Question about Rockford Fosgate Power 1500.1BD Car Audio Amplifier
T1500-1bd burnt mosfet
Amp was working fine but had drained the battery over a weekend and a burnt smell. the amp has a burnt mosfet and no other visible damage. I am unsure if this is the only problem and how to check for other faulty components. Any advise would be appreciated. I run the amp at 2ohm but plan to go 1ohm when repaired
  • 1 more comment
  • jrchitty1 Feb 10, 2009
    Thanks for the advise, This amp was only 4 months old when it failed and I Bought it from an individual on ebay so I Have no receipt from a dealer so I assume no warranty? I did check the resistors nearest the burnt mosfet and one was high and the one at the burn was infinite. I would like to try to replace the components I can test with a simple multimeter and try as I don't know who to send the amp to for reasonable price. By the way, I save a whopping $60 by not buying from a RF dealer! Thank you for your time & knowledge.
  • Perry Babin May 11, 2010
    I've worked on a lot of Rockford amps but I've never had a T1500-1bd in the shop. If you have no alternative and can send me a couple of decent quality photos showing the parts you know to be defective, I'll try to help. I doubt that it's going to be available for such a new amp but try getting a schematic diagram from Rockford. It would help quite a bit.
    babin_perry@yahoo.com
    It's a relatively new amp. If it's under warranty, you should send it to Rockford for service. I'll generally help people through repairs but these amps are relatively complex and if you have to ask for help on them, you should probably refer service to someone else. If it's under warranty and you tamper with it, it could void the warranty.
The cap will help but If you can take the alternator off and take it to a rebuilder they can build you an alternator that puts out more amps which is a great for multiple amps to charge the battery faster and will give you more sound! More power to amp more watts and clearer sound!
Posted on Apr 01, 2012
  • 30 Answers
Fosgate's get very hot.My first amp was a fosgate and I freaked out because it got really really hot. And smelled bad. So I moved it so where it could get more air That should help you out a lot and the smell went away on its own. As for your battery dying. Basically your stressing out your battery and your alternator is having a hard time keeping the battery changed. I'm sure you see your light dim when a low bass note hits. Invest in a cap. This will help save your battery your alternator and should even sound better.
Posted on Feb 10, 2009
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
Hi used my dual drill last weekend and it seemed fine went to use it this weekend and it dose not work ,both batteries charge but when you press the trigger nothing happens ,I have. Power all round the...
look at the windings in the housing and if they are black not bright brown they will be burnt out Also smell the motor and you will tell if it is burnt as it will smell burnt.
Jun 15, 2013 | Drills
Hooking up the amp i had the ground wire connected and was going to hook up the power wire and it hit the case of the amp know the amp turns on but there is no sound from the speakers other amps work on...
sadly, your amps' output MOSFETS are more than likely toast.
your amp was grounded, and you touched the amp chassis with the power line.
electricity will follow any path available to find ground. in your case, the output mosfets became your main ground-path since they are directly connected to the amps chassis (heat sink) and internally you had grounded the amp so power would flow full force through the output transistors in the serach for a ground.
open up your amp and smell the row of MOSFET transistors. you'll probably even be able to see some burnt transistor legs.
repair or replace.
May 08, 2011 | Kenwood KAC-7202 Car Audio Amplifier
My orion 6004 amp was connected, but it didn't turn on, so i was going to disconnect it and smoke came out from wire connections, i opened and i didn't find a solution Can you help me with it?
you had a short circuit.... you need to check the fuse of your amp if it is blown then replace it.. otherwise replace the cable if it is burnt and check your amp carefully
Aug 01, 2010 | Orion Car Audio & Video
Trying to find the right FET to replace burnt up ones with
hafler use international rectifier hexfets. there is alot of confusion what constitutes a mosfet amplifier.
if the outputs are mosfets instead of bipolar transistors, it is a mosfet amp.
some designs are using mosfets to drive the switch mode power supply,but use bipolar output transistors.that is not a true mosfet amp.
you need to go to an electronic supplier for the repair industry.
or the manufacturers warranty depot,who will be able to order them.mosfets are very high current devices,you have to ask ...why did they fail. if they are the switch mode drivers,there is bad capacitors in that circuit
May 23, 2009 | MTX Thunder 5-Channel Amplifier 895 Car...
First of all is the mosfet your talking about in the output section or in the power supply section? Most car amps use mosfets in the power supply section, some use them in the output section. To test the transistors in your amp, take a digital volt meter and set it to diode check. Then take the leads and put them accross the first and third legs of the transistors. Usally the red test lead on the first leg and black test lead on the third leg of transistor. If you get a reading of 000 then transistor is shorted. If you get a reading below 600 then transistor is on it's way out if not allready or it's next to a shorted transistor that is it's complimentry output transistor. comonly you will have 2 transistors working together, one NPN and one PNP per a channel, or 4 of them in a bridged type output circuit depending on the watts and how man channels your amp has. I was just looking at the specs of this amp and it's got me confused. It says it's a 2 channel but looking at all the info on different pages it says at 4ohm:200wattsx4 and at 2ohms:300wattsx4 and 1 channel mono 600watts into 4ohms. weird for a 2 channel. anyway that is how you test your transistors. Same way for the power supply section but, you will come accross a couple or more switching diodes that look like transistors and you will get a 000 reading when you test those like I specified. They rarely go out and most of the time there is only 2 of them. They will have a diagram like a diode on the front showing you which way the power flows. Let me know what you find out. Your amp should have went to protect mode if you smoked a mosfet.
Feb 08, 2009 | Audiofonics ADF-243 Car Audio Amplifier
LIGHTS ON BUT NO BASS
Is the master/slave switch set to master? Have you tried feeding the signal into a different amp to make sure that there is signal reaching the amp?
Sep 18, 2007 | Car Audio & Video
Audiobahn A6004T Amp Blown PLEASE HELP!!
They are most likely a MOSFET type of transistor. If they are in the power supply part of the amp then you will probably need to replace all the MOSFET's in the power supply along with perhaps some gate control resistors for them. They each have their own resistors. It wouldn't hurt to see if the 494 IC in the power supply is working properly too. This IC is what sends the pulse width modulated square wave to the MOSFET's. Next you will want to test all the MOSFET's that are used as the audio output drivers and their predrivers and bias resistors. Don't forget to check the DC bias and offset on the outputs too, to make sure everything is OK there. In short, you will most likely need to go to a repair shop that can do all this and who would know what the heck I'm talking about. Good luck.
Mar 05, 2007 | AudioBahn A4004T Car Audio Amplifier
No sound output from amp.
It has bad parts. It should NOT be drawing 15amps at idle!! You need to grab a DMM and check the mosfets!!
Sep 20, 2006 | Rockford Fosgate Punch 800a2 Car Audio...
Burnt smell
If something is burnt,something made it burn !! These things dont smoke for no reason. Have the amp checked out, and also have the speakers and all the wiring checked for a partial short. Good Luck
Aug 08, 2006 | Power Acoustik PS2-1600 Car Audio...
Rockford Fosgate Power 1500.1BD Car Audio Amplifier Logo
423 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
