Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
Picture suddenly turned dark
In the middle of a show, the picture suddenly went dark black/red..looks like night vision or infrared picture.? All stations look to some degree like this. some not as bad as others. When you first turn the t.v. on it says MAIN on the screen for a few seconds. Please help.
Thanks so much
  • 744 Answers
Hi the picture tube of ur tv has got damaged and it badly needs a replacement.. so its better to replace ur picture tube..
thank u rate me!!
Posted on Feb 08, 2009
I have a swann security camera with night vision & it doesn't show a picture at night. What could be the problem
Those cameras use infrared led lights to see at night. If you have no image at night then those led lights are not working.
Aug 24, 2015 | SWANN Home Security
Vm321 infrared leds stoped working
it might be cause of open infrared diode or shorted
Nov 28, 2014 | Vtech VM321 Video Baby Monitor 1 Camera...
I have the swann 8 channel platinum cctv camera system and whilst it works with amazing quality during the day, the night vision is almost non-existant, it won't trigger cameras and is very dark on sc
Nearly all cameras work well in the day. Night vision depends on the type of camera and the technology it is using. For example a CMOS based camera will provide a very poor quality picture in the dark. A CCD Super HAD CCD II will provide a good picture with 0.01 illumination and a EXVie HAD CCD II will provide an even better picture with lux of 0.001. You really need to look at the specifications of the camera before you buy and not go with the "Platinum" or hype keywords used by the manufacturer. I have seen a lot of SWAN Cameras which are basically useless at night.
Aug 21, 2014 | Swann Communications Home Security
Can't get IF to work on my night vision monocular
There are only 6 versions of night vision showing, it sounded like you said f5, but the only one that looks like yours is a FT 300.
This requires a 3V lithium battery, you must make sure it's lithium .
Duracell D/L 1/3 N , radio shack 23265, Eveready 2L-76.
Here are the instructions, '
To use, depress the Energizer button, and release. A gradual fading of the image is typical. Press the Energizer button again to re-power. If your unit includes a self-energizingpower source (i.e., does not require batteries), simply depress and release the top lever one time and repeat as necessary.3.The infrared (IR) illuminator works to enhance the available ambient light in areas of extreme darkness, or brighten the electronic image in very dim ambient light. Utilize as needed by depressing the IR button (next to the Energizer button onmost units). Also, please note that on self-energizing units only, the detachable IR illuminator requires a 3-volt lithium battery.
Let me say that this is not a IF, infra red, Infra-red picks of heat from the environment, so when you look at something say a person you see their body heat, they cost thousands.
This is just a night vision, it does not even say what GEN this is.
There are three GEN's, GEN 1, GEN 2, GEN 3.
GEN 1 is cheap, GEN 3 is expensive. Starlight is the best, but your looking at spending 3000,00 for a good one.
Don't expect this one to be that good.
Here is the manual.
If it does not open, or can't download, then download foxit reader, it's free and allows you to view PDF files online.
Apr 02, 2013 | Photography
Why in total darkness does the unit just flicker with no picture? with infrared it works fine
these units need a very small amount of light to work at all, They amplify this small amount of light, with no light at all they have nothing to amplify! the infra red is a source of light so it can amplify that, At night they amplify street lighting or moonlight or starlight etc, hope this helps,
Sep 19, 2011 | Yukon 24021 Monocular
I bought 2 outdoor RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
How do you work the camcorder at night?
Some camcorders have the ability to see infrared. This is broadcast as a red light spectrum, but you cant see it, kind of like a rainbow but you can only see them at vertain angles. Some remote controls are this way as well. A good way to check to see if your camcorder can see infrared light is to go in total darkness. have your camcorder turned on, (or hooked up to the tv and turned on) either way so you can actually see either the view screen or the TV. Aim the remote control, (preferably not the cameras remote but rather say a dvd or tv remote) and press and hold a button. If you see the light light up say when you press the pause button on the DVD remote you should see it light up on the screen. If this is the case you can purchase an infrared light so you can shoot in the dark. If you have a full moon this will help as well. Since the light spectrums are not the same most infrared on camcorders show up as green and the blacks of your eyes glow white. On higher end camcorders they compensate for this and make it grey instead of green. But most the stuff you see at night is green.
Mar 10, 2011 | Cameras
Simply does not work anymore. I put in fresh batteries, and the on button and infrared work but when i look through the optics I only see black
Hello, it sound like it went south, hey. These NV monocular uses Russian manufactured image intensifier tube and they are cheap. As far as the longevity is from 1 minute to 10 ten years. I have thrown away at-least 10 within the last 6 months, and that seems to be the problem with all of the that have the logo, Zinth NV, Night Owl, Rigel Optics, ATN, Bushnell, Tasco, on and on Sorry to tell this. stewbison
Feb 06, 2011 | Bushnell Optics 2x24 264202 Guardian Night...
Last night the screen started going dark, then went out, black
If still under warranty, I would suggest going that way as this is a bad matrix driver....
Feb 15, 2010 | Sony Televison & Video
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
115 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
