Question about Dell 924 All-in-One InkJet Printer
Paper does not feed
Dell photo 924;
paper begins to feed then stops.
'load paper' message on screen
    Master:
  • 441 Answers
Try feeding a post card or a different kind of paper thru the feeder tray, make sure that it is going in smoothly.
Try something innovative for checking out those rollers
Posted on Feb 08, 2009
It starts to feed and the rollers keep going and the paper stops and does not print
Start of layer. Dell 924 All In One Inkjet Printer. Click To Close ..... However it does a good job with photo printing on photo paper, .... I had contacted Dell about the problem I was having and I felt they were not going to do .... I bought a all in one dell printer, and it will not feed the paper, correctly. ...
catalog.ebay.com/Dell-924-All-One-Inkjet-Printer-/50399257/r.html
Jul 02, 2010 | Dell 924 All-in-One InkJet Printer
Dell 924 Photo Printer will not recognize that paper is loaded
you will likely have to take this in for (hopefully free!) warranty service. it sounds like there was an assembly issue here. good luck!
Feb 17, 2009 | Dell 924 All-in-One InkJet Printer
Paper will not feed all the through the printer
I had the same problem with my Dell 924 and after EXTENSIVE research I found a forum where about 90 percent of the people with the same problem ultimately found some sort of foreign object in the printer. I spent about 30 minutes shaking my printer to no avail then I broke out the flashlight and started looking in every nook and cranny. I lifted up on of the small black plates on the roller towards the back of the printer (if you're looking in the front) and low and behold I saw something that looked odd. Grabbed some tweezers and fished out an allergy pill in a little bubble pack. Was wedged in there to good to fall out from the shaking. Take a piece of card stock or photo paper and try to feed it through the printer manually. If starting at the top, take note of where the paper stops and that should be where your problem is. Try feeding from the top and the bottom, if the paper will not feed through, something is in it's way. Hope this helps.
Dec 25, 2008 | Dell 924 All-in-One InkJet Printer
Paper Jam
Open the tray and cover. Look out for any paper inside the cover.
Close the cover and tray firmly. Then check for a test page.
Let me know if I can assist you further. Don't forget to vote the solution.
Regards
Ellin
Sep 25, 2008 | Dell 924 All-in-One InkJet Printer
Print Feed Issue on 924
Make sure that there are no obstructions blocking a sensor or in the way of the paper path.
Are the cartridges jammed?
Jun 19, 2008 | Dell 924 All-in-One InkJet Printer
How to get my Dell Photo 924 to feed paper for printing?
if you are having issue with the paper feed ,moz-screenshot.jpg try these steps
1. Unplug the power adapter
2.open the printer cover , look for any obstructions inside , lift the printer and shake it firmly
3.turn the printer upside down and gently tab on the base,.
4. Put your Hand inside the Input paper tray and manually roll the two rollers
5. Put back the power adapter , turn on the Printer and try to copy a document from the printer.
Try all these steps and if you still have the paper feed issue then purchase the new printer
Apr 15, 2008 | Dell 924 All-in-One InkJet Printer
Paper won't feed
Dell.com will chat with you on-line to help you toubleshoot that printer.
Mar 31, 2008 | Dell 924 All-in-One InkJet Printer
Paper feed problem.
ATN master 3202 clean paper feed rollers with a micrfiber cloth moistened with rubbing alcohol will be rollers that pull paper probably just need wiping off after a lot of use these rollers build up paper dust that causes traction problems
Nov 01, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 paper feed
you need to clean paper feed rollers with isopropanol alcohol on a microfiber towel or get a sheet of cardstock to print on as it prints it will force out any foriegn material
To correct paper feed function make sure feed sensor lever isnt broken
Oct 29, 2007 | Dell 924 All-in-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
175 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
