Question about E-Machines eMachines Desktop PC
Disk drive I bought a new E machine and the disk drive keeps opening and shutting on its own how can I fix this
  • 2,404 Answers
Sounds to me like there is something stuck in back of the drive that is preventing it from staying closed properly. To fix that type of problem you would have to take the drive apart. There is 4 screws on the bottom of the drive, unscrew those screws. Unclip the front cover of the drive which the clips are located on the sides of the drive, the door will come off then you can take the top off.
From there you look to see if there is any debris and remove it, then put everything back together and hook the drive back up to the computer and test it to see if the drive will open and close when you want it to and not by itself.
It could also be just a bad drive, easiest thing would be to replace it but if your handy enough you can try the method I explained.
Posted on Feb 08, 2009
Needed is an operation manual "how to" for HGST Touro 4TB external hard drive machine just bought. Want to know how to transfer files from computer to external storage?
FIRST the short ANSWER; Open Windows Explorer and drag and drop files/folders to new drive.
LONG ANSWER; Connect drive,during boot up of PC, and ENTER (CMOS) SETUP. See if drive is listed.
IF LISTED resume boot and see if Windows FINDS new Hardware and installs it. If so go to short answer.
If not seen by windows but seen by CMOS the drive must be PARTITIONED and then FORMATTED. OR
IF disk came with install CD run install to assure all needed USB drivers are present for windows to install disk through USB port.
Once USB drivers are installed reboot PC and see if Windows finds new hardware.
IF windows still does not install new HD but CMOS shows drive is present, the drive needs to be partitioned.
To partition new drive type DISKPART at dos prompt or in START RUN OPEN and press enter.
At the DISKPART> ( prompt ) type LIST DISK then press enter.
Example: DISKPART> LIST DISK press enter
FIND the number assigned to the new drive in the list (#), then type SELECT DISK #
Example: DISKPART> SELECT DISK 2 press enter
the info returned in the dos window should be;
Example: Disk 2 is now the selected disk
Type CREATE PARTITION EXTENDED
Example: DISKPART> CREATE PARTITION EXTENDED press enter
Now shutdown the PC then reboot. Windows should now Find hardware and install new disk.
Click START then COMPUTER the new disk should be listed.
Right click on the Drive and select FORMAT use NTFS format.
now you should be able to drag and drop files/folders to your new disk.
Oct 16, 2013 | Computers & Internet
I cant download op cd
If the new hard disk is a SATA hard disl then the problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Feb 18, 2012 | Computers & Internet
Virus notice keeps popping up and unable to open any programs. i have had downloaded McAfee anitivirus and cannot get it to open
You require Norton AntiVirus from a disc as a clean boot will be required due to the virus "hiding" in the RAM.
Feb 05, 2011 | E-Machines eMachines Desktop PC
Hello! I dropped my Lacie Brick (300GB, the blue one, bought in 2006 - that's all I can remember, I don't have it here right now) and now, of course, the HD is broken. I lost my data, but I've been...
If the disk-drive was LARGER than 500GB, it definitely would be a SATA drive; nobody makes IDE disk-drives larger than 500GB.
How about getting your friend to help you open the case?
Given that it is four years old, it probably pre-dates most SATA disk-drives.
Or, take it to a computer-store, and have them open it, and sell you a brand-new (and thus more "reliable") disk-drive?
Oct 17, 2010 | LaCie BRICK (301063U) 300 GB Hard Drive
My pc shut off and now it is asking for restore disk 1 version 3.0 but I am not sure where to purchase this because when I got to the web site, it keeps bringing me to recovery disk. Help
Restore disks are unique to each machine so they should have come with the PC when you bought it. If you never got them contact the manufacturer and/or retailer were you bought the PC. If you can't get the restore disks you may have to do a full Windows reinstall.
Jan 19, 2010 | E-Machines eMachines Desktop PC
Won't format new DVD-RW disks
i did everyting today to fix this. bought new dvds, name brands different, tried finding codes, called the number. trust me. try this. clean it. thats All i did. cleaned it with a dvd cd cleaning disc, the one with two little brushes on it, nothing special, ran it until i heard the beep, popped my dvd in, they all worked. everyone, im still recording. i ran it about four times. now, if you tried to burn a dvd, and got the error, throw that dvd away. because i tried about ten dvds. after i fixed it, THOSE dvds were no longer usable. dont know why. hope this works.
Sep 18, 2009 | GoVideo Go Video VR3840 DVD Recorder/VCR
Won't read a disk keeps saying reading then open tray
YOU NEED TO REPLACE THE LASER THAT READS THE DISCS IN THE DRIVE COSTS ABOUT £40,
HAD THIS PROBLEM MYSELF!
please rate me :)
Jul 27, 2009 | Microsoft Xbox 360 Console
Keeps telling me to open the tray whenever I put a game into it..not reading any disk
you re going to need a new disk drive i had the same problem and called 18004myxox and they said its a bad disk drive and would cost 100.00 to fix so i went and bought a new 360 insteadf
Apr 17, 2009 | Microsoft Xbox 360 Arcade
Problem with disk drive A:
First, you should try to keep the floppy drive. If you can find one, I highly recommend getting the floppy drive cleaner diskette. They're hard to find now, but it's worth it if you want to continue to use your floppy drives. If cleaning it doesn't resolve the issue, next item to try is replacement of the floppy drive. You can borrow a floppy drive from someone, plug it in and test to side if it fixes the problem, if not, then it's either a motherboard issue (which I doubt) or a software/windows XP problem (more likely of the two). In which case I would recommend reinstalling windows XP to see if it fixes the problem before shopping for a new motherboard or a new computer.
Good luck
Jun 29, 2008 | Dell Dimension 2350 PC Desktop
Desktop problem
maybe a dead cosm battery.
May 17, 2008 | Computers & Internet
E-Machines eMachines Desktop PC Logo
42 people viewed this question
Top E-Machines Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
