Question about Dell Photo 964 All-In-One InkJet Printer
My dell 948 printer can send faxes but doesn't receive
I am using my dell 948 as a stand alone fax. It sends faxes ok, but when I receive a fax, I hear the ring tone through the fax, but nothing else happens. The sender gets a "no answer" message.
  • Anonymous Mar 28, 2009
    hi i can send a fax but i am unable to recieve a fax
  • roryocasey Mar 28, 2009
    i can recieve a fax but am unable to send a fax on my Dell 948 printer
IB4G2008
  • 3587 Answers
SOURCE: Fax rings but will not pick up or give fax tone
hmmm..that's a fax settings issue on the front panel...you may new drivers for that hp.
get them here
Posted on Feb 28, 2008
SOURCE: canon mx310 fax noise
Ok, I think I have found a solution.
I have read all the posts on the net and with no success I decided to go againts the grain.
After I set all data to default:
Set printer to "Fax priority mode" and set Ring count up to enough that you have time to pick up.
It rings the amount of rings you set it to and then makes a beep sound in the caller's side. It then continues to ring on the printer and asks you to press stop if you want to use handset.
I am still testing this.
Posted on May 28, 2008
tech435
  • 284 Answers
SOURCE: Fax ring tone or ring leader
im sorry to say the machine you have does not have DRD distinctive ring detect.
Posted on Sep 22, 2008
leroyal
  • 2120 Answers
SOURCE: hello I have a dell
Do you have a DIGITAL phone line? Fax machines only work on ANALOG phone lines.
Posted on Jan 02, 2009
Ajkill
  • 2035 Answers
SOURCE: Hi, Remote Fax Error being displayed
Set the DRPD in the settings to 9600 and then try send a fax ...
Posted on Jan 29, 2009
Can I send and receive faxes?
u need to have a modem that can send receive fax, then install faxing software in computer, install dell drivers then setup modem, and send recieve program, to send fax u scan n save then use fax program to use image sometimes it may scan and send at same time? read manual with program
Aug 22, 2015 | HP Photosmart 3210 Printer
Dell V715w wont receive faxes
To receive a fax automatically:
  1. On the printer control panel, press the Setup setup_icon%281%29.jpg button, then use the menu to select Fax Setup, Ringing and Answering, and then Auto Answer.
  2. Select On and then press OK to save the settings.
  3. Select Pick Up On and set the number of rings, then press OK to save the settings.
To receive a fax manually:
  2. Select Off and then press OK to save the settings.
  3. When the telephone rings and you hear fax tones when you pick up the handset, press the Start button on the printer or *9* on the telephone attached to the printer.
Oct 25, 2011 | Dell All-in-One Multifunctional (v715w)...
Why our fax sending and receiving solid black
Its a problem with scaner unit. Reports are being printed out, and do not pass trough scaner, because of thath report is Ok.
If the fax is still under warranty, go to warranty provider service.
Next time dont buy "kids toy" for fax machine. Try laser Canon Fax L140.
May 20, 2010 | Canon FAX JX200 Fax / copier Plain Paper...
I can send faxes on my printer, but I can't receive faxes. I have a V505 printer. have a Dell V505w. Service tag JVQ2G1. I have wireless conection. The blue light is on indicating that the wireless is...
Are you sending using Ifax means internet fax? if yes this means you cannot receive fax since you donot have phone line but you can receive only Ifax.
Aug 21, 2009 | Dell Office Equipment & Supplies
Can send faxes but are not receiving
Is AutoAnswer turned on? Have you set it up to receive the fax using Dell PC Fax?
Support page at http://support.euro.dell.com/support/edocs/systems/prn966/en/UG/HTML/d0e7828.html#d0e8636
may help
Jul 20, 2009 | Dell 966 All-In-One InkJet Printer
Need to know abt fax
HP.com has a web page that talks about the different ways you can send a fax from this product:
Faxing Overview
In general, the fax machine in the all-in-one product doesn't need a computer to work. It works just like a stand alone fax machine. You shouldn't have to scan anything in from the scanner in order to fax. Just put the sheet of paper you want to fax into the product's feeder and follow the fax instructions (see the link I posted above).
As long as the product has electric power and is connected to a phone jack, it should work out OK.
As far as legal papers, if you mean legal sized papers, it should work as long as the product supports the paper size you want to use. You can get that on the product specifications web page at HP.
Product Specifications
Once that page opens, go to the Faxing specifications and Paper specifications sections for the relevant details. Good luck.
Oct 09, 2008 | HP Officejet 5610 All-In-One InkJet...
Using a calling card for a long distance fax
It will surely help if you are using a calling card that has a pinless dialing feature where you don't need to dial your pin. I use Onesuite.com calling card and it has that feature and sending a fax through regular fax machine is easier than having to dial your pin midpoint.
Apr 19, 2008 | HP Photosmart 2410 All-In-One InkJet...
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
Dell Photo 964 All-In-One InkJet Printer Logo
201 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
