Question about Homedics Health & Beauty
Homedics massager - want to take apart and fix - easy or not?
Hi.
I have a Homedics Professional Percussion Massager with Heat, Model PA-2H that stopped working. It has had a decent lifetime, many years, but I don't like to toss things without at least trying to repair them. However, I am at a loss for this one. Has anyone worked on one of these before? What should I look for when I take apart? Is there anywhere on the web that I can get images/diagrams to help me? Near the end of its working life, so to speak, I could hear something rattling inside, so thinking maybe there's a loose screw or connection.... not sure. Any help would be appreciated. Thanks! (P.S. Don't care much about the heat feature, just want it running).
I have a homedics home chair massager, no heating feature, that simply stopped running after many years. No symptoms, no drop off in performance. One day it worked, the next day it did not.
The wiring runs inot a circuit board so unless there is any easy fix to change the transformer (if that is the cause of the problem) then it certainly does not bode well fro a home repair, or any repair at all.
  • 19,396 Answers
I do not think the wirings for such a device are available onbline, you should call the factory to get a service manual before starting the repair job.
Posted on Feb 08, 2009
  • Ginko
    Ginko Feb 08, 2009
    Hi there , I can see tehre are two post in same question.
    My previous comment was an answer to the first post.
    If the problem is the power unit (transformer) that is easily replaceable, and even if this repair should not be done by the user for safety reasons, it can be done by any local electronic or appliance technician.
    The best way to proceed is finding a technician willing to do the repair.
    Then you ask the technician to test wiring and board at component level, better replacing a $1 capacitor , rather than the whole power board.
    If the technican cannot find the blown component, then you can contact Homedics to order a replacement power board. See links below:
    HoMedics UK.
    HoMedics US and Global.
  • 679 Answers
There is a service manual for Massage Model 2H-60>>
http://www.ionicfootdetoxify.com/pdf/6.pdf
hope this is helpful.
Thanks
I was given a homedics percussion action handheld massager with heat. It won't work at all. It does nothing!
Check that you have power and that there is a lit LED when a massage attachement is put into the top. Otherwise check this link for further instructions and power issues.
The 3 Best Handheld Percussion Back Massagers Under 50 Back Pain Relief...
http://back-pain-relief-products.net/handheld-percussion-back-massagers/
Feb 09, 2015 | Homedics Health & Beauty
Which heads to use for what
The Manual says the heads are color coded:
Black = Soft Massage
Medium Grey = Medium Hard Massage
Light Grey = Hard Massage
Red = Heat Massage
Jun 13, 2011 | Homedics Pa 100h Percussion Massager With
Massager Parts
Wow , I've never hear of wearing out the balls - I dunno.
Apr 17, 2010 | Homedics Pa 100h Percussion Massager With
Can Homedics Therapist Select? Shiatsu Pillow with Heat be used under 220 V power? Thanks
If it is set up for 110 volts, you should not use it on 220. Most likely you will burn the motor out in a matter of minutes.
Jan 24, 2010 | Homedics PA-4H Programmable Percussion...
How to replace power cord om homedics massager
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Jun 20, 2009 | Homedics Inc Massager Neck Massager W/heat
Can't disassemble massager.
I don't have the Homedics programmable, but I have taken apart my Brookstone programmable (and lots of old Homedics massagers).
I'm going to guess the screws concealment method is similar. On the under side of the massager, look for small oval-shaped outlines that are the same color as the rest of the body. Mine had four. These are little plastic plugs that you can pry out with a tiny flat screwdriver or a razor blade. The screws are hidden under these plastic plugs.
I hope this helps
Feb 23, 2009 | Homedics PA-4H Programmable Percussion...
Homedics programmable percussion massager with heat
The motor is Jammed
Try Taping it or banging it lightly
if that don't work im sorry ether needs repair or buy a new one
Regards; Aaron
Sep 15, 2008 | Homedics 10 Motor Back Massager with Heat
Hand held massagers question
The unit is not a toy and should not be used by children without adult supervision. Also, it is unsafe to use this product on adults and children while they sleep. You should NEVER use the massagers while you are asleep.
Aug 27, 2008 | Homedics PA-4H Programmable Percussion...
Health & Beauty Logo
3,192 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
