Question about Acer Aspire 5610-4648 Notebook
Can't use my webcam in Yahoo! Messenger
I and those who view my webcam only see black when I activate my webcam. When I checked Yahoo! Messenger support/ help topics, it says my webcam is not compatible with Yahoo! Messenger.
I need help, please.
  • 6 more comments
  • cardy556 Feb 11, 2009
    same
  • sibin98951 Feb 20, 2009
    when i try to connect webcam in yahoomessenger it cannot work.
  • alpha02 Mar 09, 2009
    webcam doesnt work on yahoo
  • ihmmpz Mar 14, 2009
    i have the same problem... please help....
  • Anonymous Mar 18, 2009
    please help, i have the same problem, but when i use other software that records video by the use of webcam, my webcam works, in YM, it only displays black screen
  • maritz Apr 09, 2009
    i cant use my webcam in yahoo messenger due to vfw static
  • aashwer May 18, 2009
    on aspire one netbook - webcam does not work on yahoo messenger, it says "not connected" or "sorry, no webcam was found on your system"
  • Anonymous May 25, 2009
    dvxcvxcvxc
How to set up web cam viewing on yahoo instant messenger
first make sure your web cam is perfectly ok. open yahoo messenger login your account click messenger menu then click view webcam then a window will open a warning message check donot show again then ok then choose you internet connection choose broadband then it will open a window with your webcam.
if you want your friends to view your webcam just chat with them, and in action menu click invite to view my webcam. you can see in your webcam window how many viewers you have and if you are broadcasting.
Apr 12, 2011 | Yahoo Messenger
How do i connect my web cam to my yahoo messinger
I am going to assume that you already have installed your webcam and can use it within windows with the software it came with.
I am also going to assume you are using yahoo messenger 10.
To activate your webcam in Yahoo! Messenger 10 in the top menu click Messenger, then from there select My WebCam.
Read the warning that should pop up, click OK and then select your speed preference and click OK.
Another box should come up showing your webcam view. It will monitor how many users are watching yor webcam.
Apr 28, 2010 | Microsoft Windows XP Home Edition
How to use web caM
be sure you plug-in in your webcam to the usb port of your computer and install the software and driver properly. when chating. if you are using a yahoo, camfrog, msn messenger. you just fing the option that can activate your webcam when you are chating. in yahoo messenger you can find their in the option and then view my webcam and now you can see your viewing your cam. be sure you log in first to yahoo messenger. if you want to taking picture with you're web cam just go to the my computer and find you camera D-link DSB-300 and just double click to open it your cam.
Mar 18, 2010 | D-Link DSB-C300 Webcam
Webcam problem
Go to Preferences of Yahoo Messenger and specify this webcam as your default camera. Then only will Yahoo look for it. And the webcam has to be installed before that. So,install the webcam and set it up as default in Yahoo Preferences and then use it in Yahoo.
Nov 16, 2009 | Logitech 961462-0403 Webcam
Usb webcam is not working in yahoo messenger
here is a link to test your web cam with yahoo messenger.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/index.html
Aug 08, 2009 | Computers & Internet
My cam wont work on yahoo
Did you try different Yahoo versions? Some webcams have compatibility issues with later versions of Yahoo messenger.
Another option is to use webcam sharing software, like SplitCam.
Jul 31, 2009 | Logitech 961462-0403 Webcam
I cannot find the "video and voice set up" in yahoo messenger that's why i cannot use my cyberlinkyoucam as my webcam
Yahoo! Messenger offers voice services, such as PC-to-PC, PC-to-cell or PC-to-landline calling. You can also participate in chat rooms and use the voice chat feature instead of typing. However, slow connection speeds or improper settings can interfere with voice activation in Yahoo! Messenger.
Instructions
  1. Step 1 Reduce echoes by using a headset instead of speakers and a microphone. Place the microphone farther away from the speakers, if possible. Adjust the volume of the speakers and the microphone.
  2. Step 2 Verify your Internet connection speed if your friend's voice sounds choppy. The computer modem speed must be 56K or higher in order to send voices or sounds.
  3. Step 3 Go to "Actions" and "Call Setup" in Yahoo! Messenger if you can't hear, or your friend can't hear you. Test the sound by following the instructions that proceed call setup.
  4. Step 4 Click on the speaker icon in the lower right corner of your computer screen if you want to test the sound manually. Uncheck "Mute," if necessary, and make sure sound levels are above 50 percent.
