Question about Sharp Microwave Ovens
Sharp R-24ST Microwave - Sticking START button
This has been a fantastic oven, but recently the start button has started sticking - you have to press it hard several times to get it to work. At first I thought it might be dirty, but I tried cleaning the area around it and it has made no difference. I guess it needs a new switch - any ideas on how to replace it, please.
  • italiastar Feb 09, 2009
    Many thanks - I'll give this a go.
  • italiastar Feb 10, 2009
    Thank you for the follow-up. I haven't had a chance to find out how the control cover comes off yet, because there are no obvious screws. I think your solution is the most like one, and thank you for it. I'm always nervous about Microwaves - these are one of the things that bother me, however I'm reasonably confident and only work withing my ability - besides I'm not going anywher near the magnetron etc. I''ll give it a look hopefully by the weekend and let you know how I get on. More than happy to give you a Fixya, because you've been more than helpful and I'm sure your solution will work.
    Thank you,
    Gerald
I had the same problem some years ago, and in my view it is caused by a design fault. There's a circuit board behind the front panel with tiny tactile switches that get pressed by the front panel buttons. But the **** design is that the switches aren't located behind the buttons, so the "engineering solution" that Sharp has used is to mount each of the buttons on a framework so that a sticky out bit from the button presses the appropriate switch. The problem is that the framework is made of plastic and so will eventually give way. Some 5 years ago I opened up my microwave and repaired the framework. When it went again yesterday, it was too far gone to repair. I could purchase a spare button panel from one of the spares suppliers, but for some GBP 8 or so.
Wanting an instant solution, I went a bit further. I removed the switches and soldered short trailing leads to their contacts. I glued (with epoxy) the switches back onto the circuit board so that they were directly behind the buttons, and then soldered the trailing leads from each switch back to the original switch locations. This meant redrilling the holes for one switch as the original holes were now obscured. I then cut off the three buttons from their framework (it was just the Stop, Start and Power level buttons as we never use the others) and trimmed off any projections to make them flush on the back. I filled the hollow of the button with modelling clay, and then expoxied a thin (2mm) layer of rubber on the back. When re-assembled, the buttons simply float in the hole in the front panel, but don't fall out as the switch is just behind them. They now work better than ever before, as they're pressing directly on the switch, rather than indirectly.
For disassembly (from memory), I removed the six or so screws holding on the main steel cover (at the sides and on the rear). There was one screw inside the casing securing the front panel assembly which, when removed, allowed the front panel assembly to be removed by lifting slightly and then pulling out. Disconnect the cable connectors (taking care to label where the yellow & red power connectors go. On the front panel assembley there are two circuit boards on top of each other. Remove the top one and the connector from it to the bottom one. The bottom circuit board is screwed in with 4 screws. Once the bottom board is removed, the button panel lifts out and you're ready to consider whether you're up to my repair method or whether you want to order a new button panel.
It may have taken me a while to complete this, but it gave me the satisfaction of a repair with no parts required, and the confidence that it will last, and can be tweaked if required. So my R24ST lives again!
Posted on May 06, 2009
  • Sharp Master
  • 9,098 Answers
I don't have the service manual for that UK model, but my experience tells me that under the buttons there is either a set of board with mechanical switches or a membrane keypad.
Either way, that membrane or switch board is likely what you'll have to replace.
For generic disassembly help, see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
Info on ordering Sharp UK parts / spares is here.
If you're in another country, you can visit Sharp's world portal here.
Posted on Feb 09, 2009
  • William Miller
    William Miller Feb 10, 2009
    If you need more help, please reply back and let me know.
    If this gets it fixed, I'd appreciate if you'd consider me for a FixYa rating.
    Good luck & thanks.
Can you buy replacement decals to show the button functions, as ours have worn off. Thanks in advance.
'Decals' are not available separately.
You can order a replacement keypad here ... http://www.searspartsdirect.com/model-part/r24gt/0958/0123242/p0102289/00001.html
$90.00+ & you'll need to dis-assemble the microwave to replace this part. Probably less expensive to replace the oven.
Aug 23, 2015 | Sharp R-24ST Microwave Oven
Start button not starting. when you tourch its not responding , what is the problem
Hit the relay on the main circuit board to see if it is sticking in the wrong position
Nov 28, 2013 | LG LMV1680ST Microwave Oven
REPLACING THE MEGATRON ON A SHARP R-24STM
see the video and proceed according and fix it. God bless you
Mar 06, 2013 | Sharp R-24ST Microwave Oven
When I press start on my sharp R-305K microwave nothing happing,
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 24, 2011 | Sharp R305KS Microwave Oven
Fan Button doesn't work
HI, in most cases, the button will be fine. there is an error code that will illuminate on the control if the touch pad starts to malfunction(sticking buttons). this is more likely an issue that concerns the integrity of the fan motor. have it tested. replace it if found to be defective.
Jul 21, 2009 | Frigidaire PLMV169DC Microwave Oven
Sharp R-1510 Start Button Not Working
This may not solve your problem, but on my Sharp R315J microwave, the little plastic pin that pushes forward on the inside of the start button, had broken off and it wouldn't start. The Minute Plus button would start the microwave, so I knew the microwave worked, so I tried to find a piece of plastic that I could glue into the start button hole, because the part doesn't exist and you have to buy the whole door for $100 plus shipping. Nothing I could find was small enough, so I started looking for a new microwave.
While ouside doing lawn work I noticed a small bird tail feather and the end looked to be the perfect size. I snipped off the pointed end and then up about 3/8" to make a little rod to replace the plastic one that broke. It fit perfectly!!! I didn't even have to glue the inside end, it stays put even after repeated door opens. This is sturdy material and looks to last a long time. When it wears out, I have a cat, there's always a few feathers around. I hope this saves someone else a hundred bucks, like it did me.
Mar 09, 2009 | Sharp R-1510 Microwave Oven
Manual needed
You can download it free here and print it if necessary.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Sharp R-24ST Microwave Oven
Sharp R-1505 Microwave
I would first suggest that you be sure every single wire got reconnected where it belongs.
Here is a diagram: http://www.microwavedisplay.com/r1500_series_wiring.pdf
If you still have toruble, see http://www.microwavedisplay.com
Nov 28, 2007 | Sharp R-1505 Microwave Oven
Microwave Ovens Logo
434 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
