Question about Majesco Jillian Michaels Fitness Ultimatum 2009 for Wii
Jillian Michaels won't allow Wii Balance Board for weigh in
Wii Fit Balance Board is not being read by Jillian software though the balance board works fine with other applications such as Wii Fit.
Unable to use with Jillian Software to set up actual weight or as part of any exercise.
  • 1 more comment
  • wwgurl May 06, 2009
    mine won't read weight when I stand on the board. I've tried on hard surface and rug. My wii fit reads on both.
  • lilavie May 24, 2009
    I have the same problem...what is the fix?
  • Anonymous May 26, 2009
    the balance board will not read my weight and have no problem with using the balance board for wii fit... tried resettting and everything I could think of and nothing works
Actually, I had the same problem and discovered that you have to have the wii remote in your hand and that you must push the A button once you're on the board. Otherwise it just keeps telling you that you're moving too much.
Posted on Jun 01, 2009
I get to where you start new but i can type in my name but thats all i can do when i push enter it wont click down
Posted on Nov 01, 2009
When you are at the sart training screen and the picture of the balance board looks dim, click on the picture of the board and you will then be prompted to link up,
Posted on Apr 21, 2009
Do we need to follow some any diet plan along with Jillian Michaels Body Revolution Training System?
Every workout needs a diet plan to follow in fact it is important without a diet plan doing work out is use less. I've been following this Jillian Michaels Body Revolution Training System since a long time and in it they recommend a diet plan which we have to follow.
Source
http://productreviewandrate.com/jillian-michaels-body-revolution-complete-body-transformation/
Feb 06, 2013 | Majesco Jillian Michaels Fitness Ultimatum...
My wii balance board says it's working fine then won't weigh me it gets stuck in a cycle of checking it's turned on then trying to weigh me but it says "Unable to measure. Try again and remain still...
It may be that the batteries in the board are dying. If you ave not replaced the batteries recently, I recommend doing so. If it is the batteries, the board is trying to communicate with the Wii and can but cannot sent all the info about whoever is standing on it. It simply does not have enough juice.
Feb 28, 2011 | Nintendo CTA Digital WI-BBP Wii Fit...
The board keeps asking me to step off when I'm not on the board. It won't work with any game. It thinks it has someone on it when there isn't.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds.
good luck .
rate please !
Mar 20, 2010 | Nintendo Wii Fit - Balance Board + Game...
What do you do when your wii balance board keeps saying please step off me and press A
Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Mar 18, 2010 | Nintendo Wii Fit - Balance Board + Game...
Communications with the wii balance board interrupted
dont push your feet hard or the batteries might come off of the cap isnt put on or the batteries are fully used
Feb 12, 2010 | Nintendo Wii Fit for Wii
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
Wii Balance Board thinks I'm on it all the time!
Make sure of a couple of things and try again -
If you are on semi-shag carpet, try using the little foot extenders. They may not seem like much but they can help.
If you are on moderate to thick carpet, you may need a board to set the Wii Fit Balance Board on.
If you are on a wood floor, you can (but don't have to) remove the little foot extenders.
Another little gremlin can be in those silicone covers. If you have one, I'll bet that's the culprit. As nice as they are to keep the board clean, they can actually attach to the non-moving part of the scale (the bottom) to the moving (surface) part. Be sure that your silicone cover is not interfering with the normal movement of the board.
Finally, be sure that you are always using YOUR setting while exercising or it will not be calibrated correctly. Also be sure that when you start, you are not on the board when it calibrates for the first time after turning it on. If the weight on the board differs by about 5 lbs or more than what it thinks you weigh, it will pitch a little wii fit.
I hope you find this advise helpful. If not, though, please don't label this advise as "inappropriate". A "Thanks for Trying" would be just fine.
Thanks for using Fixya.
Mar 23, 2009 | Nintendo Wii Fit for Wii
Wii Fit Weighing Me Wrongly
You should probably put it on a board but if that doesn't work, you could try putting something weighing 12 pounds on the board or in your pockets or whatever.
Feb 28, 2009 | Nintendo Wii Fit for Wii
Wii fit software
No, it doesnt appear to be available solo yet. It should have been in the box, did you buy an authentic balance board from nintendo?
Feb 27, 2009 | Nintendo Wii Fit for Wii
Want to use two wii fit boards at the same time?
You can't sync 2 balance boards to one wii.
I heard this is why but this isnt confirmed...
the wii can only register 4 controllers at one time... the wiifit balance board counts as 2 controllers, leaving only 2 controllers available... obviously a person would want at least one regular controller to use along with the wiifit balance board, so just using wiifit leaves only one free controller slot available...
hope this helps...
Feb 05, 2009 | Nintendo Wii Fit for Wii
Majesco Jillian Michaels Fitness Ultimatum 2009 for Wii Logo
544 people viewed this question
Top Majesco Video Game Consoles & Games Experts
comandomcl8
Level 1 Expert
EnergeeUK
Level 1 Expert
Are you a Majesco Video Game Console and Game Expert? Answer questions, earn points and help others
