Question about LG LRFC25750 Refrigerator French Door
Ice build up on floor of freezer drawer starting under ice maker
I have noticed a build up of ice on the floor of the freezer drawer in our 4-year old LG French door refrigerator, starting under the ice maker. Any idea what might be causing this or how to fix it? I suspect the ice maker may be leaking water periodically, but it appears to be working normally.
  • 2 more comments
  • sue15 Mar 13, 2009
    My LG french door freezer has the same problem. I have disconnected the ice maker and water to the frig but the ice build up continues. I have moved the frig away from the wall to help circulation and there is no food blocking the freezer ventilation system. LG says to turn the freezer temp to 0 and see if that helps (we had turned it to -3 ) and if that doesn't help, then next turn the frig off for 4 hours. I don't expect that to work either. I found a comment on line that it may have to do with the evaporative drain.
  • Anonymous Mar 21, 2009
    I have the same problem with 4 year old lg refrigerator. ice wil melt soaking floor with water. Must manually remove the ice on the floor of the freezer.
  • tony572 Mar 21, 2009
    tony572 here - we got a serviceman in about 3 weeks ago to take a look. He determined that the problem was not the icemaker, but a frozen defrost drain (the water in the defrost drain had somehow frozen up). After melting the ice in the frozen drain with boiling water which we supplied, the problem seems to have gone away. I am not sure what caused the water in the defrost drain to freeze in the first place (this is thr first time this has happened in 4 years or so) but that seems to be the problem.
  • Anonymous Mar 28, 2009
    Does anyone know how to get to the "defrost drain" or "condensation drain" to clear it out. Do you go through the inside of the freezer, or get at it from the back of the appliance? If anyone has details they wouldn't mind sharing, that would be great. Thanks.
  • 66 Answers
Since this problem is discussed over and over on various models, I point you to a detailed manual that shows (with images) how to solve the frozen drain pipe issue. This is the manual by Avi
good luck
Posted on Jan 29, 2011
  • 28 Answers
You will have to access to the drain from the inside, most of the time is water sludge that stuck the drain opening after years of operation.
Posted on May 09, 2009
    New Friend:
I hve no soloution how do i get to this drain
Posted on Jul 06, 2013
Ice buildup in bottom of freezer compartment
Here's a link to a great website that will help you understand what might be causing your freezer to have that ice build up. I could explain it here, but if you look at this link, they've already done a wonderful job.
Jun 08, 2016 | Samsung RF4287HARS French Door...
Ice build-up on the bottom of the freezer drawer
Water on the freezer floor has only two sources, 1) ice maker overflow/leak, or 2) defrost drain plugged. For the first you can turn off the ice maker and shut off the supply water for a few days to see if the problem recurs. If this is the problem determine if the water fill valve leaks or the ice maker is the problem and replace the offender. For the second, thaw out and clear all the ice, paying special attention to the drain located under the freezer (cooling) coil. Then clear the blockage from the drain tube. BE CAREFUL AND DO NOT USE WIRE OR SHARP ITEMS as this can pierce a hole in the drain requiring replacement, not something you want to do or pay for. A turkey baster and hot water are useful tools to flush out the blockage allowing water to drain freely into the defrost drain pan under the refrigerator.
Sep 12, 2014 | Refrigerators
I have an old GE fridge with ice maker in freezer, water started leaking and flooded floor of freezer and started leaking outside freezer. What's going on & how do I fix it?
I think you need a new fridge/freezer. Look for offers now on sale some are quite reasonably priced and home Depot has interest free credit.
Sep 19, 2017 | GE Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Ice under the bottom draw in freezer. Melts some
Close, it is in the freezer.
It is your defrost drain. that ice was actually ice originally, just from your evaporator. the defrost heater comes on when the evap. gets frosty white, it melts, and then is supposed to go down your drain. if it is clogged, it will build up, and just freeze because it is around zero in there. my advice, take off the back wall of the freezer, look for the drain under the aluminum coils that is toward the back wall. get your moms hair dryer and go at it
Oct 07, 2009 | Frigidaire FRS26R4A Side by Side...
Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. good luck Avi
Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Ice maker spills ice
Jun 29, 2008 | GE PFS22SBSSS Stainless Steel French Door...
LG LRFC25750 Refrigerator French Door Logo
1,111 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
