Question about Saeco Royal Professional Espresso Machine
Drip Drawer will not release
We just bought our unit a week ago. The machine operates properly, but I cannot unhinge the drip drawer. I've applied some force in pulling on the tray, but it will not budge.
    Scholar:
  • 60 Answers
Hi
They can get sticky at times but there is no real reason for it to be jammed unless its taken a bit of a bang on the metal base of the unit at the front left. Mine was the reverse when I got it - could not get it in properly until I realised the left edge was bent in a bit.
Suggest you remove the 'grill' top of the tray, mop up all water in there. Get someone to hold the whole unit steady while you give it a good pull out and slightly up. Then you can remove the used coffee bin and then the brew unit. The former will need emptyimg when the message comes up and the brew unit ( vertical grey object inside door) it should be cleaned with warm water at least once a week to save that gumming up with coffee goo also.
If you need a manual contact me.
Posted on Feb 22, 2009
New Royal Professional Machine has the workd Dregraw.miss can not use the machine what must I do to get started need help.
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. Inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Jan 10, 2011 | Saeco Royal Digital Plus Coffee...
Water is slowly dripping from the top of Frig.
The water is coming from the defrost cycle in the top of unit . It drains down at the back of the light cover into a tube at the back. Get a phillips screwdriver and take it down to be sure tube is inserted properly. Get model number and go to.appliancepartspros.com to get a diagram.
May 24, 2010 | Frigidaire FRT18B4A Top Freezer...
Dregs drawer light on .I own Saeco Magic Deluxe.
Hi
Jan 12, 2010 | Saeco Magic De Luxe Espresso Machine
The dregs drawer missing indicator on, unit won't work.
There is a micro switch whit an arm the hangs down in the slot on the side of the machine. Make sure that you have the arm for the micro switch.
Jan 11, 2010 | Saeco Magic De Luxe Espresso Machine
I have emptied the dregs drawer, after prompting, and I keep getting a message saying firstly that the dreg drawer is missing (It isn't and I have checked that has been properly fitted)and then that the...
Hi
When you want to empty the grounds because it says to in the menu, REMEMBER TO LEAVE THE MACHINE ON when you remove the drawer. The machine is a counter and when it reaches the magic number for that machine the message comes on. If the machine is turned off when you pull the drawer out, the machine doesn’t know this and the message will be there when you turn the machine back on. Also remember to leave the drawer out for at least 15 seconds or a little longer so the machine thinks you actually dumped the grounds
Dec 29, 2009 | Gaggia Syncrony Espresso Machine
Drip drawer for white FF X1
HI
Try Illy.com
877-469-4559
They should be able to point you in the right direction
Nov 11, 2009 | FrancisFrancis! X1 - Stainless Steel...
I have a Saeco 21103 unit and it keeps getting an error message of ''dregdraw Miss'' what is that?
Hi
Dredge drawer is the big box on the bottom right. That is where the grounds are dumped. Remove the drip tray and pull the drawer out about half way. Push it back in with 1 finger on the right side of the drawer. That should clear the message. If it comes back on when you put in the drip tray, there is a section of the drip tray that can be removed to stop that. On the right side of the drip tray is a notch. inside that notch is a thin piece of plastic. It curls up on the right side. Cut out the piece that curls up (just the piece that curls, about an inch). When you push in the drip tray that curl lifts the dredge drawer and knocks it out of position.
Oct 27, 2009 | Coffee Makers & Espresso Machines
Dredge drawer full and it is empty
Hi
One thing you want to make sure you do is leave the machine on when you remove the drege drawer other wise the machine doesn't know that you emptied it. Remove the drip tray and pull the empty drawer out about half way and leave out for 15 seconds. Then push the drawer back in from the right front side with 1 finger. That way you make sure that you engage the switches in the machine. If you slam the drawer in you can pull it away from the switch and it will say drege drawer missing. If you put the drip tray back in, it can sometimes lift the drege drawer and disengage the switch. There is a notch in the right side of the drip tray that has a flashing on the back side of it. You can remove about an 1" of the right side of the flashing and it will stop the lifting of the drege drawer. Remember to leave the machine on when you empty the drege drawer other wise it doesn't know.
Jul 17, 2009 | Saeco Royal Professional Espresso Machine
I keep getting a message that says dreg drawer missing what is this? is this where the cup sits when it is getting filled? coz i have taken it out and put it back hundreds of times
The dreg draw is the little draw where the coffee pucks are released to after they've been use.
Typically if this message stays on even though the draw is in place indicates a bad microswitch.
doesn't cost much to get fixed, but i would take it in to a service center as it is a little rough to get to.
Jul 06, 2009 | Saeco Magic Comfort Plus Espresso Machine
The tray appears to have been inserted just slightly askew, causing the notch in the back of the tray to get hooked under that black bit. I was finally able to remove it by tilting the front upward and pulling out. I have reinserted the tray several times since and it pulled out as simply and smoothly as it usually does.
Feb 18, 2009 | Saeco Royal Digital Plus Coffee...
Saeco Royal Professional Espresso Machine Logo
75 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
Mike Cairns
Mike Cairns
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
