Question about Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum
My kenmore progressive vacum will not turn on
When I press the on switch, my vacum will not turn on.
Does the motor in the head turn on? If the one in the head turns on but not the one in the canister, the motor in the canister is probably dead. If they both don't turn on, then it could be the switch, the power cord, the internal fuse or even a relay inside.
Posted on Oct 06, 2009
You need a new switch.
Posted on Feb 08, 2009
Ther is no suction and rolar prush is not runing in my kenmore vacume progressive
Remove the rotating brash and check it, something is blocking the suction, probably you need a new belt
Mar 24, 2013 | Kenmore 31912 Progressive Direct Drive...
I changed the cord and vacume comes on without hitting the switch
chances are you've connected the the new cord to wrong side of the switch thus bypassing it, also if its soldered joints,make sure that you've not linked both sides of switch with the solder.
Nov 10, 2010 | Kenmore 31913 Progressive Direct Drive...
Brush will not turn
The vacuum needs a new belt. Check the brush roller, if it turns easily without resitance, it needs a new belt. Get your model number off the back of the machine. It's on a sticker near the floor with UL logo on it. Go to Sears and gets some belts.
Apr 16, 2010 | Kenmore Progressive Bagless Upright with...
Carpet roller brush will not turn
You probably need a new belt. You can get kenmore belts here:
Kenmore Belts
Jan 02, 2010 | Vacuums
Vacum not sucking the dirt and the light is not turning on
loss of vaccum brush head not spinning check belt turn over remove bottem plate check belt assmble. remove any string or hair build up sear is the best bet for the belt
Mar 31, 2009 | Kenmore 34923 / 34925 Progressive Bagged...
Brushes don't turn
i once was a vacume salesman and i have handled a lot of differnt kinds of vacumes there are a few things that will make the brushs not spin the belt could be broken is some there is a swith that when you lower the handle will turn on the brushes. or if the vacume is on the barefloor setting in somecases they also wont spin i hope this helps.
Nov 11, 2006 | Kenmore 31913 Progressive Direct Drive...
Kenmore 25614 / 25615 Progressive Bagged Canister Vacuum Logo
551 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
