I am not able to enlarge my print on my printer
SOURCE: the printed text on my canon printers is to small
Hi there
I use the program Microsoft Word on my pc to do what you want but the program link I put in here I think you would like it can do all sorts and it is free take a look at thie link.
Read more below.
The best program to put on your Pc is what I use and it is Free you, it is called PagePluse SE, you should try it you can do all sort of things with it but there no scan on it, just scan your photos to the your pc with another program witch has scan on it and put them in the SE program and you can do any size you wont and after adding text to it or backgrounds you can send it to the printer and print, an other program I use for scanning from the printer to the PC is called PainShop Pro 7 witch is a old program there newer ones out now but I am happy just using the old one it does the trick.
The Free version is Called PagePluse SE you not need the version 9.
Ok here the link to download the PagePluse SE program and it not a free trial it a free, there is one you can Buy but this is all you need download the free one it just as good.
Click Link = http://www.freeserifsoftware.com/software/pageplus/index.asp
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: The print is too small to read so is there a way
Set the printer properties to default and also see if the paper setting is A4 or which is default inserted for printing.. you will get results... Good Luck.
SOURCE: how do I change the text size in my printer
Have you tried changing the text in the document you are printing? Maybe you have to go to the print portion of your program and change it in the program before you print?
