Trane Weathertron XE1000 Thermostat Wiring
I have a Trane weathertron XE1000 heat pump and I have the following wires coming in for the thermostat: yellow, green, red, orange, black, white, blue and brown. I am trying to hook up a Goodman Janitrol HPT 18-60 thermostat and the connectors inside are Y G R O W2 E and C. what wires go where? I currently have the yellow to y, green to g, red to r, orange to o, white to w2, brown to e, blue to c and black unhooked. everything seems to be running ok but the emergency heat strips seems to be running all the time causing my electric bill to skyrocket. PLEASE HELP!!!
  • virgamanda Feb 16, 2009
    I already have the black wire disconnected too, so the black and brown both should be disconnected?
  • Pyldrvr May 11, 2010
    All the wire hook ups look fine with except the Brown wire. Problem is I have no idea what wires are hooked to what at the unit. Can you confirm wire and let me know.
My weathertron heat pump stopped putting out heat
Posted on Jan 13, 2010
  • 56 Answers
Check to see if you have the system switch accidently on em. heat. The way you have it wired is correct except for the having brown on e. disconnect brown wire and cut ofbare end just in case they have the wire hooked up for constant run on roof.
Posted on Feb 16, 2009
  • Pyldrvr Feb 16, 2009
    Yes. Like I said if the unit was set up wiring wise for the heatstrips to run all the time based on where you live then both should be unhooked..try that and let me know.
Hello, I am trying to wire up my new Nest thermostat coming from a Trane Weathertron. The error code E106 keeps coming up. It seems to heat the house fine. I've included pictures. Thanks in advance!
Check your settings for the stat. Be sure you have your heat set up properly. Gas/electric, tstat btings fan on in heat or equipment brings fan on???
Nov 12, 2016 | Heating & Cooling
Heat/Cool does not respond after replacing Trane Weathertron BAYSTAT239 with Honeywell RTHL3550
Sounds like you didn't turn the power off and blew the low voltage fuse. Typically a 5 amp blade style (like a car) inside furnace. TURN THE POWER OFF!!
Jul 13, 2017 | Heating & Cooling
Hi, I have a 1984 Trane Weathertron Heat Pump/Air Conditioner. We had to move the thermostat a couple feet. When we tried to use it, the system would not turn on. We reset the circuit breaker; the power is...
You likely blew the low voltage fuse. Uncertain about the weathertron but it's likely a buss style fuse. I typically cut it out, add 2 spade clips and install a blade style fuse (5amp) . Turn power off first and check blower compartment.
Dec 02, 2017 | Heating & Cooling
Changing From Trane to Honeywell
Color ---> New stat terminal
Blue--------C
Green------G
Yellow-----Y
Orange----O
Red---------R
White------E and Aux.
Tan---------unused, tape and secure it
If there is Rh and Rc or R and Rh, these terminals should be jumpered together.
I used to install Weathertrons eons ago. Whatever you do DO NOT connect the blue wire to the B terminal, you will short out your low voltage transformer immediately when you switch to heat
Jun 13, 2013 | Honeywell RTH3100C - Digital Heat Pump...
Wiring diagram for a sfhf trane wiring diagram
i need a wiring diagram for trane weathertron heat pump.
Jul 03, 2012 | Heating & Cooling
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Trane weathertron thermosatat
OK. Here is a Trane Weathertron BAYSTAT240 thermostat wiring picture. This heat pump w/ electric (emergency) heaters is running right now. Notice the G terminal has green wire, the R terminal has red wire, the white wire is jumpered from W to X2, etc. The black wire loop you see in the center hole is unconnected.
This unit is adjusted by leveling the base - loosen the screw to the left of "R" and the one to the right of "F". Twist the base clockwise to RAISE the indicator. This makes the mercury in the switch turn ON at a different temperature. Remember to tighten those 2 screws again.
You will have to experiment several times to make the unit read exactly right. If the tech installed the base exactly level, the unit would read right (it says here).
Mar 20, 2009 | Heating & Cooling
Heating & Cooling Logo
4,034 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
