Question about Sharp Office Equipment & Supplies
Developer problem When we change the develper or insallaling the one the check light of developer dosen't gose off, if want turn off the check light developer what we shoud do?
  • 26 Answers
Hello
you must respect exactelly the weight of the developer which specified in its bottle.
Posted on Feb 08, 2009
Minolta EP2010 CSPro copier: Where does the develper bottle go??? I see the Toner MT 102a bottle but where does the Develper bottle install. Or does the toner bottle already have the develper filings?
When the developer is added during normal replacement, the developer bottle is installed in place of the toner bottle. Then when the F8 mode is initiated from the service mode the developer is added into the developer unit and automatically calibrated. This is only done after the old developer has been cleaned from the DV unit.
The toner bottle contains no developer. The developer is replaced separately and only needs to be changed about every 80,000 pages.
Good Luck and Thnak You for using Fixya.
Sep 21, 2010 | Minolta Office Equipment & Supplies
Copier working fine. moved from one office to another. now no print. pages come out blank. what could we have done?
Check the high voltage unit.Remove and clean the transfer / separator corona unit.
Aug 12, 2009 | Xerox 5855C Copier
Print a part of paper
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it.
To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
May 25, 2009 | Toshiba e-Studio 350 Copier
Prints aren't plain, it have some texture like crayon
its problem of toner
its of good quality
and also check proper supply of toner into develper assembly
trying to add some extra ink directly in developer assembly
if problem solve
check
cartridge motor running
and supplying toner proeprly
May 24, 2009 | Xerox DocuColor 12 Color Copier
Developer leakage while copying
after replace  developer you dont turn round the developer wheel left side. only right side.try this take out the developer and after re fill in to the developer unit. and u change the main charger unit also.
Feb 06, 2009 | Toshiba e-Studio 161 Copier Copier
Develper
The answer to you question is "no". Epson printers do not have developer units mixed in with the toner. They are a seperate unit all together. If you look around, you might find an epson warranty service agent who is happy to sell you the developer, however dependant on the unit, they are fitted in variouse ways and may require some technicle expertise to install.
Gremlin11
Nov 07, 2008 | Epson ACULASER CX11NF All-In-One Printer
Minolta ep 1083
i still think its your developer unit is causing this problem,do this take out the drum unit remove the developer unit and rotate the develper unit gears clock wise and look for void areas on the magnet roller where develpoer adhear .
hope that help
and check your fuser rollers ?
Nov 02, 2008 | Minolta EP1083 CS/PRO Copier
Adding developer to sharp sf-2025
Hi, it means the developer requires changing. it has a life of 30k (i think). I would suggest that if your quality is not effected, then keep using the machine, or spend the money on an engineer to come out and replace it.
Andy
Feb 28, 2008 | Sharp SF 2020 Copier
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