  5. Step 5 Pick "Preferences" in Yahoo! Messenger if you have trouble with connecting to the voice server. Choose "Connection," then select "No Proxies." Log in to Messenger again to check the voice server.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); For Webcam Setting
Having a webcam, or web camera, is a great way to share video images of yourself or whatever you want to show to family, friends or whomever you want. Being able to share your webcam on Yahoo Messenger can make it even easier for you to do. Learning how to change your webcam settings from your account informatioInstructions
  1. Step 1 Open Yahoo! Messenger and then click "Messenger," "Preferences" and then select "Webcam." Choose the option "When I show my webcam, change my status message to," and then enter whatever you want your status message to be in the text field. Then click "OK" to finish changing your status settings.
  2. Step 2 Choose "Webcam" from your Yahoo! Messenger "Preferences" menu and then click one of the following options, "Always ask my Permission," "Allow everyone to view my webcam," or "Always allow the following people to view my webcam." If you choose the latter you can select, from your friend's list, the people who you always want to allow to view your webcam. From there you can also select "Ignore other view requests," if you don't want to allow anyone else to view your webcam. You also have the option to either choose or not choose to select "If I am in a chat room, allow people in the chat room to view my webcam," by clicking the box. If you want to remove anyone who is viewing your webcam, you can select, "Who's watching me?" to remove their name from your viewers list.
  3. Step 3 Click "Webcam" from the "My Webcam" options in your Yahoo! Messenger "Preferences" menu, and choose "Statistics. From there you can figure out how much bandwidth you are using, as your connection mode, frame rate, image size and image capture type.
  4. Step 4 Select "Messenger," "Preferences," and "Webcam" from Yahoo! Messenger, and then click "Camera Settings." Move the slider under "Broadcast my webcam with," to select the between faster-speed transmissions or higher quality images. You can also change image size from this option as well as brightness and contrast. Click "OK" to finish.
n to creating contact groups is easy to do so that soon you can enjoy using your webcam on Yahoo! Messenger.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); NOTE:
must be login using any of your account on YM or try upgrade your yahoo messenger or download it again from the main site.
Jun 29, 2009 | Computers & Internet
Obi cam wont work in messenger
If you see a black screen when broadcasting your webcam:
There may not be enough light in the room. If so, illuminate the room appropriately.
Your camera may not be functioning properly. Try your camera with the manufacturer's software.
The correct camera may not be selected by Yahoo! Messenger. To change your camera source:
1. Click the "Messenger" menu in Yahoo! Messenger and select "Start My Webcam."
2. Click the "Messenger" menu in Yahoo! Messenger and select "Preferences."
3. Click the "Webcam" category.
4. Click the "Camera Source" button.
5. Click the pull-down menu and select the desired camera.
6. Click the "OK" button.
If you see a black screen when viewing a friend's webcam:
Check the status message at the bottom of your viewer window. If it says "Stopped," the person broadcasting has stopped broadcasting images. Ask the person to resume broadcasting and try viewing again.
If the person is in fact broadcasting and you still see a black screen in your viewer, ask them to check their camera and take the webcam compatibility test.
Oct 10, 2008 | Acer Aspire 5630 Notebook
Yahoo messenger - Webcam is not connected
You cannot access camera source until the webcam is running in Messenger - try setting it up from scratch
1) The webcam is working outside of Messenger
2) Reboot webcam by unplugging the USB connection and inserting it again - its important if its been used elsewhere and prior to chat.
BODY,.aolmailheader {font-size:10pt; color:black; font-family:Arial;} a.aolmailheader:link {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:visited {color:magenta; text-decoration:underline; font-weight:normal;} a.aolmailheader:active {color:blue; text-decoration:underline; font-weight:normal;} a.aolmailheader:hover {color:blue; text-decoration:underline; font-weight:normal;} YAHOO SPECIFICATION
To find out what the requirements are for messenger webcams, check out the following.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamreq.html
Once you have your webcam working outside of Yahoo Messenger you have to configure it to messenger CONNECTION
Open messenger - on top toolbar > messenger > preferences > connection - select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the 2 lower boxes > apply > ok TESTING
> messenger > my webcam - warning panel will come on click 'ok' and your webcam will launch. DEFAULT
With webcam still running > Messenger > Preferences > Webcam > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK PERMISSION OPTIONS
>messenger > preferences > webcam - make your selections about who you will allow to view you
IN USE Your contacts may need to configure their connection the same as above or they may also get a "webcam not connected" message
Jun 16, 2008 | Logitech QuickCam Express Web Camera
Acer Aspire 5610-4648 Notebook Logo
1,614 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
