Volume dial not working
The volume dial on my Logitech Z-5500 speakers stopped working. I have volume, but it is too low, and when I twirl the dial, nothing happens (no indication on the screen that volume is changing, no change in sound). I have an optical connection to an Apple G5. These speakers have been working for five years.
    Problem Solver:
  • 7 Answers
I would recommend you ask logitech if they can fix it, if the cost is too high i would go look for other stores that fix speakers, if it still cant be fixed, your better off buying new ones because having speakers like those for 5 years is a long time, it may just be time to change
Posted on Feb 11, 2009
How to adjust volume on left speaker? volume is extremely low on that side.
Its most likely the balance or fader that is causing the volume difference. set both of them to the mid setting ( usually straight up on a round dial) and check the volume again. if its still low check the speaker wire connection if it looks good on the bad side try swapping the cables from left to right. if the same side is still low the issue is most likely the amp.
Jun 13, 2014 | Logitech X-140 Speaker
I have an HP Laptop with Windows 7 and I have correctly set up my Logitech LS21 speakers, but the volume control does not enhance the sound coming from my laptop. The speakers work fine, but the sound is...
There are 2 volume controls on the audio output in windows 7. one is the system volume the other is the device volume. make sure that they are both at full and then control the sound volume on your speakers.
Jan 20, 2013 | Logitech LS-21 2.1 Speakers
My logitech speakers mo.ls11 sound is blurred when volume is increased
Adjust the volume level of the TV to low while the Logitech Speaker volume is at the middle... try changing volume of both TV and speaker to achieve satisfying results.
Apr 26, 2012 | Logitech Audio Players & Recorders
Output port for left speaker Z2300
I've been having the same problem actually.
In my situation, turning the volume up and down using the speaker volume control will fix the problem. I only have the faint volume problem at some positions of the dial. turning it up usually fixes it. I'm thinking that opening it up and cleaning it might fix the problem (it used to work with an older set of Creative speakers i had).
If that doesnt work im going to try to get a new remote from logitech.
Jul 02, 2009 | Logitech Z-2300 Computer Speakers
Popping Audio
You may have blown the speaker and need to replace it. Try at a low volume and then at high to notice any difference, if the popping occurs only at higher volume then it needs replacing. I hope this helps
May 27, 2009 | Logitech Z-5500 Computer Speakers
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Lip Sync issues with Logitech Z-5500 and PS3
hello there
First things First:
1) change the digital opt, cable, for another with cooper conduction. **
2) check connection again on low volume.
good luck
Mar 21, 2008 | Logitech Z-5500 Computer Speakers
Only getting half the volume
The first things I would check would be the volume control within your operating system. If I assume you have Windows XP, you would go to Start-->All Program-->Accessories-->Entertainment and click "Volume Control". Make sure all of the sliders are at least 1/2 way up. You might also want to check to make sure the cable from the speakers to the computer is plugged into the proper jack (usually the green one), as sometimes computers have jacks for rear speakers, which might make them sound quieter.
Mar 04, 2008 | Logitech Z-2300 Computer Speakers
Ups and Downs with Logitech
yeah repair the volume switch, open the speaker carefully and pump out the lead which connected the switch and the board..
Oct 11, 2007 | Logitech Z-340 Computer Speakers
Im looking for a part for my z-5500 You should be able to find what you are looking for here or alternatively go to logitech themselves,en&returnurl=support_downloads You could also try e-bay for the part as you are bound to find it much cheaper Still having problems just let me know.
Aug 11, 2007 | Logitech Z-5500 Computer Speakers
276 people viewed this question
