Question about HP Photosmart C5280 InkJet Printer
HP Photosmart C5280 - continually reinstalls the software.
I'm having problems with this printer. I have Windows Vista on my laptop, everytime I switch on my pc, the printer installs itself. Thus I can end up having 6 or 7 printers installed within a couple of hours. I just don't know how to get it to stop. There were problems with the printer causing other applications such as Word doc's to freeze and the solution was to make another printer the default one - which I have done. However, this installing the software causes my laptop to crash and not work until the software has run.
  • doggonet Apr 18, 2009
    Printer also keeps reinstalling itself. 90% of the time it will not print at all then out of the blue it starts printing. It doesn't tell me when it can not print or why. sometimes takes hours to print a one page document.
I have exactly the same problem. Found a solution onthe Microsoft forums:
"Checkpoint: Unhide Hidden Devices in the Device Manager, view the problem
devices and remove them manually from there.
This workaround is for an HP Printer, use accordingly:
1. When the Found New Hardware Wizard starts at startup of the computer,
click <next>.
2. When it asks you for the HP disk, (the next thing that will require a
response from you probably), click <ok>. However, do NOT insert the disk
into your CD-ROM drive.
3. On the next screen that comes up, there will be a button that is already
highlighted telling the wizard where to find the printer driver (which is
what it is looking for). This button will be pointing it at "other media,
CD-ROM,etc.
The trick is to DESELECT this button. At that point, the button for your C:
drive will become active and you can select the C: drive. It will also
probably be prompting you with the location for the already installed HP
printer driver that is somewhere on your C: drive. (If not, you need to
click browse and locate the driver).
4. After you have deselected the CDROM and selected the C: drive, click
<ok> (or <next>) The Wizard then makes a second copy of your printer driver
(and, by the way, creates a second "installed printer" in your Control
Panel/Printers). And then, the wizard finally completes and tells you that
you have successfully installed the new hardware.
5. On subsequent startup, the Wizard should then NOT run."
Posted on Feb 17, 2009
My laptop does not recognize the USB cable during a reinstallation of the HP Photosmart C5280 all-in-one printer. Yet, it recognizes the cable when I use it for another printer.
1) Do you have the drivers for the C5280 installed on the laptop?
Each printer (All-In-One) has to have it's own drivers.
The C5280 and the other printer.
Drivers are small pieces of software that allow the Operating System to 'communicate' with a device.
{Windows XP and Windows 7 being two examples of an O/S. The device in this case is an all-in-one printer ]
If you already have both drivers for both printers installed, post back in a Comment.
It would seem that if the USB cable works okay on a different all-in-one printer, that the problem is Not the USB cable, but the printer.
This is what draws me to conclude, that the drivers for the C5280 have not been installed.
Regards,
joecoolvette
Jan 10, 2012 | HP Pavilion DV6830US 15.4­ Laptop (Intel...
I have a dell computer and a hp photosmart c5280 it will not open the digital image monitor what do i do?
I have had some issues with hp software for printers. usually to make it work i had to do complete uninstall and reinstall and that was pain. Sometimes you firewall will block it or anti virus software. try to turn them off and try to open and if this does not work then reinstall it. Make sure you download latest software form hp site if available and not the cd since this sometimes can cause issues (Outdated drivers).
Mar 14, 2011 | HP Photosmart C5280 Printer
I would like to scan documents with my hp photosmart c5280 and save to a file on my hp laptop.How do I set this up ?
Try to scan using picture or media viewer like iview, windows photo gallery in Vista, or any other program you already have. Next, go to File menu of the viewer(software you use) and in the File menu choose Scan or Import from.. then choose Save as in the same File menu.
Mar 30, 2010 | HP Photosmart C5280 Printer
Have no installation disc for photosmart all in one printer need to use it it my laptophelp?
You can download software and drivers here
http://h10025.www1.hp.com/ewfrf/wc/product?product=3204464&lc=en&cc=us&dlc=en&lang=en&cc=us
Jan 01, 2010 | HP Photosmart C5280 InkJet Printer
I need a program disc for a hp photosmart C5280 all-in-one machine. I have a new computer and need to hook-up the copier etc. Is there one avalible and what is the cost.
go to HP.com and go to the support pages, type in your model number and you can download all the drivers and software foir your printer there.
Nov 11, 2009 | HP Photosmart C5280 InkJet Printer
Scanning to my PC from my HP Photosmart C5280 Printer
hi!!!!
try to check the port of your printer or replaced the usb port
Sep 20, 2008 | HP Photosmart C5280 Printer
HP photosmart c5280 PRINTER
go to web site and do download of software from there hp.com/drivers/sfotware--put in model number. especially true if using Vista. also ensure your setup when asked is for windows XP and not windows 98/2000
Jun 21, 2008 | Office Equipment & Supplies
Photosmart Essential Lockup
Hey guy don't follow thier suggestion. No one can't do anything for u r problem because Your H.P. inkjet Printer 3210 doesn't work with Vista. I am also faced same problem. It is technical problem. Just change your vista or Printer
Jul 02, 2007 | HP Photosmart 3210 All-In-One InkJet...
HP Photosmart C5280 InkJet Printer Logo
277 people viewed this question
Ben Johnson
