Question about Whirlpool LER4634J Electric Dryer
How do i change belt
Cant figure out how to get in where the belt is
  • 979 Answers
Take off the back of dryer. There should be a panel with about 6-8 screws in it. You will put your hand towards the middle of the drum on the outside and feel a groove. This is where the belt will ride. Just slide the belt over the drum and into the groove and then around the pulley on the motor. Your particular model may have a tensioner device on it that has a pulley on it as well. You would trace the belt on this pulley as well. Put the belt against the pressure side of the pulley. This would give it tension on the belt at all times. Let me know how you do with this.
Posted on Feb 08, 2009
I need belt dirgram for 84 six cyl
If you have a different belt for each component, How many belt driven components and how many belts? Sometimes you can visually line up the pulleys, they all go around crankshaft pulley, I believe. Of course the inside belt goes on first. If you want me to try to look up routing diagram, I need make and model?
Oct 20, 2016 | Cars & Trucks
Need to change belts on engine
The tension is spring loaded and you use a wrench or 1/2" drive ratchet end and move away from the direction of the belt tensioner tensions the belt..
Oct 10, 2012 | 2000 Mazda 626
How to change my vacuums belt
If you can't stretch it for enough get a bigger one and cut the bigger belt to where you want it.
May 19, 2010 | Bissell 6594 PowerForce Bagless Upright...
How do i change the alternator?
To release the tension belt, use a breaker bar and socket or long long wrench. the pulley will pull up or push down in order to put belt on. Alt must be completely installed first.
Sep 11, 2009 | 2002 Dodge Intrepid
How to put on belt 100 series jd 48 cut belt.cant figure out how it goes on
Check out this link to some videos of changing the belts on a lawn tractor. Hope this helped and best wishes.
http://www.youtube.com/results?search_query=replace+belt+on+lawn+tractor&search_type=&aq=f
Aug 17, 2009 | Garden
Cant seem to get timing right after changing head gaskets. Someone previously replaced the timing belt in it and made their own marks and it is causing difficulty for my mechanic. Anyone know where th
What motor and year? If it is the Ej 25 DOHC all the marks are on the cam sprockets except the crank is marked in the block almost straight up, Just a small notch. Good luck and hope this helps. Have a good day.
Apr 24, 2009 | Subaru Forester Cars & Trucks
Whirlpool LER4634J Electric Dryer Logo
60 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
