook up the Reciever with analog cables, the system functions ok. I am assuming it is a setting or compatability option? Can someone help ?
  • 2 more comments
  • jdiraff Feb 08, 2009
    I am not sure that really addresses my issue
    Thanks
    When you say component , you mean the reciever ...correct
    yes, but it was working fine until I unplugged
    it
    Someone suggested disconnecting everything for 20 minutes
    I will try that
    Im sure my Samsung LCD is compatible
  • 10,594 Answers
Please Reassigned HDMI to units by going in to TV MENU.
Above procedure will reset HDMI settings and relocate all units hooked with TV.
Posted on Feb 08, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..HDMI ia kind of cable connectivity cable which
boost u with extra clarity.Some tv comes with HDMI
support whereas some doesn't support.so it is a kind
of compatibility available in the television.
check it out..
thank u..
  • 679 Answers
There is a cable for that kind direct connection.
  • rockfixya
    rockfixya Feb 08, 2009
    Only fixes are: disconnecting HDMI cable (SDTV signals restored immediately) or connecting HDTV via component jacks (no SD-composite blocking at any time).
    SD output via composite connectors should never be blocked if HDMI device is powered off.
  • rockfixya
    Use...DVI (Digital Video Interface) connectors, found on some graphics cards, are used for sending video signals digitally to screens with a suitable interface. They bypass the needless and potentially quality-reducing digital-analog conversion process.
    The DVI interface, however, is soon to become obsolete, with the release of the HDMI interface.
  • 19,396 Answers
Unplug everything from main, wait ten minutes, then plug devices back to power.
  • Ginko
    Ginko Feb 08, 2009
    This is not a settings problem, settings get reset if you unplug from power, the problem is probably because you unplugged or plugged back HDMI cable with the devices on.
    This can jam or damage the HDMI signal board (Input plate) on one of the devices.
    Just in case start checking settings, set resolution to same value on both TV and receiver.
    If that did not work, then reset settings by unplugging everything for ten or twenty minutes.
    If still no luck try a different HDMI port on tv, and even a different cable if you have one.
    If all the above did not fix it, then you have probably blown one of the capacitors on the HDMI signal board, and the component must be replaced.
  • Ginko
    Ginko Feb 08, 2009
    Nope components are those tiny things mounted on circuit boards inside electronic devices, like ICs, resistors, diodes , capaciors etc.
    My suggestion is quite simple:
    Do a general hard reset first, by unplugging both TV, DVD and receiver , waiting ten minutes and connecting everything back. This will drain power and reset devices.
    After startup, check display settings on both TV and cable receiver, set everything to 720 Dpi to start, this setting is supported by both devices.
    If still no luck , try a different HDMI input on TV.
    If still no joy, there is an internal fault either on TV or receiver, both must be tested with different devices using HDMI connections, in that case it is better calling the number listed on the owner manual.
HDMI signal cuts out for a few seconds constantly from receiver to television. It does it when switched to cable box and the roku box. Onkyo TX-SR606 Scientific Atlanta Cable box thru HDMI Roku Box...
Mine did the same thing where the screen would go black for a few seconds and then the picture and sound came back. I would try (1) switch HDMI cables, (2) try a different HDMI input in the back of the receiver, (3) try different input in the back of the TV. None of these seemed to work with mine. I finally ended up running the cable box direct to the TV and only run the audio through the reciever via coax or digital. No more problems. I think the HDMI inputs in the back of the reciever have a problem continuously carrying the signal if it is the leaset bit weak.
Sep 08, 2010 | Onkyo TX-SR606 Receiver
I would like to hook up my components without having to turn on the receiver to watch tv from DVR or Cable if possible. I have Scientific Atlanta Explorer 8300 HD Cable DVR w/HDMI out, Samsung TV w/HDMI ,...
You should not lose any picture quality from the DVD player. I am currently having the similar setup with PS3 as the Blu-ray DVD player with HDMI and a Samsung DVD as regular player with component cable to a Samsung LCD TV. Remember the quality on Blu-ray is better than normal DVD so don't expect more than what it is.
Oct 07, 2009 | Yamaha RX-V463 Receiver
Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Apr 12, 2009 | Onkyo TX-SR705 Receiver
Want to add all of my video components to my rxv 663 reciever
The rx-v663 has 2 hdmi inputs, and 1 HDMI Outputs, The way I would run is 1 HDMI in dedicated to the Blu-ray, This will do the audio HD True digital, DTS-HD , then video out to the TV for HD 1080p resolution, On the cable box out do you have an HDMI 1.3? If so sport it to the other available receiver HDMI IN, net the same in/out as the blue ray, minus a 1080p result video which will only happen Blu-ray, cable will result 1080i HD and audio HD will vary with the signal broadcast format.
Feb 01, 2009 | Yamaha RX-V663 Receiver
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Off Air?
The Scientific Atlanta box was a cable box and recieved CATV signals. The Direct TV box is satellite only. You might check if it has a built in ATSC tuner for off air digital signals. Direct TV in most locations offers the major networks in HD format.
Jan 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
HDMI connectivity
what does the error message say?
Dec 01, 2007 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
