Question about Audiofonics ADF-243 Car Audio Amplifier
T1500-1bd burnt mosfet
This amp was still working fine but drained my battery so i unhook the battery and remove amp-- It definatly smoked a mosfet. But I am unsure if this is the only problem or how to check for possibly faulty components. Any advise would be appreciated.
    Novelist:
  • 77 Answers
First of all is the mosfet your talking about in the output section or in the power supply section? Most car amps use mosfets in the power supply section, some use them in the output section. To test the transistors in your amp, take a digital volt meter and set it to diode check. Then take the leads and put them accross the first and third legs of the transistors. Usally the red test lead on the first leg and black test lead on the third leg of transistor. If you get a reading of 000 then transistor is shorted. If you get a reading below 600 then transistor is on it's way out if not allready or it's next to a shorted transistor that is it's complimentry output transistor. comonly you will have 2 transistors working together, one NPN and one PNP per a channel, or 4 of them in a bridged type output circuit depending on the watts and how man channels your amp has. I was just looking at the specs of this amp and it's got me confused. It says it's a 2 channel but looking at all the info on different pages it says at 4ohm:200wattsx4 and at 2ohms:300wattsx4 and 1 channel mono 600watts into 4ohms. weird for a 2 channel. anyway that is how you test your transistors. Same way for the power supply section but, you will come accross a couple or more switching diodes that look like transistors and you will get a 000 reading when you test those like I specified. They rarely go out and most of the time there is only 2 of them. They will have a diagram like a diode on the front showing you which way the power flows. Let me know what you find out. Your amp should have went to protect mode if you smoked a mosfet.
Posted on Feb 12, 2009
Reebok T3.2 treadmill stop after couple of minutes
7 amps wth no load is kind of high for this.. be looking at the surface that the belt is on.. and the rollers for excess drag..this should completely freewheel when no one is on it..
Jan 19, 2014 | Reebok Exercise & Fitness
How to remove factory amp from 1996 mustang
of hand , it sounds like you need a new alternator. Jxust unplug one of the poles on the battery until you find what you are looking for, that will stop the drain of power. Now clear up to me on what you are referring to ," factory amp"
Aug 16, 2012 | Ford Cars & Trucks
Amplifier draws too much wattage
Buy new battery
ampifiers take little current to rise the voltage
also look for unwanted bugs xD
Jun 27, 2012 | 2001 Chevrolet Impala
I had my boss 2400 watt 2 channel amp hooked up in my car. I had one sub on each channel and one of my subs blew. I unhooked the positive speaker wire on the blown sub, everything was fine. Driving down...
If your amp started smoking, probably not. Due to your description, did the other sub really blow? I would hook it up to another amp to test it. It may have been a channel in your amp. As for repairing the amp, the parts and labor to repair will probably cost you more that to just replace the amp.
Sep 06, 2011 | Boss Car Audio & Video
I hooked up a dual mosfet 4 channel amp and i am not getting power to it. the way it is setup is from battery to 100 amp fuse, from fuse to inside cab of truck then to 500 K farad, Split from + to power on...
Bad ground sounds like you may have paint or undercoating stopping the ground from making good contact or unhook the remote wire and run a small wire from the main power to the remote hook up and see if it works ...... May have a faulty remote
Apr 25, 2011 | Dual 2-Channel Bridgeable MOSFET Amplifier...
Mosfet in my asus motherboard burnt out,
Better to have the motherboard replace, do not wait until some other components might be also damage. Commonly mosfet is use in power supplies regulator. It can kill your processor and memory.
And also check your power supply. It might also having problems.
May 02, 2009 | ASUS P4GE-MX Motherboard
Fosgate's get very hot.My first amp was a fosgate and I freaked out because it got really really hot. And smelled bad. So I moved it so where it could get more air That should help you out a lot and the smell went away on its own. As for your battery dying. Basically your stressing out your battery and your alternator is having a hard time keeping the battery changed. I'm sure you see your light dim when a low bass note hits. Invest in a cap. This will help save your battery your alternator and should even sound better.
Feb 08, 2009 | Rockford Fosgate Power 1500.1BD Car Audio...
MA2 laptop, not charging battery, changed burnt 4407 chip, no LED now.
This unit had a RED CHARGE error. Replaced PQ38 solved the problem.
If you get an error on the charge circuit after replacing the PQ38 you should also replace PQ38 because it too may be blown. Make sure Pin 1 where the dots. Also check the MOSFET on the other side of the COIL too.
Oct 08, 2008 | Gateway MX6030 Notebook
Rockford p5002 amp is smoking...
Completely disconnect the amp and remove the cover. Look for anything that is discolored or burned.
Did you have one sub on each channel before the sub blew?
Jan 23, 2008 | Rockford Fosgate Punch P5002 Car Audio...
Audiobahn A6004T Amp Blown PLEASE HELP!!
They are most likely a MOSFET type of transistor. If they are in the power supply part of the amp then you will probably need to replace all the MOSFET's in the power supply along with perhaps some gate control resistors for them. They each have their own resistors. It wouldn't hurt to see if the 494 IC in the power supply is working properly too. This IC is what sends the pulse width modulated square wave to the MOSFET's. Next you will want to test all the MOSFET's that are used as the audio output drivers and their predrivers and bias resistors. Don't forget to check the DC bias and offset on the outputs too, to make sure everything is OK there. In short, you will most likely need to go to a repair shop that can do all this and who would know what the heck I'm talking about. Good luck.
Mar 05, 2007 | AudioBahn A4004T Car Audio Amplifier
Audiofonics ADF-243 Car Audio Amplifier Logo
212 people viewed this question
Top Audiofonics Car Audio & Video Experts
Mark Skinner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
