I have a Panasonic TV/DVD/VCR Combination - PV-DF2004 and the DVD tries to read the disc and then says it does not recognize the disc and to put in another. I have tried using a head cleaner and blowing out any dust without success. Does anyone have any idea of what I would need to try for the next step. I had put it on Craigs List for $75 and when I found out the DVD did not work, I reduced the price to $50, but if I can fix the problem myself that would be a better solution. If anyone can help me with this issue, I would be most appreciative or if you need more information to solve my problem, please email me. Thank you. CJ
Comments:
Feb 08, 2009
- Appreciate your prompt response. If I had to purchase a laser unit, do you have an idea what the cost maybe and whether it would be worth it on a 4 year old TV.
hi..if a lense cleaner dont solve the prolbem then you can replace the laser unit itself if that type of cleaning also dont work means and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got stucked sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont shake the device too much it should be quite hard to push any way when you push back to middle try a disk but please make sure you dont touch anything while device is it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning.. if its not spinning then ur laser unit is damaged..
thank u rate me
Comments:
Feb 08, 2009
- ya its absolutely worth buyin a new laser unit... its of meager cost only...
Was this helpful?
Yes
No
Popular Solutions for GoVideo VR3840 DVD Recorder /
I have a Go Video DVD Recorder/VCR Combo (Model VR3840) that freezes at exactly 4 min 8 sec on...
(More)
I have a Go Video DVD Recorder/VCR Combo (Model VR3840) that freezes at exactly 4 min 8 sec on recorded DVDs. How can I fix this?
When I power up my VR3840 Combo machine it says "please wait" and after about a...
(More)
When I power up my VR3840 Combo machine it says "please wait" and after about a minute then shuts down. I can't open the DVD door. I've tried to manually open the door as suggested in one of the posts but there is still no success. The DVD drive seems to respond to DVDs, but does not fully start up or show anything on the TV. Can you help me?
When I power up my VR3840 Combo machine it says "please wait" and after about a minute...
(More)
When I power up my VR3840 Combo machine it says "please wait" and after about a minute then shuts down. I can't open the DVD door. I've tried to manually open the door as suggested in one of the posts but there is still no success. The DVD drive seems to respond to DVDs, but does not fully start up or show anything on the TV. PLEASE HELP!!!
My remote for my VR 3930 was inadvertently trashed. I can't find the code to allow me to use a...
(More)
My remote for my VR 3930 was inadvertently trashed. I can't find the code to allow me to use a universal remote. Con you help me find the code?
I've had the DVR set to the local PBS channel for over an hour and it hasn't reset the clock. The...
(More)
I've had the DVR set to the local PBS channel for over an hour and it hasn't reset the clock. The setup is set to Automatically set the time.
