Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Under a window
Can I install a cooker by a window
  • 59 Answers
By a window is fairly vague? How close would it be? the only concern would be that the heat (if there would be any) would cause a Insulated window (double pane) to fail (fog up)
Posted on Feb 23, 2009
I cannot set the clock, what could be wrong?
You don't give any info what cooker you have or where you live
If you live in UK then contact the dealer where you bought from as its under guarantee, sounds like a fault clock unit
( also try leaving your cooker off at the mains for a few mins, then try again, make sure you holding down the correct buttons) good luck!
Oct 20, 2014 | Ovens
My cooker I had delivered lastThursday does not work
You will have to contact the place you bought the new cooker from. There can be problems with warranty if you did not have it installed by a qualified technician as required by the manufacturers. Some more information on what is the model of the cooker and where you purchased from might help with providing any additional guidance on your options. Also a description of the problem might help.
Sep 15, 2014 | Zanussi Ovens
Bush AE66DCA cooker main oven wont come on
Hi guess you would have got your cooker fixed or replaced by now but I thought I would comment as we have had the same problem.
First I checked the bulb inside the cooker to see if there was a fault but the bulb was intact, I then checked the cooker over visually inspecting suspect broken parts I noticed the Thermosat control (3rd in from left hand side) wasn't turning properly so I ordered a new one. Couple days later it arrives and I remove the old switch and replace (very simple task) once the cooker is apart I get it all back together and it still doesn't work. So I grab my multi tester and perform a continuity test on the elements which proved to be normal range (43ohms was the reading). I was stumped. I began checking the whole cooker wiring and checking everywhere for a fault. After some time I notice a abnormality inside the main cooker control (2nd from the left hand side). Under closer inspection I realise one of the brass pins and spring has dislodged and no longer giving an electical connection. After ordering a new switch I stripped the old one and replace the pin and spring and rebuilt for a temporary fix. Rebuild the cooker and hey presto it works. Couple days later new switch arrives so I changed them over. Touch wood nothing else goes wrong but there's not much to them once they are apart.
Hope this helps others with their problem.
Feb 03, 2014 | Ovens
How to wire a cooker
If you don't have the instruction on how to do and you don.t seam to be an electrician so I would let an expert wire the stove for you. You could electrocute yourself and cause a fire.
Mar 28, 2012 | Ovens
Do I need a fan for exhauting air from the kitchen when I use a Sunfire gas convection oven?
The oven burns using a gas and oxygen mix , if the room is airtight the oven will go out and you will suffocate.
All cookers should be used in a reasonably well ventilated area which can include extractors and open doors or windows.
This environment gives the cooker enough air to work with and clears cooking smells from the room
Extractors are optional but good ventilation is crucial.
I
Mar 04, 2010 | Ovens
Fitting neff double oven cooker purchased from display at mfi
Go to this site here.
http://www.neff.co.uk/ovens.html
You need to register the oven under My Apliance to get the manual
Good Luck
Please rate FixYa!
Dec 19, 2008 | Neff U1721 Double circotherm Electric Oven
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Jul 27, 2008 | Baumatic B904SS Stainless Steel Electric...
Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Sep 08, 2007 | Ovens
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
63 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
